Idiots guide to Hi-Res burning on DVD for the Perfect Wave Duo using windows Vistaâ€
Rudimentary step by step
This will assume to are starting with FLAC (most common download format right now)
1: Download and install “Nero 9.0†free trial version(huge program, takes forever!)
2: Download free “Traders Little Helper†software.
3: Create 2 folders that you can easily find and access. Name one FLAC and the other WAV
4: Download FLAC file into pre-determined Flac folder .
5: Open “Traders Little Helperâ€
6: Select “Decode Audio Files†from the File menu .
7: Import/select the FLAC files to be converted using the “Add†button
8: Make sure the box next to “over-write existing file is NOT CHECKED
9: Make sure to select the WAV folder created above as the destination of new WAV files
10:Click the “Decode†button
You now have usable WAV files. Time to burn the DVD-R
11: Open Nero software
12: Select the “Rip and Burn†option tab
13: Select “Burn Data Disc†button
14: Do not use “Express Burnâ€. Select the “Burning ROM†option instead.
15: Select “DVD-ROM (UDF)†option from the left side column
16: Click the “UDF†tab on the top
17: Change options box to “Manual Settings†(this allows you to access UDF formats)
18: Leave Partition Type as “Physical “ and select “UDF 2.0†in the box below.
19: Select the “New†button from below
20: Find the folder with your WAV files.
21: Select, drag and drop files you want burned
22: Click the Burn Button from the toolbar.
You're done!
Stick it into your PWD and prepare yourself for a listening experience of a lifetime!
