| Physical | |
| Unit Weight | 30.3 lbs [13.61 kg] |
| Unit Dimensions | 14 3/4” x 17 1/2” x 4 3/8” (with feet) 375 mm x 445 mm x 112 mm (with feet) |
| Shipping Weight | 40.3 lbs [18.3 kg] |
| Shipping Dimensions | 20 1/2” x 24” x 10” 521 mm x 610 mm x 254 mm |
| Color Options | Black Silver |
| Power requirements | |
| Input Power | Auto Voltage: 120VAC or 230VAC 50 or 60Hz |
| Power Consumption | 30W |
| Digital audio inputs | |
| Inputs | I2S (2), Coax (2), XLR Balanced, Optical, USB |
| Sample Rates | Optical (TOSLink): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz and 96kHz S/PDIF (Coax and XLR): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz and 192kHz; DoP64 I2S: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256 USB: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256. |
| Analog Audio Output | |
| Connector | RCA single ended or balanced, XLR balanced |
| Output Level High, Maximum | 4 VRMS Balanced 2 VRMS Single Ended |
| Output Impedance | < 100Ω / 200Ω |
| Frequency Response | 20-20KHz +/- 0.25dB |
| THD+N @ 1KHz (full scale) |
<0.001% |
| Output Stage | High-speed op-amp with discrete buffers. |
| Data Handling | |
| Format | PCM or DSD |
PCM Input |
Up to 768KHz 32 bits |
| DSD Input | Up to DSD512 |
| DSD Output | DSD128, DSD256, DSD512 (user selectable) |
| Analog Conversion method | 64-bit FIR filter to low pass analog filter |
| I2S Digital Input | |
| Connector | HDMI |
| Format | PCM or DSD. DoP on all inputs as well as raw DSD on I2S inputs |
| USB Digital Input | |
| Connector | USB "B" Type |
| Format | PCM, DoP v1.1 (DSD over PCM), or Native DSD |
| Transfer Mode | Asynchronous |
| Streamer | |
| Connectivity |
Roon Ready |
| Network Support |
WiFi: IEEE 802.11 b/g/n/ac (2.4 & 5GHz dual band) |
PMG Signature · DAC
PMG Signature 512 DAC
Every detail the recording holds, recovered.
$8,999
Save up to $2,500 with a trade-in.
Options
Buy or audition near you
All dealersExclusive 60-day in-home trial
The Gold Home Experience
Live with it in your own room for 60 days. If it isn't right, you get a full refund and return shipping is on us.
How it works
- Zero risk. Full refund guaranteed.
- Full experience. Plenty of time for proper setup and break-in.
- Total comfort. Decide from the best seat in the house.
- Outside the US? Find your local dealer
Designed for your finest system. It plugs straight into a power amplifier
- Volume Built in, analog. Drives a power amp directly
- Formats PCM and quad-rate DSD
- Output Balanced XLR, Class A
- Inputs Includes I²S for DSD direct
What reviewers say
The music simply flows from the '512, solid and three-dimensional, tonally transparent.
There is an immediacy to every note that is highly addictive.
A world-class DAC.
Why choose it
One pure path for all your music
Whatever you play, streaming, CDs or files, is converted to one pure DSD stream, with no compromise. Volume is built in, so it can plug straight into your power amplifier.
Where it fits
The PMG Signature 512 DAC is as versatile as it is revolutionary—and a major step above even the finest DACs we’ve ever built. Use it as a standalone directly into your power amplifier, thanks to its ultra-precise analog volume control, and experience purity, dynamics, and realism like never before. At its heart is PS Audio’s latest high-definition streaming module, fully galvanically isolated to eliminate noise and preserve absolute musical integrity.
Read more
The PMG Signature 512 DAC is as versatile as it is revolutionary—and a major step above even the finest DACs we’ve ever built. Use it as a standalone directly into your power amplifier, thanks to its ultra-precise analog volume control, and experience purity, dynamics, and realism like never before. At its heart is PS Audio’s latest high-definition streaming module, fully galvanically isolated to eliminate noise and preserve absolute musical integrity. Whether paired with the PMG Signature Preamplifier for the ultimate reference system or run solo into your amp, the 512 delivers sound that is breathtakingly clear, natural, and alive. This isn’t just high-end performance. This is a whole new benchmark. The PMG Signature 512 DAC is music, uncompromised.
Design
How it's built
Designing the PMG Signature 512 DAC was never about meeting expectations—it was about redefining what a digital source could be. This is a radical departure not only from traditional PCM-based architectures but also from conventional DSD implementations and off-the-shelf chip solutions.
Read the full design story
At its core is our all-new PureStream® DSD512 engine, a proprietary design that upsamples every input—PCM or DSD—to a native 8X DSD stream. That stream is then refined by our SpectraWave 64-Tap Sequencer, a precision digital filter engineered to eliminate jitter, reduce noise, and preserve every nuance of the music. The result is pure sonic truth, passed into a fully balanced, direct-coupled analog output stage. With galvanically isolated inputs, a built-in high-performance streamer, and precision analog volume control, the PMG 512 is not just a DAC—it’s the heart of a no-compromise reference system.
- >100 dB
- SINAD
- 8x
- DSD PureStream engine
- 64-tap
- SpectraWave sequencer
Deep dive
Inside the PMG Signature 512 DAC
How it works, what’s inside and how it measures, for anyone who wants every detail.
Overview
Think of the PMG Signature 512 DAC as the ultimate destination in digital audio—a no-compromise centerpiece for the most revealing high-performance systems. Whether your setup is purely digital or a hybrid of analog and digital sources, the 512 redefines what’s possible from a DAC. Built around our PureStream DSD512 engine and SpectraWave 64-Tap Sequencer, and featuring a fully balanced, direct-coupled analog output stage, the PMG 512 delivers sound with breathtaking realism, depth, and musicality. It supports I²S for a perfect connection to our top transport, and includes a world-class galvanically isolated streamer. Replace your DAC, your streamer—or even your preamplifier—and prepare to be stunned by the transformation. Rich. Pure. Effortless. The PMG Signature 512 DAC is the product of over fifty years of innovation and the first to carry the name of our founder. It’s not just the best DAC we’ve ever built—it’s the best DAC we know how to imagine.
DSD vs. PCM, explainedVideo with Paul McGowan
At the heart of the PMG Signature 512 DAC is a breakthrough in digital audio: our PureStream DSD512 engine. Architected by engineer Doug Goldberg and realized through the exacting execution of chief engineer Bob Stadtherr, PureStream runs at a blazing 22MHz, upsampling any incoming PCM or DSD signal to a native 8X DSD stream—far beyond standard formats and completely free from PCM conversion or decimation.
This ultra-high-resolution DSD stream is then passed through our SpectraWave 64-Tap Sequencer, which time-aligns and refines the signal with surgical precision, lowering noise and distortion while preserving every musical nuance. From there, it flows directly into a simple, elegant analog low-pass filter—no complex conversion stages, just pure music.
The PMG Signature 512 doesn’t rely on off-the-shelf DAC chips. This is a custom-designed platform built from the ground up to achieve what no other DAC has: sonic transparency with SINAD better than -100dB and vanishingly low output noise. Multiple ultra-stable reclocking circuits, galvanic isolation between all digital inputs, and full separation between digital and analog sections ensure jitter-free, noise-immune performance.
And yes, the PMG Signature 512 also features our renowned Digital Lens technology, ensuring that incoming digital data is perfectly reorganized and reclocked before ever reaching the PureStream engine. Every effort in its design—from input to output—is focused on preserving imaging, tonal richness, and musical truth.
One listen, and you’ll know: this is unlike anything you’ve heard before.
The PMG Signature 512 DAC is not just a component—it’s a revolution in digital audio.
A walk through the PureStream engineVideo with Paul McGowan
An inside look
The SpectraWave 64-Tap Sequencer is a groundbreaking solution within the PMG Signature 512 DAC—unlike anything used in traditional digital filters. Conceived and architected by engineer Doug Goldberg, and brought to life through the meticulous execution of chief engineer Bob Stadtherr, SpectraWave represents a fundamental rethinking of how digital audio should be handled.
Engineered as a fully discrete FIR architecture, SpectraWave operates at the same extreme 22MHz sample rate as our PureStream DSD512 engine. Designed from the ground up to handle ultra-high-speed data streams, its 64 precisely tuned taps work in real time to align musical transients with absolute accuracy, ensuring perfect phase coherence and eliminating timing smear.
Where typical filters introduce artifacts like pre-ringing or harmonic distortion, SpectraWave maintains the purity of the signal without compromise. It preserves the natural shape and timing of every note, creating a spacious, uncolored soundstage with lifelike presence. Instruments bloom into three-dimensional space. Transients arrive exactly when they should. Nothing is exaggerated. Nothing is lost.
Following the sequencer, the signal flows seamlessly into the PMG Signature’s fully balanced, direct-coupled analog output stage. This minimal-feedback circuit—carefully refined by Bob Stadtherr for speed, transparency, and control—features ultra-low output impedance and high current drive, effortlessly powering even the most demanding downstream components. There are no transformers, no coloration, and no filters to blur the truth—just a clean, open window into the soul of the music.
This isn’t just a better DAC.
It’s a complete rethinking of what digital audio can be—from inspired architecture to uncompromising execution.
A walk through the SpectraWave sequencerVideo with Paul McGowan
Bench measurements
Audio Precision verification of the PMG Signature 512 DAC: distortion, noise floor, dynamic range and frequency response.
THD+N @ 1 kHz
0.000688% / 0.000479%
Ch1 / Ch2
SINAD @ 1 kHz
103.25 / 106.40 dB
Ch1 / Ch2
Dynamic range (AES17)
99.39 / 99.89 dB
Ch1 / Ch2
Output level @ 1 kHz
3.970 / 3.984 Vrms
Ch1 / Ch2
All bench graphs
All measurements captured with Audio Precision test equipment.
Features
At a glance
- Class A balanced analog output stage
- Full function DAC
- Fixed or variable DAC mode
- Analog volume control
- Balanced XLR output
- Digital Lens technology
- PureStream DSD 8x engine
- SpectraWave 64-tap sequencer
- High-current oversized analog power supply
- SINAD exceeding −100 dB
- No transformer in output signal path
- Quad rate DSD
- DSD direct through I²S
Specifications
Full specifications
| Physical | |
| THD+N @ 1KHz (full scale) | <0.001% |
| Data Handling | |
| PCM Input | Up to 768KHz 32 bits |
| Connector | HDMI |
| Streamer | |
| Connectivity | Roon Ready Tidal Connect Qobuz Connect Spotify Premium DLNA/UPnP ShairPort |
| Network Support | WiFi: IEEE 802.11 b/g/n/ac (2.4 & 5GHz dual band) 10/100/1000 Ethernet |
Compare
How it compares
| 512 DACThis one | StellarGold DAC | Stellar DAC | AirLens | |
| Price | $8,999 | $3,999 | $2,199 | $1,999 |
| Volume | Built in, analog. Drives a power amp directly | Built in. A preamp is best for high-end systems | Built in, fixed or variable | None. It feeds your DAC |
| Formats | PCM and quad-rate DSD | PCM to 768 kHz and quad-rate DSD | PCM and double-rate DSD | PCM to 352.8 kHz and quad-rate DSD |
| Output | Balanced XLR, Class A | Balanced XLR, Class A | Balanced XLR, Class A | I²S and coax, to your DAC |
| Inputs | I²S, USB, coax, optical and XLR digital, plus Ethernet and Wi-Fi | I²S, USB, coax and optical | I²S, USB, coax and optical | Ethernet or Wi-Fi. Roon Ready, Tidal and Qobuz Connect |
Build your system
What it pairs with
A power amplifier, connected directly
PMG Signature S400 Stereo$9,999Floorstanders, typical roomsView detailsA power amplifier, connected directly
PMG Signature M800 Monoblocks$29,998 / pairLarge rooms and demanding speakersView detailsTrade Up and Save
Save up to $2,500 on your PMG Signature 512 DAC
Your old gear is worth more than you think. PS Audio credits the full original retail value of what you trade, up to the limit, straight off your new purchase.
- Tell us what you have. Press Start your trade-in and list your gear. Nearly any working hi-fi component counts, from any brand.
- Pay the adjusted price. At checkout you are charged only the price after your credit. Our sales team reviews every trade within 48 hours.
- Send yours back. We email a return label number. You have 30 days to ship your trade.
The fine print
What we accept. Nearly any hi-fi make and model at component level: a preamplifier, power amplifier, DAC, phono stage, loudspeaker pair, turntable, headphones or CD transport. It must work and be in respectable cosmetic condition.
What we don't. Broken or non-working products, and most accessories, phono cartridges, power cables and interconnects. Exceptions can be made based on value.
Several items? Yes. Trade as many as you like, up to the credit cap. Use "Add another" on the Trade Up form.
Not sure it qualifies? Call 800-PSAUDIO (800-772-8346) or email sales@psaudio.com, and a real person will answer.
Reviews
More reviews
Paul, after receiving my new PMG Pre-amp and PMG DAC.
I have a hard time sitting down! How can you remain in your seat when life is blooming? The sound is so real! So moving! I can’t sit down! The music moves me out of my chair! I’m in love…..!!!!
Lots of detail that didn't sound bright or forced.
I might want to keep the PMG Signature 512 for a while yet.
A very long while. A world-class DAC.
I’ve had my PMG dac for a few months now and absolutely love it.
Among all the great attributes, the review mentions the quality of percussion instruments through the PMG, I had a similar experience. The clarity and presence of drums and cymbals is amazing.
Well, this PMG DAC blew me away right out of the box!
The PMG Signature 512 DAC has a presentation that is most recognizable by outstanding clarity.
Layer upon layer of detail is revealed... in a way that is natural, not forced.
Read all 17 reviews
Spatial detail against a crystal-clear background—it makes you want to sketch the concert hall by ear on graph paper
The new PMG Signature DAC 512 is a giant leap forward in nearly every way.
Sonically, it brings out every little nuance in recordings without ever sounding harsh.
The PMG 512 sounds incredible.
The single most impressive upgrade in the system to date. Going from the Stellar Gold DAC and Airlens to the PMG 512 DAC, listening to the difference to me is just jaw dropping. Thank you again for the amazing product. :blush:
I am simply amazed at how much the PMG 512 DAC contributes to the wondrous gestalt of my system.
I hadn’t realized just how capably and synergistically these components could function as a whole without having had a musical source as extraordinary, to me, as this DAC. I don’t need new speakers, or new amplification, or new cables, because now I know what my...
Maybe flabbergasted is too strong a word to describe what I heard, but I think it’ll do.
There are no nuances. Everything is obvious, and better, and not in a small way. Instruments are precisely placed, not only across the soundstage but also front-to-back. I didn’t realize my DSD was smearing the size and placement and the actual sound of the sound...
I am using the PMG dac without a preamp, couldn’t do that with the MKII.
The upgrade is fantastic. Go with the dac.
Vocals on the PMG 512 were clearer, more defined in space, and even more natural and human in tone and presence.
Cymbals were less smeared, more refined and delicate, the soundstage was wider and dimensional. Now, despite my old man hearing, I can hear more distinct, intelligible vocals. The background singers and instruments that I previously had strained to hear. It has been very rewarding listening...
"I was awestruck.
Stability, imaging, clarity, soundstage width and depth, silence between notes, dynamic range, bass reproduction, and "musicality" were consistently outstanding. I own a very good DAC -- the ****** Designs' M21. I would say the new PS Audio PMG DAC is at least its match and...
But the resolution that I am now able to hear without effort is more than mind-bending.
You and your team have knocked this one out of the park! I am hearing acoustic environments and timbres that I was simply not aware of.
Whether I play poorly recorded music or really well recorded music, the musicality enhancement is quite real.
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialistOutside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealerHear it in your own room
$8,999
- 60-day in-home trialThe Gold Home Experience. Return shipping is on us.
- Save up to $2,500 with a trade-inCredit comes off the price at checkout.
Free UPS Ground shipping (continental US only)
DAC & source
Meet the all new PMG Signature 512 DAC powered by PureStream DSD.
At home
Where the last box between you and the music disappears.
The whole of the recording — and none of the digital
Why the converter matters
Overview
An inside look
The proof is on the bench
What the numbers actually mean
Distortion you will never hear
under 0.001%
A blacker background
SINAD beyond −100 dB
Four converters, not one
×4 parallel DACs
Everything at its own resolution
PCM 768k · DSD ×8
Who it is for — and who it is not
Where it sits
Steps up from
Pairs with
Built for
What owners and reviewers say
Paul, after receiving my new PMG Pre-amp and PMG DAC. I have a hard time sitting down! How can you remain in your seat when life is blooming? The sound is so real! So moving! I can’t sit down! The music moves me out of my chair! I’m in love…..!!!!
I might want to keep the PMG Signature 512 for a while yet. A very long while. A world-class DAC.
I’ve had my PMG dac for a few months now and absolutely love it. Among all the great attributes, the review mentions the quality of percussion instruments through the PMG, I had a similar experience. The clarity and presence of drums and cymbals is amazing.
The PMG Signature 512 DAC has a presentation that is most recognizable by outstanding clarity. Layer upon layer of detail is revealed... in a way that is natural, not forced.
The new PMG Signature DAC 512 is a giant leap forward in nearly every way. Sonically, it brings out every little nuance in recordings without ever sounding harsh.
The PMG 512 sounds incredible. The single most impressive upgrade in the system to date. Going from the Stellar Gold DAC and Airlens to the PMG 512 DAC, listening to the difference to me is just jaw dropping. Thank you again for the amazing product. :blush:
I am simply amazed at how much the PMG 512 DAC contributes to the wondrous gestalt of my system. I hadn’t realized just how capably and synergistically these components could function as a whole without having had a musical source as extraordinary, to me, as this DAC. I don’t need new speakers, o...
Maybe flabbergasted is too strong a word to describe what I heard, but I think it’ll do. There are no nuances. Everything is obvious, and better, and not in a small way. Instruments are precisely placed, not only across the soundstage but also front-to-back. I didn’t realize my DSD was smearing t...
I am using the PMG dac without a preamp, couldn’t do that with the MKII. The upgrade is fantastic. Go with the dac.
Vocals on the PMG 512 were clearer, more defined in space, and even more natural and human in tone and presence. Cymbals were less smeared, more refined and delicate, the soundstage was wider and dimensional. Now, despite my old man hearing, I can hear more distinct, intelligible vocals. The back...
"I was awestruck. Stability, imaging, clarity, soundstage width and depth, silence between notes, dynamic range, bass reproduction, and "musicality" were consistently outstanding. I own a very good DAC -- the ****** Designs' M21. I would say the new PS Audio PMG DAC is at least its match and perh...
But the resolution that I am now able to hear without effort is more than mind-bending. You and your team have knocked this one out of the park! I am hearing acoustic environments and timbres that I was simply not aware of.
Trade up to it
Hear it first
Who made it
Not for sale
Design
Application
Overview
An inside look
Bench measurements
Audio Precision verification of the PMG Signature 512 DAC — distortion, noise floor, dynamic range, and frequency response.
All measurements captured with Audio Precision test equipment. Click any chart to enlarge.
Features
13 key featuresCLASS A BALANCED ANALOG OUTPUT STAGE
FULL FUNCTION DAC
FIXED OR VARIABLE DAC MODE
ANALOG VOLUME CONTROL
BALANCED XLR OUTPUT
DIGITAL LENS TECHNOLOGY
PURESTREAM DSD 8X ENGINE
SPECTRAWAVE 64-TAP SEQUENCER
HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
SINAD EXCEEDING -100DB
NO TRANSFORMER IN OUTPUT SIGNAL PATH
QUAD RATE DSD
DSD DIRECT THROUGH I2S
Reviews
17 reviews
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →The new PMG Signature DAC 512 is a giant leap forward in nearly every way. Sonically, it brings out every little nuance in recordings without ever sounding harsh.
I am simply amazed at how much the PMG 512 DAC contributes to the wondrous gestalt of my system. I hadn’t realized just how capably and synergistically these components could function as a whole without having had a musical source as extraordinary, to me, as this DAC. I don’t need new speakers, or new amplification, or new cables, because now I know what my system had been missing.
Maybe flabbergasted is too strong a word to describe what I heard, but I think it’ll do. There are no nuances. Everything is obvious, and better, and not in a small way. Instruments are precisely placed, not only across the soundstage but also front-to-back. I didn’t realize my DSD was smearing the size and placement and the actual sound of the sound until I heard the same pieces via the PMG.
Vocals on the PMG 512 were clearer, more defined in space, and even more natural and human in tone and presence. Cymbals were less smeared, more refined and delicate, the soundstage was wider and dimensional. Now, despite my old man hearing, I can hear more distinct, intelligible vocals. The background singers and instruments that I previously had strained to hear. It has been very rewarding listening to the new PMG series.
Maybe flabbergasted is too strong a word to describe what I heard, but I think it’ll do. There are no nuances. Everything is obvious, and better, and not in a small way. Instruments are precisely placed, not only across the soundstage but also front-to-back. I didn’t realize my DSD was smearing the size and placement and the actual sound of the sound until I heard the same pieces via the PMG. It’s as though there was always cloud of chaff, but I never noticed it until it was gone.
"I was awestruck. Stability, imaging, clarity, soundstage width and depth, silence between notes, dynamic range, bass reproduction, and "musicality" were consistently outstanding. I own a very good DAC -- the ****** Designs' M21. I would say the new PS Audio PMG DAC is at least its match and perhaps even its better. Bottom line: if you are in the market for a new DAC , you must seriously consider the PS Audio PMG DAC
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
