Card decks
by Paul McGowan![Card decks](http://www.psaudio.com/cdn/shop/articles/cards-627167_1920.jpg?v=1674832131&width=1100)
When we enter this life we're each dealt a hand of cards. Each hand has a different distribution of good ones and bad ones and it is up to us to make the most out of the hands we are dealt.
The same can be said for our HiFi systems and rooms. None are perfect. All are compromised.
How we handle our setups: emphasizing its strengths, shoring up its weaknesses, determines the outcome.
I have always been most impressed with the humblest of systems.
When those shine you know there's a master card player behind them.
It is not a measure of how much great stuff you have, it's how effectively you have utilized what you do have.
- Opens in a new window.
