PMG Signature · Monoblock pair
PMG Signature M800 Monoblocks
Our finest power amplifier, period.
$29,998 / pair
Save up to $7,499 with your PS Audio amplifier trade-in.
Options
Buy or audition near you
All dealers
Exclusive 60-day in-home trial
The Gold Home Experience
Live with it in your own room for 60 days. If it isn't right, you get a full refund and return shipping is on us.
How it works
  • Zero risk. Full refund guaranteed.
  • Full experience. Plenty of time for proper setup and break-in.
  • Total comfort. Decide from the best seat in the house.
Designed for large rooms and demanding speakers
  • Power 400 W into 8Ω · 800 W into 4Ω
  • Design Mono pair, one per speaker
  • 50 W of Class A bias: 99% of typical listening in pure Class A
What owners say
Similar to my experience when I went from the BHK 300 amps to the BHK 600’s, the step up to the M800’s is not subtle at all - it’s revelatory.
MMasonStormOwner · PS Audio forum · 2026
It’s super quiet, dynamic and highly resolving.
SstraightwireOwner · PS Audio forum · 2026
Low level percussive stuff jumps out. Imaging appears to be more pinpoint.
JJoeOwner · PS Audio forum · 2026
Why choose it
Pure Class A for nearly everything you play
50 watts of Class A bias keeps 99% of typical listening in the amplifier's most linear region. And with 400 watts into 8Ω, doubling to 800 into 4Ω, nothing your speakers ask for is out of reach.
Where it fits
Each M800 is a monoblock — one chassis, one channel — sold as a pair for stereo. With 800 watts into 4 ohms and the current to double down without strain, a pair will drive virtually any loudspeaker made, from sensitive horns and electrostatics to the most demanding low-impedance reference designs. There is no speaker too difficult and no room too large.
Read more
Each M800 is a monoblock — one chassis, one channel — sold as a pair for stereo. With 800 watts into 4 ohms and the current to double down without strain, a pair will drive virtually any loudspeaker made, from sensitive horns and electrostatics to the most demanding low-impedance reference designs. There is no speaker too difficult and no room too large. If you own loudspeakers that have humbled other amplifiers, the M800 is the pairing that ends the search.
Watch
Why the power supply is everything
PS Audio founder Paul McGowan on why the power amplifier matters more than most people think, and on the power supply at the heart of every PMG Signature amplifier.
The unloved power amplifier
Paul McGowan · 6 min
The secret behind the PMG amplifiers
Design
How it's built
The M800's character begins with its power supply. Where a conventional amplifier leans on a heavy passive transformer, the M800 is built around a state-of-the-art active power supply — a design that delivers current with a speed and stability no transformer-based supply can match.
Read the full design story
The M800's character begins with its power supply. Where a conventional amplifier leans on a heavy passive transformer, the M800 is built around a state-of-the-art active power supply — a design that delivers current with a speed and stability no transformer-based supply can match. Around it sits Darren Myers' low-feedback current-based topology, chosen deliberately: the less an amplifier has to correct itself, the more honestly it passes the signal through. Every M800 is assembled and tested by hand in Boulder, Colorado, and brought into production by Bob Stadtherr — whose work ensures the amplifier you receive measures and sounds exactly like the one Darren designed.
800 W
into 4Ω, per monoblock
50 W
of pure Class A bias
>500 kHz
bandwidth
>200 V/µs
slew rate
01
Class A purity
Class A is the most linear way an amplifier can operate — and the most expensive. In a Class A output stage, every transistor conducts through the entire musical waveform and never switches off.
Read more
Class A is the most linear way an amplifier can operate — and the most expensive. In a Class A output stage, every transistor conducts through the entire musical waveform and never switches off. There is no crossover point, no moment where one device hands off to another, no discontinuity for the music to stumble across. It is, simply, the purest mode of amplification known.
It is also brutally inefficient. A Class A stage runs hot and draws power continuously, even in silence, because its transistors are always fully active. That cost is why true Class A is so rare. It is rare for a high-end amplifier to deliver even a single watt of genuine, pure Class A — most designs that advertise the term operate in it for only a fraction of a watt before sliding into Class AB.
The M800 carries 50 watts of pure Class A bias. Fifty. Not a fraction of a watt, but fifty full watts before the output stage ever leaves its most linear region. For 99% of normal listening — and nearly all music lives well within that window — the M800 never crosses a notch, never sees a discontinuity, never asks its circuitry to correct an artifact it should not have created. What you hear is the natural texture of the recording: the body of a cello, the air around a voice, the decay of a struck cymbal, all intact. This is what Class A was always supposed to sound like. The M800 simply commits to it.
02
Power is The Key
A power amplifier is, fundamentally, an interface between a reservoir of energy and the loudspeaker. The character of that reservoir — how cleanly it stores energy, how instantly it can deliver it, how silent it is at rest — determines more about how an amplifier sounds than any other single design choice.
Read more
A power amplifier is, fundamentally, an interface between a reservoir of energy and the loudspeaker. The character of that reservoir — how cleanly it stores energy, how instantly it can deliver it, how silent it is at rest — determines more about how an amplifier sounds than any other single design choice. For half a century, the high-end audio industry has approached this with passive supplies: large linear transformers feeding banks of electrolytic capacitors. The approach works. It also imposes real limitations. The transformer is the slowest element in the amplifier's signal path. The capacitors store charge but cannot return it without ripple. The rectifier introduces switching noise every time it transitions. And the entire arrangement is sized for a peak demand it will almost never actually see.
The M800 is built on a state-of-the-art active power supply that delivers performance benefits no traditional transformer-based passive supply can match. Instant transient response with no rectifier-induced noise. A vanishingly low residual noise floor. Total grip on the speaker at any output level. Full continuous output without sag. The active supply is the M800's foundation — silent, fast, and capable of delivering everything the output stage asks for the moment it asks for it.
03
The PMG disappears into the Music
Negative feedback is the most powerful tool an amplifier designer has — and the most easily abused. Applied in large amounts, it can drive measured distortion on a steady-state test tone almost to zero.
Read more
Negative feedback is the most powerful tool an amplifier designer has — and the most easily abused. Applied in large amounts, it can drive measured distortion on a steady-state test tone almost to zero. It looks spectacular on a spec sheet. But feedback works by continuously comparing the output to the input and correcting the difference, and that correction is never quite instantaneous. With music — which is nothing but transients, never a steady tone — heavy feedback always arrives a fraction late. The amplifier spends its life chasing the signal rather than following it. Transients lose their edge. Immediacy fades. The performance begins to feel like a recording of a performance.
The M800 is built on the opposite philosophy: strikingly low overall feedback. Because its output stage is already extraordinarily linear on its own — running deep in pure Class A, where correction is barely needed — the M800 does not have to lean on a heavy feedback loop to clean up after itself. Distortion stays uniformly low across the entire audible band not by aggressive correction, but because there was little to correct in the first place.
What this produces is the M800's defining quality, and the hardest to put into words: it disappears. The electronics stop announcing themselves. The speakers and the source seem to dissolve, and what remains is the performance — present, immediate, and whole. Eight hundred watts of authority, delivered with the openness of a far smaller amplifier. The M800 gives you both.
Deep dive
Inside the PMG M800 Monoblock
How it works, what’s inside and how it measures, for anyone who wants every detail.
Bench measurements
Measured on our bench in Boulder.
Distortion vs. frequency
Twin-tone intermodulation
10 kHz square wave
10 kHz square wave
Features
At a glance
  • 400 watts into 8Ω, doubling to 800 watts into 4Ω
  • 50W Class A bias — 99% of typical listening in pure Class A
  • Slew Rate >200V/uS
  • Bandwidth exceeding 500 kHz
  • Flat distortion across the audible band with strikingly low overall feedback
  • State-of-the-art active power supply
  • Balanced (XLR) and single-ended (RCA) inputs
  • Available in Silver or Black
  • Hand built in Boulder, Colorado
Specifications
Full specifications
Unit Weight95.7 lbs / 43.4 kg
Unit Dimensions26.75 in L × 17.5 in W × 8 in H (679.5 × 444.5 × 203.2 mm) With feet & binding posts: 27.5 in L × 17.5 in W × 8.75 in H
Shipping Weight119.2 lbs / 54.1 kg (per unit)
Shipping Dimensions34.4 × 23.1 × 14.9 in / 873.8 × 586.7 × 378.5 mm (2 units)
Input PowerAuto Voltage: 120VAC or 230VAC, 50 or 60 Hz
Power ConsumptionStandby (Ready): <2W | Idle: 360W | 25W/4Ω: 520W
FusesNo user serviceable fuses
Audio InputsRCA (Single-ended): 1 pair | XLR (Balanced): 1 pair
Speaker OutputsSilver Plated Binding Posts: 2 pair
TriggerInput: 3.5mm, 5–15VDC | Output: 3.5mm, 12VDC
Gain26.2 dB
Sensitivity2.8V
Power Output400W into 8Ω, 800W into 4Ω, 1200W into 2Ω (1kHz, <1% THD)
Class A Power Output60W into 8Ω
Frequency Response<10Hz – 80kHz (±0.25dB)
Input Impedance100kΩ Single-ended | 200kΩ Balanced
Bandwidth>500kHz
THD<0.002% typical (20Hz–20kHz, 1W/8Ω)
Damping Factor>300 at 8Ω (20Hz–1kHz)
Compare
How it compares
M800This oneM400S400S200M1200M700S300Strata
Price$29,998 / pair$17,998 / pair$9,999$7,999$6,998 / pair$3,498 / pair$1,999$3,499
Speakers & roomLarge rooms, any speakerLarge floorstanders, medium to large roomsFloorstanders, typical roomsBookshelf or efficient speakers, smaller roomsLarge or hard-to-drive speakersFloorstanders, typical roomsBookshelf speakers, smaller roomsAdd your speakers, bookshelf or floorstanding
Power400 W into 8Ω · 800 W into 4Ω200 W into 8Ω · 400 W into 4Ω200 W into 8Ω · 400 W into 4Ω, per channel100 W into 8Ω · 200 W into 4Ω, per channel600 W into 8Ω · 1,200 W into 4Ω350 W into 8Ω · 700 W into 4Ω140 W into 8Ω · 300 W into 4Ω, per channel—
DesignMono pair, one per speakerMono pair, one per speakerStereo, one boxStereo, one boxMono pair, one per speakerMono pair, one per speakerStereo, one boxIntegrated, one box
What sets it apart50 W of Class A bias: 99% of typical listening in pure Class A30 W of Class A bias10 W of Class A bias per channel10 W of Class A bias per channelVacuum tube input stageStable down to 2ΩDual mono, a separate power supply for each channelMoving magnet and moving coil phono, plus a Class A headphone amp
What's inside———————Streaming DAC, preamplifier, phono stage, amplifier
Build your system
What it pairs with
Trade Up and Save
Save up to $7,499 on your PMG Signature M800 Monoblocks
Your old gear is worth more than you think. PS Audio credits the full original retail value of what you trade, up to the limit, straight off your new purchase.
  1. Tell us what you have. Press Start your trade-in and list your gear. Nearly any working hi-fi component counts, from any brand.
  2. Pay the adjusted price. At checkout you are charged only the price after your credit. Our sales team reviews every trade within 48 hours.
  3. Send yours back. We email a return label number. You have 30 days to ship your trade.
Start your trade-in
The fine print
What we accept. Nearly any hi-fi make and model at component level: a preamplifier, power amplifier, DAC, phono stage, loudspeaker pair, turntable, headphones or CD transport. It must work and be in respectable cosmetic condition.
What we don't. Broken or non-working products, and most accessories, phono cartridges, power cables and interconnects. Exceptions can be made based on value.
Several items? Yes. Trade as many as you like, up to the credit cap. Use "Add another" on the Trade Up form.
Not sure it qualifies? Call 800-PSAUDIO (800-772-8346) or email sales@psaudio.com, and a real person will answer.
Reviews
More reviews
Similar to my experience when I went from the BHK 300 amps to the BHK 600’s, the step up to the M800’s is not subtle at all - it’s revelatory, and frankly, probably, more so than that previous upgrade.
Not only can I hear more detail (and I’m genuinely alarmed at HOW MUCH more detail - as people always write, I’m hearing things I never heard before in tracks I’ve known for years)
FForum memberOwner · PS Audio forum · 2026
Read the full post
Imaging appears to be more pinpoint. Recently, I was able to move my FR-30’s further out from the front wall and things improved a lot. So far, the M800’s are keepers.
Read the full post
Interview with Paul at the High End Vienna show 2026
SSG Akustik - Youtube2026
Read the full review
The BHK models are sweet and seductive (tubes?) but if you want step everything up a notch, these amps can do it. The lower noise floor was noticeable right at the start.
Read the full post
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialist
Outside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealer
Hear it in your own room
$29,998 / pair
  • 60-day in-home trialThe Gold Home Experience. Return shipping is on us.
  • Save up to $7,499 with your PS Audio amplifier trade-inCredit comes off the price at checkout.
Add to cartTrade up your gear and save
PMG Signature · Flagship
The new M800
Monoblock.
The flagship of the PMG Signature Series. The best power amplifier PS Audio has ever built — period.
800 watts · 4Ω Power
50WClass A bias >500 kHz Bandwidth >200V/µS Slew rate State of the art Distortion vs. frequency
Skip to product information
PMG M800 Monoblock
href="/products/pmg-m800?variant=51635812434210" class="link" >PMG M800 Monoblock
PMG M800 Monoblock
PS Audio has been designing and building amplifiers for half a century. Every one has been a step toward sonic perfection — each teaching us something the last could not: about power supplies, about feedback, about the quiet ways an amplifier can color the music it carries. The M800 is where that road arrives.
Eight hundred watts into 4 ohms, doubling cleanly down from 400 into 8 — decisive, effortless, never strained.
But power was never the hard part. Speed, evenness, and restraint were. The M800 is the first amplifier we've built to hold all three at once.
Its slew rate exceeds 200 volts per microsecond. Hand it a 10 kHz square wave — the cruelest signal in audio — and it returns vertical edges and flat tops, no overshoot, no ringing. In fifty years we have never seen one this perfect. Distortion stays flat and low across the entire audible band, never trading one frequency for another. And it does all of this with strikingly low overall feedback — no heavy correction, just the music. Remarkable.
Designed by Darren Myers. Engineered by Bob Stadtherr. Hand-built in Boulder, Colorado.
Price is per pair.
Save up to $7,499 with your PS Audio amplifier trade-in!
$29,998.00
A pair of PMG Signature M800 monoblock amplifiers in a living room
At home
Where the biggest amplifier we build disappears into the music.
Nothing in the music asks more of it than it has
400 watts into 8 ohms, doubling to 800 into 4 and 1,200 into 2 — and the first 50 of those watts are pure Class A, where nearly all ordinary listening actually happens.
Why a monoblock
An amplifier running out of power does not announce it. It rarely sounds distorted — it sounds smaller. The orchestra stops growing at the moment it should overwhelm you, the drum stops being startling, and you quietly conclude the recording was disappointing. It usually was not.
A monoblock is the answer taken to its end: one amplifier and one power supply per channel, sharing nothing with the other. The M800 is what we build when nothing is being traded away.
The proof is on the bench
The proof on this page is the measurements — and they are better proof than most reviews. Very few makers publish figures this specific, and anyone who knows what they are looking at will notice that we did. We took them on our own bench, and further down this page we tell you how.
What the numbers actually mean
You never have to read these to enjoy the music. But if you like knowing why something sounds the way it does, here is what we measured — and what each figure quietly does for the sound in your room.
Distortion you will never hear
under 0.002%
Total harmonic distortion, typical from 20 Hz to 20 kHz at one watt into 8 ohms — measured across everything you can hear, not at one flattering frequency. What reaches you is the recording, and nothing the amplifier added to it.
An iron grip on the woofer
damping over 300
At 8 ohms, from 20 Hz to 1 kHz. It is how firmly the amplifier holds the cone still the instant the music stops — the difference between bass that booms and bass that starts and stops exactly on cue.
Flat well past hearing
10 Hz–80 kHz
Within a quarter of a decibel, with bandwidth reaching beyond 500 kHz. Everything you can actually hear sits in the calm middle of what this circuit can do, never straining near its edges.
Quick enough for every edge
over 200 V/µs
Slew rate — how fast the output can change. Music is full of sudden edges, a rim shot or a plucked string, and this is the figure that decides whether they arrive whole or slightly blunted.
What owners and reviewers say
Similar to my experience when I went from the BHK 300 amps to the BHK 600’s, the step up to the M800’s is not subtle at all - it’s revelatory, and frankly, probably, more so than that previous upgrade. Not only can I hear more detail (and I’m genuinely alarmed at HOW MUCH more detail - as people ...
PS Forum - MasonStorm · Read full review
Low level percussive stuff jumps out. Imaging appears to be more pinpoint. Recently, I was able to move my FR-30’s further out from the front wall and things improved a lot. So far, the M800’s are keepers.
Joe - PS Forum · Read full review
SG Akustik - Youtube · Read full review
It’s super quiet, dynamic and highly resolving. The BHK models are sweet and seductive (tubes?) but if you want step everything up a notch, these amps can do it. The lower noise floor was noticeable right at the start.
straightwire - PS Forum · Read full review
Who it is for — and who it is not
For a loudspeaker that has never been properly driven — something demanding, in a large room, that you have always suspected you were not hearing all of.
If your loudspeakers are efficient and your room is normal, buy the S400 instead and spend the difference on the source. The M800 exists for the cases where the amplifier is genuinely the limit. Tell us what you own and we will tell you honestly whether that is you.
Where it sits
Steps up from
The PMG Signature M400 monoblock amplifier — the same design at half the power, for rooms that do not need this.
Pairs with
The PMG Signature Preamplifier and the PMG Signature 512 DAC, which publishes its full bench measurements per channel.
Built for
Aspen FR20 and FR30 loudspeakers, and anything else that has been asking more than it was given.
Trade up to it
You do not have to have bought from us before, and it does not have to be ours. Trade in almost any component from any brand — a preamplifier, a DAC, another amplifier — and we credit its full original retail value against this one.
There is a cap on how much credit a single component can carry toward the M800, and the exact figure appears the moment you start a trade. See what yours is worth.
Hear it first
Sixty days in your own room, and we pay the return shipping if it goes back. Not a restocking arrangement and not a deposit — the amplifier arrives, you live with it through a season of listening, and if it is not what you hoped, it goes back at our expense.
Who made it
The M800 was designed by Darren Myers. In his own words:
“When I begin a design like the PMG amplifiers, I clear out the old concepts and rethink the whole signal chain from scratch. A fresh start — and it begins with a list of everything I have ever wanted from a perfect amplifier: effortless, seemingly unlimited dynamic range, and a sweetness and musicality that keeps me up late at night, just listening.
Through every decision that follows, I keep coming back to that one goal — the moment the music takes hold and pulls you in, almost hypnotic, until you look up and hours have gone. That feeling, that emotional tie, matters more to me than any measurement target I could ever set for myself.”
Darren Myers, designer · PMG Signature Series
Designed and engineered in Boulder, Colorado.
Not for sale
The measurements above were taken on our own bench and we publish the method. If you want to know why we measure the way we do, Paul answers questions on video most weekdays, and the factory is open to visitors.
Try a pair at home for 60 days $29,998.00 the pair
Take it home
PMG M800 Monoblock
Design
Application
Class A purity
Power is The Key
Bench measurements
Independently verified across the tests that separate good amplifiers from great ones.
Distortion vs. Frequency
Distortion vs. Frequency — This measurement tracks total harmonic distortion across the entire audio band, from 20 Hz to 20 kHz, under four conditions: no load, 8 ohms, 4 ohms, and a punishing 2 ohms. The traces do vary — distortion climbs gently with frequency, and the hardest 2-ohm load runs highest — but the takeaway is simple. Even at its worst, the PMG's distortion stays a tiny fraction of one percent, far below the level of audability. Linearity held this tight, across every load, and achieved without adding negative feedback, is something perhaps one amplifier in a hundred can claim — which means distortion simply stops being part of the conversation.
Twin tone Intermodulation results
Twin tone Intermodulation results — Here the amplifier is fed two tones at once — 19 kHz and 20 kHz — and we look for everything it adds that shouldn't be there. An amplifier that isn't perfectly linear lets those two tones beat against each other and spawn entirely new frequencies that have no musical relationship to the original signal. Those added tones are precisely what the ear registers as harshness, grain, and listening fatigue. The PMG produces almost none — the spectrum is essentially just the two original tones and silence. That is the measurable fingerprint of sound that stays clean and natural no matter how dense or demanding the music becomes.
10kHz square wave response
10kHz square wave response — A square wave is the cruelest signal you can hand an amplifier; it demands instantaneous swings in output voltage. Reproducing one cleanly takes tremendous speed — measured as slew rate — and the PMG Signature series exceeds 200 volts per microsecond. You can see the result here: vertical edges, flat tops, no overshoot, no ringing. Real music is full of fast transients — the leading edge of a cymbal, the snap of a plucked string — and an amplifier too slow to follow them rounds those transients off and smears the detail. The PMG follows all of it. In fifty years of designing amplifiers, we have never measured a square wave this perfect.
Features
9 key features
Slew Rate >200V/uS
Reviews
4 reviews
Similar to my experience when I went from the BHK 300 amps to the BHK 600’s, the step up to the M800’s is not subtle at all - it’s revelatory, and frankly, probably, more so than that previous upgrade. Not only can I hear more detail (and I’m genuinely alarmed at HOW MUCH more detail - as people always write, I’m hearing things I never heard before in tracks I’ve known for years)
Read full review →
Joe - PS Forum
Joe - PS Forum
Read full review →
Read full review →
Read full review →
Want to leave your own review?
Specifications
Technical details
Unit Weight 95.7 lbs / 43.4 kg
Unit Dimensions 26.75 in L × 17.5 in W × 8 in H (679.5 × 444.5 × 203.2 mm)
Shipping Weight 119.2 lbs / 54.1 kg (per unit)
Shipping Dimensions 34.4 × 23.1 × 14.9 in / 873.8 × 586.7 × 378.5 mm (2 units)
Input Power Auto Voltage: 120VAC or 230VAC, 50 or 60 Hz
Power Consumption Standby (Ready): <2W  |  Idle: 360W  |  25W/4Ω: 520W
Fuses No user serviceable fuses
Audio Inputs RCA (Single-ended): 1 pair  |  XLR (Balanced): 1 pair
Speaker Outputs Silver Plated Binding Posts: 2 pair
Trigger Input: 3.5mm, 5–15VDC  |  Output: 3.5mm, 12VDC
Gain 26.2 dB
Sensitivity 2.8V
Power Output 400W into 8Ω, 800W into 4Ω, 1200W into 2Ω (1kHz, <1% THD)
Class A Power Output 60W into 8Ω
Frequency Response <10Hz – 80kHz (±0.25dB)
Input Impedance 100kΩ Single-ended  |  200kΩ Balanced
Bandwidth >500kHz
THD <0.002% typical (20Hz–20kHz, 1W/8Ω)
Damping Factor >300 at 8Ω (20Hz–1kHz)
Recommended products
