Stellar Strata
Stellar Strata
The Stellar™ Strata™ combines the benefits of an exceptional analog preamplifier, a full-featured state-of-the-art DAC, a stereo 150 watt per channel power amplifier, and a high-performance streaming module in one gorgeous package. Strata's fully balanced analog preamplifier circuitry, state-of-the-art DAC, no compromise high-definition streamer, and Analog Cell™ based power amplifier create an extraordinarily rich, full-bodied musical experience few products can match. The Stellar Strata is the perfect foundation for those unwilling to compromise sound quality. Rich. Lush. Powerful. A music lover's answer to spiraling cost-no-object equipment without sacrifice.
Regular price
$1,749.00 USD
Regular price
$3,499.00 USD
Sale price
$1,749.00 USD
Unit price
per
Couldn't load pickup availability
![call](https://cdn.shopify.com/s/files/1/0672/2283/1394/files/phone_1.png?v=1675373886g)
TALK TO A HI-FI SPECIALIST
![Silver](http://www.psaudio.com/cdn/shop/products/Strata-cover.jpg?v=1667322731&width=1445)
![Black](http://www.psaudio.com/cdn/shop/products/8.jpg?v=1675419389&width=1445)
![Silver](http://www.psaudio.com/cdn/shop/products/9.jpg?v=1675419389&width=1445)
![Stellar Strata](http://www.psaudio.com/cdn/shop/products/5.jpg?v=1675419389&width=1445)
![Silver](http://www.psaudio.com/cdn/shop/products/6.jpg?v=1675419389&width=1445)
![Black](http://www.psaudio.com/cdn/shop/products/4.jpg?v=1667322745&width=1445)
![Black](http://www.psaudio.com/cdn/shop/products/1.jpg?v=1667322747&width=1445)
![Black](http://www.psaudio.com/cdn/shop/products/stellar-strata-left-black.jpg?v=1667322749&width=1445)
![#feature_Front Panel](http://www.psaudio.com/cdn/shop/products/Strata-Silver-Front-1700x681.jpg?v=1675358376&width=1445)
![#feature_Rear Panel](http://www.psaudio.com/cdn/shop/products/Stellar-Strata-Rear-silver-2000.jpg?v=1675358376&width=1445)
Design
Application
Technology
![](http://www.psaudio.com/cdn/shop/files/9-768x768.jpg?v=1674748036&width=1500)
![](http://www.psaudio.com/cdn/shop/files/Strata-cover-768x768.jpg?v=1674748059&width=1500)
![](http://www.psaudio.com/cdn/shop/files/Stellar-Strata-right-front-silver-2000-Edit-768x264.jpg?v=1674748088&width=1500)
Features
Specifications - Stellar Strata
Physical |
Unit Weight | 13.5 lbs [6.1 kg] |
Unit Dimensions | 17” x 12” x 3” |
Shipping Weight | 17 lbs [7.7 kg] |
Shipping Dimensions | 23”x 18” x 9” |
Power requirements |
Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
Maximum Power Consumption | 500W |
Mains Power Input | IEC C14 |
Fuses | 100V T250V-2.0AH (5A Slow Blow) 120V T250V-1.6AH (4.5A Slow Blow) 230V T250V-1.0AH (2.5A Slow Blow) |
Accessories included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS1363) (230V version) |
Analog inputs |
RCA | 3 stereo pair |
XLR | 1 stereo pair |
Digital audio inputs |
I2S | 1 PCM (384KHz max) DSD64 DSD128 Compatible with DirectStream Transport SACD handshake for DSD playback |
Coax | 2 PCM (192KHz max) |
Optical | 1 PCM (96KHz max) |
USB | PCM (384KHz max) DSD64 (DoP) DSD128 (DoP) |
Format | PCM, DSD |
Analog Audio Outputs |
RCA | (Analog Unbalanced) 1 stereo pair |
Headphones | One 1/4" headphone connector front panel |
Analog Performance |
Gain | 12dB +/-0.5dB |
Maximum output | 20 Vrms |
Sensitivity | 5.3Vrms |
Input Impedance | 47KΩ single ended RCA 100KΩ Balanced XLR |
Output Impedance | 100Ω single ended RCA 200Ω balanced XLR |
Frequency Response | 20Hz – 20KHz +0/- 0.25dB 10Hz – 100KHz +0.1/-3.0dB |
Noise | 20-20KHz <-90dBV |
S/N Ratio | 1KHz >110dB (max output) |
Channel separation | 1KHz >90dB |
Input separation | 1KHz >90dB |
THD&IM | 1KHz < 0.025% 20-20KHz < 0.05% |
Headphone performance |
Output power @1% THD | 300Ω 300mW 16Ω 3.25W |
S/N Ratio 1kHz Noise |
>95dB (max output) <-80dBV |
THD & IM 1Vrms out | 300Ω <0.05% 16Ω <0.06% |
Output impedance | <4 Ω |
Network |
WiFi | 100 mbps |
Ethernet | 100 mbps |
Power Amplifier |
THD & IM | < 0.02% @ 1KHz, 1W/4Ω < 0.02% @ 10-20KHz, 1W/4Ω < 0.05% (90kHz BW) @ 10-50 KHz, 1W/4Ω < 0.01% @ 1KHz, 37.5W/4Ω |
Output Power | Both channels driven 120vac mains, 1kHz, 1% THD 100W minimum @ 8Ω 150W minimum @ 4Ω Stable for musical transients @ 2Ω |
Features |
Volume Control | 0-100 (1/2 and 1dB steps, 80dB total range) |
Balance Control | 24dB each direction in 1/2dB steps |
Home Theater Mode | Assignable to any analog input Adjustable (in setup) to any level |
Polarity (phase) Control | Digital sources only |
Filter Control | 3 selectable digital filters (PCM digital sources only) |
Trigger output | (3.5mm 5-15VDC) 2 |
Remote Control | Infrared |
Reviews
Power well beyond my needs
The sound is razor sharp. Power well beyond my needs (never thought I ever say that about anything) And the
soundstage… Now my speakers (Klipsch Forte III's) just seem to sit on either side of my bookcase lifeless
while all the sound is clearly coming from my bookcase. Different books even.
- rgcjr60
Reach out and touch the singer
The sound is great. Some songs are so realistic you feel like you can reach out and touch the singer.
- BPfister
Controlled bass, less mushed together
Strata actually seemed a little less bassy but in fact it was more airy, controlled bass, less mushed
together. There was more space and you can tell that we were in a church. From a bass standpoint, different
but a tie. The Strata gives a much better impression of being in a church (reverb?). Also, I noticed a
shocking difference. I was suddenly hearing all the clicking and clacking of the organ pedals. I had never
heard that before. I then heard it (less) on the Exposure/Schiit but only because Strata had revealed it to
me.
- yann.pigeaire
An elegant single box solution that sounds great
An elegant single box solution that sounds great. We have connected the TV via digital cable for a greatly
enhanced experience. And my wife, who loves music but does not take the initiative to use the dedicated
music room, sat down for hours Sunday and played some of her favorite tunes. It was a pleasure seeing her
enjoy it so much, and not needing my assistance to do so.
- chuck929
I realized “that's a subway underneath!”
The DAC is really something. I was just listening to B. Evans Sunday at the Village Vanguard. On Alice in
Wonderland take 1, i hear a faint rumbling sound around 0:20-30 that I had not heard before. On the Exposure
amp I figured it was some club or mike noise. But with the Strata I realized “that's a subway underneath!”.
I would know, I used to live in a big city with subway under my appt. I check on google maps and sure
enough, lines 1/2 pass underneath the club.
- yann.pigeaire
More detail with the strata
I am hearing more detail with the strata, without a total loss of the fullness/body I get from vidar and/or
the tubes.
- renscandi
![](http://www.psaudio.com/cdn/shop/files/audophilia_c0a91262-1dd1-4e93-a336-23df3a089467.jpg?v=1689279852&width=1500)
Track after track, album after album, I got the impression it was
working to show every recording in its best light.
