Skip to product information
Silver
href="/products/stellar-strata-mk2-refurbished?variant=49560670044450" class="link" >Stellar Strata MK2 - Factory Certified
The new Stellar™ Strata MK2™ combines the benefits of an exceptional analog preamplifier, a full-featured state-of-the-art DAC, a stereo 150-watt per channel power amplifier, and an amazing sounding MC/MM phono stage in one gorgeous package.
Strata MK2's fully balanced analog preamplifier circuitry, state-of-the-art DAC, no compromise high-definition phono stage, and MOSFET based power amplifier create an extraordinarily rich, full-bodied musical experience few products can match.
The Stellar Strata MK2 is the perfect foundation for those unwilling to compromise sound quality. <strong>Rich. Lush. Powerful.</strong> A music lover's answer to spiraling cost-no-object equipment without sacrifice.
Note:
Sale price  $1,899.00 Regular price  $3,499.00
Factory Certified 14-Day In-Home Evaluation Click for details
Call
TALK TO A HI-FI SPECIALIST
Design
The idea of combining a cutting-edge DAC, full-featured analog preamplifier, high-definition MC/MM phono preamplifier, and a robust 150-watt per channel power amplifier was the basis of the Stellar Strata™ design imperative. We wanted an easy, simple, no-compromise musical experience, whether playing from a connected transport or tracking amazing vinyl. "Just add speakers" became engineering's rallying cry. Strata MK2 holds true to its promise of audiophile plug-and-play. Connect your speakers or headphones, press play, or lower the needle onto your vinyl, and music filled with the rich textures and toe-tapping energy you've always hoped for will delight even the most critical music lover.
Applications
Audiophiles have long recognized the challenge of interconnecting multiple systems into a single synergistic musical experience. Interconnect choices, power supply options, and chassis isolation requirements all play into the building of a truly musical system—get any one part wrong and the system performance is compromised. Not so with Stellar Strata MK2. The chance for PS Engineering to optimize the audio synergy between Strata's four separate systems was immediately appealing: eliminate the variability of interconnection issues, voice the entire system as one component, optimize power supplies, control every aspect of sound quality up to the speakers.
Silver
Overview
At this instrument's heart is a new analog attenuator that elegantly solves the fundamental problem facing preamp designers. Volume control. Nearly all analog preamplifiers use sonically degrading elements inserted in the signal path to control volume. The MKII eliminates this problem by using an all new no-loss analog attenuator in response to front panel controls. Once the connected source has passed through the Class A analog preamplifier, it's time to connect to your speakers. Here, engineer Darren Myers used the Analog Cell where he could lavish upon the music the sweet, tube-like quality of Class A biased MOSFETs. Combined with the ruler flat high linearity of Strata MK2's high current output stage, richly overlayed layers of music’s inner details are preserved even in the most complex orchestral crescendos.
The Inside Scoop
Once the high definition phono stage or connected source has passed through the Class A analog preamplifier, it's time to connect to your speakers. Here, engineer Darren Myers used a new version of our Analog Cell where he could lavish upon the music the sweet, tube-like quality of Class A biased MOSFETs. Combined with the ruler flat high linearity of Strata MK2's high current output stage, richly overlaid layers of music’s inner details are preserved even in the most complex orchestral crescendos. There's nothing like Strata MK2 when it comes to musicality. It's an all-in-one high-resolution audio solution just waiting for you to connect your speakers. Bring it on!
Silver
Silver
Construction
When you first pick up Stellar Strata MK2 Amplifier, you'll notice its solid build and heft. Every inch of Stellar suggests quality: from its rear panel connectors, Darren Myers designed MC/MM phono stage, to its internal high-end power amplifiers. Quality input and output connections, as well as beautifully constructed internals, will offer immediate assurance of quality from the very first moment you pull Strata MK2 out of its box.
Features
12 key features
CLASS A BALANCED ANALOG PREAMPLIFIER
FULL FUNCTION DAC
MC/MM PHONO STAGE INPUTS
CLASS A HEADPHONE AMPLIFIER
150 WATT PER CHANNEL POWER AMPLIFIER
TWO I2S INPUT
FOUR TYPES OF DIGITAL INPUTS
DIGITAL LENS TECHNOLOGY
DSD DIRECT THROUGH I2S
192KHZ ASYNCHRONOUS COAX INPUT
384KHZ ASYNCHRONOUS USB
HIGH CURRENT CLASS A HYBRID OUTPUT STAGE
Reviews
12 reviews
Maxwell Geiger, Audiophilia
The sound of the Strata Mk2 strikes a balance between neutrality and insight, full body and fine detail.
Read full review →
Mark Craven, Hi-Fi News
…its bass performance was eye-opening, to the point it’s easy to imagine you’re listening to bigger, heftier hardware.
Read full review →
Evan Toth, Tracking Angle
What I heard was incredibly balanced and neutral, Elliot Scheiner’s mix shined in all of its glory. In fact, it occurred to me that this presentation would suffice for constructing a mix in the studio: its presentation was honest and full of detail and space.
Read full review →
DavidF, PS Audio Forum (owner comparing with the original Strata)
I’ve used it with my Magnepan LRS+ and KEF R3 Meta’s and both sound better with the Mk2.
Read full review →
Wimek, PS Audio Forum (owner)
I bought a Strata MK2 last January and every time I use it to play music, I’m really happy with this integrated Amplifier.
Read full review →
austinNJ, PS Audio Forum (owner of a Factory Certified Strata MK2)
…the PS Audio allows me to experience classic rock and classical tracks with a smile.
Read full review →
sixpack1, PS Audio Forum (Strata MK2 beta tester)
The phono stage is very quiet and sounds very good.
Read full review →
K. Tager - PS Site
K. Tager - PS Site
I wrote to a audio buddy and said the following: "it is insane the level of sound quality i am getting from a modest integrated and 20 year old speakers (Thiel 3.7's).
Read full review →
PS Audio Forum
Been using mine for a few days now. So far I can say the sound is greatly improved. I’ve used it with my Magnepan LRS+ and KEF R3 Meta’s and both sound better with the Mk2. My REL T/5x subwoofer integrates much better, more seamlessly with my LRS+ speakers than with any other amp I’ve tried. Haven’t tried the phono stage yet but I expect good things.
Read full review →
PS Audio Forum
I swapped out a bunch of gear for the Strata MK2 too, and honestly, the improvement was huge. The sound is way clearer, and the convenience of having everything in one unit is a game changer.
Read full review →
Doug Schroeder - Dagogo
It is stunningly efficacious and will likely result in the best sound you have ever heard in your room regardless of previously used equipment. If your collection of separates is $50K or less, you should try it.
Read full review →
John E. Johnson, Jr.
I have known Paul McGowan, CEO of PS Audio, for many years and have reviewed a number of his products. They always deliver good value for the dollar, and the PS Audio Stellar Strata MK2 Integrated Amplifier is no exception
Read full review →
Want to leave your own review?
Specifications
Technical details
General
 Color Options Black
Silver
Voltage Options Japan 100V (+/-10%)
North America 120V (+/-10%)
Europe/Asia 230V (+/-10%)
Mains Power Input IEC C14
Fuses T250V-250mAH (1/4A Slow Blow)
Accessories Included Remote Control
Line Cord:
- US, JP and EX (NEMA 5-15P)
- Schuko (CEE7/7) (230V version)
- UK (BS1363) (230V version)
- Australia (230V version)
Analog Audio Inputs RCA: 2 stereo pairs
XLR: 1 stereo pair
Phono Inputs MM RCA: 1 stereo pair
MC RCA: 1 stereo pair
Digital Audio Inputs I2S: 2 inputs
- PCM 44.1KHz to 384Khz, DSD64, DSD128, DSD256
Coax: 2 inputs
- PCM 44.1KHz - 192KHz
Optical: 1 input
- PCM 44.1kHZ - 192KHz
USB: 1 input
- PCM 44.1kHZ - 384KHz
- DSD64, DSD128 (native)
- DSD64, DSD128 (DoP)
Audio Outputs RCA (Unbalanced): 1 stereo pair
Headphones: 1 1/4" stereo
Speakers: 2 binding post pairs
Other Trigger Out: 2 3.5mm, 5-15 DVC
USB A: 1 (for firmware update)
Mechanical
 Unit Dimensions 17" w x 2.8" h (not including feet) x 13.5" d (with
connectors and knobs, chassis only is 12")
[43.2cm x 7.1cm x 34.3cm]
Weight 21 lbs [9.5 kg]
Shipping Dimensions 22" w x 8" h x 17" d
[55.9cm x 20.3cm x .4.3cm]
Shipping Weight 25 lbs [11.4 kg]
Environmental
 Location Indoor use only
Storage Temperature -30 to 70C
Operating Temperature 0 to 45C
Features
 Input Selection 9 total: 2 analog, 6 digital, 1 Phono
Volume Control 0-100 (80 dB total range)
Balance Control 12dB each direction in 1/4dB steps
Fixed Volume Mode Analog2: adjustable in setup to any level
Phase Control Digital sources only
Filter Control 3 selectable digital filters (PCM digital sources only)
Input Trim Gain adjustable per input +/-10dB
Headphone Trim Gain adjustable +/-10dB relative to speaker level
Performance
Analog Inputs
 Input Separation >85dB
Input Impedance 47KΩ (unbalanced); 100KΩ (balanced)
Maximum Input Level >16 VRMS
Phono Input
 Cartridge/Type MM MC
Gain 40dB 57dB
Loading 100pF/47kΩ 470pF/100Ω
THD+N .001% @ 5mV input .003% @1mV input
Analog Output
 Output Impedance Line Out 100Ω
Gain Volume=100
6dB +/- 0.5dB
Main (Speaker) Out
 Gain (relative to line output) 30.5dB
Output Power 8Ω, 1KHz, 1% 100W minimum
4Ω, 1KHz, 1% 150W typical
Frequency Response +/-1dB 20Hz – 20KHz
-3dB 7Hz – 40KHz
THD+N 1KHz, 10W/4Ω 0.02%
IMD 18/19KHz -65dB
Speaker Impedance 4Ω minimum
Output Impedance 50Hz 150 mΩ typical
Damping Factor 50Hz, 4Ω 29
Sensitivity @76 1.77 VRMS
@100 450 VRMS
Channel Separation 1KHz >90dB
Headphone Output
 Gain (relative to line output) 16.5dB
Output Power 300Ω, 1KHz, 1%300mW
16Ω, 1KHz, 1% 3.25W
Frequency Response +/-1dB 7Hz – 40KHz
THD 1KHz, 1 VRMS 300Ω <0.02%
                           16Ω <0.02%
S/N Ratio 1KHz >110dB (max output)
Output Noise < -90dBV
Headphone Impedance 8Ω minimum
Output Impedance <4 Ω
Power
 Input Voltage US 108—132VAC (120VAC nominal)
EX/GR/UK/AU 207—253VAC (230VAC nominal)
JP 90—110VAC (100VAC nominal)
Power Consumption Idle 20W
Typical 50W
Maximum 600W
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Recommended products
