| Physical | |
| Unit Weight | 22.5 lbs [10.2 kg] |
| Unit Dimensions | 17"W x 3"H x 12" D [43.18 cm x 7.62 cm x 30.48 cm] |
| Shipping Weight | 26 lbs [11.8 kg] |
| Shipping Dimensions | 22"W x 8"H x 17"D [55.88 cm x 20.32 cm x 43.18 cm] |
| Color Options | Black Silver |
| Power requirements | |
| Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
| Power Consumption | 25W |
| Digital audio inputs | |
| Inputs | I2S (2), Coax (2), Optical, USB |
| Sample Rates | I2S: 2 inputs - PCM 44.1KHz to 384Khz, DSD64, DSD128, DSD256 Coax: 2 inputs - PCM 44.1KHz - 192KHz Optical: 1 input - PCM 44.1kHZ - 192KHz USB: 1 input - PCM 44.1kHZ - 384KHz - DSD64, DSD128 (native) - DSD64, DSD128 (DoP) |
| Analog Audio Output | |
| Connector | RCA single ended, XLR balanced |
| Output Level High, Maximum | 4 VRMS Balanced 2 VRMS Single Ended |
| Output Impedance | 100Ω / 200Ω |
| Frequency Response | 20Hz-20kHz, +/- 0.1dB 10Hz-55kHz, -1dB |
| Max Output | 4V RMS Balanced, 2V RMS single-ended |
| THD+N @ 1KHz (full scale) | <0.003% at full output |
| IMD | <0.004%, CCIF, at full output |
| SNR | 110dB, referenced to 4V RMS |
| Data Handling | |
| Format | PCM or DSD |
| Sample Rate (PCM) | 44.1kHz, 48.0kHz, 88.2kHz, 96.0kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz |
| Word Length (PCM) | 16-32 bit |
| Data Rate (DSD) | Up to DSD256 (11.2MHz) Native |
| Digital Volume Control | Yes |
| Analog Conversion | ES9018K2M DAC Chip |
| I2S Digital Input | |
| Connector | HDMI |
| Format | PCM or DSD. DoP on all inputs as well as native DSD on |
| USB Digital Input | |
| Connector | USB "B" Type |
| Format | PCM, DoP v1.1 (DSD over PCM), or Native DSD |
| Transfer Mode | Asynchronous |
Factory Certified
Stellar · DAC
Stellar™ DAC
Wonderful imaging and musicality, at a price you can afford.
$899 $2,199
Options
Join the waiting list
Factory Certified units come back in small numbers. Leave your email and we'll let you know when one is ready.
Buy or audition near you
All dealersFactory Certified
Tested in Boulder by the people who built it
14-day in-home evaluation. One-year factory warranty when registered. Each unit is fully factory tested in Boulder; some may show light cosmetic blemishes.
Factory Certified units are already priced well below new, so they can't be combined with Trade-Up credit or other discounts.
- Outside the US? Find your local dealer
Designed for a first serious DAC
- Volume Built in, fixed or variable
- Formats PCM and double-rate DSD
- Output Balanced XLR, Class A
- Inputs Includes I²S for DSD direct
What reviewers and owners say
This is a truly fine sounding DAC, with much to recommend it and little to leave wanting.
The Stellar really opened up the sound field over the Woo DAC section.
The big surprise was the soundstage and instrument definition.
Why choose it
Shape the sound to your taste
Three digital filters let you pick the presentation that suits your system and your ears. Wonderful imaging and musicality, at a price you can afford.
Where it fits
The Stellar DAC is a full-function Digital Analog Converter that can take in any digital source, from DSD to PCM, and output low distortion, high-resolution fully balanced analog. It is all you need as the basis for a reference quality digitally based music system. Add a power amplifier and a pair of loudspeakers, and using Stellar DAC's built-in lossless volume control, you'll be reveling in sonic bliss within moments.
Read more
The Stellar DAC is a full-function Digital Analog Converter that can take in any digital source, from DSD to PCM, and output low distortion, high-resolution fully balanced analog. It is all you need as the basis for a reference quality digitally based music system. Add a power amplifier and a pair of loudspeakers, and using Stellar DAC's built-in lossless volume control, you'll be reveling in sonic bliss within moments. Connect a computer, CD player, streamer, AirLens, or digital source of any kind to any of Stellar's multiple digital inputs, and you've just built one of the highest-value music systems in the world.
Design
How it's built
The idea of building an affordable, high-performance Digital to Analog Converter that can act as the center of an audiophile's music system was at the core of our engineering efforts with Stellar DAC. At this instrument's heart is the industry-leading Sabre32 bit Hyperstream Digital to Analog converter as fed by PS Audio's own Digital Lens reclocking circuit.
Read the full design story
The idea of building an affordable, high-performance Digital to Analog Converter that can act as the center of an audiophile's music system was at the core of our engineering efforts with Stellar DAC. At this instrument's heart is the industry-leading Sabre32 bit Hyperstream Digital to Analog converter as fed by PS Audio's own Digital Lens reclocking circuit. Once the incoming digital audio data has been accumulated and organized, the Digital Lens outputs near-perfect data without jitter for an amazingly clear and clean image. Stellar DAC features a fully balanced Class A analog output stage with multiple power supplies, DSD, I²S, and asynchronous USB. Stellar DAC is a winner in any system.
Deep dive
Inside the Stellar DAC
How it works, what’s inside and how it measures, for anyone who wants every detail.
Overview
Think of the Stellar DAC as the gateway to building a high-performance audio system at a down-to-earth price. Whether your dream system's main source of music is digital, or you're building a hybrid of both vinyl and digital, Stellar DAC offers great sonics that can bring a level of musicality to any system. Stellar DAC supports pure DSD, asynchronous USB, Digital Lens technology, I²S to connect to our best transport, balanced throughout. Replace your preamplifier, your DAC—or both—and be stunned at the level of improvement when the full and rich tapestry of music surprises and delights your senses. The Stellar DAC is the perfect foundation for those on a budget but are unwilling to compromise sound quality. Rich. Lush. Powerful. A music lover’s answer to spiraling cost-no-object equipment without sacrifice. In the more than fifty years of PS Audio’s design innovations and breakthrough products, Stellar’s groundbreaking level of performance as our gateway standalone DAC is unmatched for price and performance by its standalone competitors.
The DAC
At the heart of the Stellar DAC is its ESS Hyperstream and its fully balanced, class A gain stage. While numerous DACs employ ESS parts, no one but PS Audio surround those parts with our Digital Lens technology at its input and our hybrid class A gain stage at its output. Turns out that much of how a DAC performs and sounds is found in the way its input and output are handled. Engineers can tune an instrument's performance by varying the topologies of these two critical stages. At PS Audio, we focus our sonic efforts on imaging—helping the loudspeakers disappear— and proper, rich, tonal balance. One listen to the Stellar DAC and you'll know you're in good company.
An inside look
The DAC inside the Stellar GainCell will transform your expectations of what’s possible in resolving all of music's nuance and splendor without a trace of digital harshness. The DAC itself is based on the latest acclaimed 32-bit ESS Sabre Hyperstream architecture, the output of which is passively filtered to reduce transient distortion. The DAC's output stage is a unique Class-A configuration, fully balanced and direct coupled hybrid array, with an extended bandwidth of -3dB at 60 kHz. Stellar DAC features a high-resolution USB path based on the same XMOS technology found in our DirectStream DAC, as well as our exclusive I²S inputs featuring a separate clock and data signal from the source. I²S outputs are sent via an HDMI cable and I²S compatible sources can be purchased from PS Audio as well as other manufacturers. We believe that one audition of a simple CD, played through Stellar DAC, will open your eyes to the magic these design efforts have brought. And once you hear what Stellar DAC does on ordinary CDs, we can’t wait for you to hear what this fine instrument can do for higher resolution PCM and DSD.
Features
At a glance
- Class A balanced analog output stage
- Full function DAC
- Fixed or variable DAC mode
- Hybrid design
- Balanced XLR output
- Digital Lens technology
- Three selectable digital filters
- CPLD (FPGA) input
- High-current oversized analog power supply
- Latest ESS HyperStream
- Direct coupled: no capacitors in the signal path
- Single and double rate DSD
- DSD direct through I²S
Specifications
Full specifications
| Physical | |
| Data Handling | |
| Connector | HDMI |
Compare
How it compares
| 512 DAC | StellarGold DAC | Stellar DACThis one | AirLens | |
| Price | $8,999 | $3,999 | $2,199 | $1,999 |
| Volume | Built in, analog. Drives a power amp directly | Built in. A preamp is best for high-end systems | Built in, fixed or variable | None. It feeds your DAC |
| Formats | PCM and quad-rate DSD | PCM to 768 kHz and quad-rate DSD | PCM and double-rate DSD | PCM to 352.8 kHz and quad-rate DSD |
| Output | Balanced XLR, Class A | Balanced XLR, Class A | Balanced XLR, Class A | I²S and coax, to your DAC |
| Inputs | Includes I²S for DSD direct | I²S, USB, AES/EBU and coax | Includes I²S for DSD direct | Ethernet or Wi-Fi. Roon Ready, Tidal and Qobuz Connect |
Build your system
What it pairs with
A power amplifier or preamplifier
Stellar S300 Stereo$1,999Bookshelf speakers, smaller roomsView detailsA power amplifier or preamplifier
StellarGold Preamplifier$3,999Most systems with several sourcesView detailsReviews
More reviews
The Stellar DAC displays its ability to handle this large scale orchestral work with grade and authority.
It was a completely jaw dropping moment.
I have had mine for two weeks and I’m loving it.
Read all 7 reviews
Sounds more like a hiend room at the ces show.
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialistOutside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Stellar DAC - Factory Certified
Note:
Discontinued from new production in 2025
Factory Certified
Stellar DAC brings wonderful imaging and musicality to any high-performance system at a price you can afford.
What Factory Certified means
These are PS Audio units that have come home to our factory in Boulder — trade-ins, demos, and returns — not off-the-shelf new production. Each one is fully tested on the same benches we use for new gear: performance, safety, and reliability before it ships again.
- 14-day in-home evaluation — live with it in your own system before you decide.
- One-year factory warranty from your purchase date when you register the serial (new products carry three years).
- Honest cosmetics — function and measured performance meet factory standards; some units may show light blemishes.
Overview
The DAC
An inside look
What owners and reviewers say
This is not the 30-day new-product trial — it is the Factory Certified evaluation period. How it works, or read the full warranty and returns policy.
Not for sale
We build these in Boulder, Colorado, and we are glad to show our work. Paul answers questions on video most weekdays, and the factory is open to visitors.
At home
Where it disappears into the music.
Design
Applications
Overview
The DAC
An inside look
Features
13 key featuresCLASS A BALANCED ANALOG OUTPUT STAGE
FULL FUNCTION DAC
FIXED OR VARIABLE DAC MODE
HYBRID DESIGN
BALANCED XLR OUTPUT
DIGITAL LENS TECHNOLOGY
THREE SELECTABLE DIGITAL FILTERS
CPLD (FPGA) INPUT
HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
LATEST ESS HYPERSTREAM
NO CAPACITORS IN OUTPUT SIGNAL PATH
SINGLE AND DOUBLE RATE DSD
DSD DIRECT THROUGH I2S
Reviews
7 reviews
Read full review →The big surprise was the soundstage and instrument definition.
Read full review →It was a completely jaw dropping moment.
Read full review →The Stellar really opened up the sound field over the Woo DAC section.
Read full review →I have had mine for two weeks and I’m loving it.
Read full review →Sounds more like a hiend room at the ces show.
Read full review →
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Specifications
| Physical | |
| Data Handling | |
| Connector | HDMI |
