Aspen FR30 Loudspeaker
Absolute Sound Magazine's Ultra High-End Loudspeaker of the year!
Our goals for the FR30 were to design and build a state-of-the-art full-range loudspeaker with extraordinarily low distortion, effortless reproduction, seamless tonality, and exquisite beauty.
Our highest expectations have been exceeded.
The Aspen FR30 represents the culmination of 50 years of industry experience; learning in intimate detail what works and what does not; what it takes for a loudspeaker to disappear and leave only the magic of the music; designing a no-compromise phase-correct crossover; constructing a cabinet that does not color the sound; crafting a near-flat impedance curve for driving the speakers with any power amplifier, and when not even the most advanced driver manufacturer's products are good enough to meet our exacting standards, designing woofers, radiators, tweeters, and midranges from scratch. In all respects, the FR30 will transcend your expectations of what it means to be called a reference loudspeaker.
No longer do you have to compromise.
Breathtaking to listen to, beautiful to behold. The Aspen FR30.
Regular price
$29,999.00 USD
Regular price
Sale price
$29,999.00 USD
Unit price
per
Couldn't load pickup availability
![call](https://cdn.shopify.com/s/files/1/0672/2283/1394/files/phone_1.png?v=1675373886g)
TALK TO A HI-FI SPECIALIST
![6](http://www.psaudio.com/cdn/shop/products/6_3a09b428-e68b-43b3-ac41-5a80aa493636.jpg?v=1667326376&width=1445)
![Pearl-Home](http://www.psaudio.com/cdn/shop/products/Pearl-Home.jpg?v=1667326368&width=1445)
![Ivory-home-2](http://www.psaudio.com/cdn/shop/products/Ivory-home-2.jpg?v=1667326370&width=1445)
![fr30-black-home-2](http://www.psaudio.com/cdn/shop/products/Sable-home-2.jpg?v=1667326371&width=1445)
![Sable-Home](http://www.psaudio.com/cdn/shop/products/Sable-Home.jpg?v=1667326373&width=1445)
![Aspen FR30 Loudspeaker](http://www.psaudio.com/cdn/shop/products/2.jpg?v=1670722489&width=1445)
![Aspen FR30 Loudspeaker](http://www.psaudio.com/cdn/shop/products/5_cfa49cc9-01b2-4881-931d-15aebb3a15fc.jpg?v=1670722489&width=1445)
![7](http://www.psaudio.com/cdn/shop/products/7.jpg?v=1670722489&width=1445)
![1](http://www.psaudio.com/cdn/shop/products/1_24b3999e-687a-46d5-a974-30f824ae294a.jpg?v=1670722489&width=1445)
![3](http://www.psaudio.com/cdn/shop/products/3.jpg?v=1670722489&width=1445)
![4](http://www.psaudio.com/cdn/shop/products/4_289a1f83-f17d-468e-ad52-d90b1f30799a.jpg?v=1667326390&width=1445)
![#feature_Pearl White](http://www.psaudio.com/cdn/shop/products/White-683x1024.jpg?v=1675360443&width=1445)
![#feature_Sable Black](http://www.psaudio.com/cdn/shop/products/Black.jpg?v=1675360443&width=1445)
Literally Nothing Like It
If you want to make uniquely beautiful art, you have to start by creating your own paints. That’s why for the FR30’s, the decision to custom build every component was an easy one. The result is something that is truly a one-of-a-kind listening experience.
Design
Application
Technology
![](http://www.psaudio.com/cdn/shop/files/Tech-1_86ba6669-8b4a-4f24-974c-bc0d4337461d.jpg?v=1674750575&width=1500)
![](http://www.psaudio.com/cdn/shop/files/Drivers.jpg?v=1674750598&width=1500)
![](http://www.psaudio.com/cdn/shop/files/Enclosure.jpg?v=1674750612&width=1500)
Features
Specifications - Aspen FR30 Loudspeaker
Color Options | Pearl White, Sable Black |
Enclosure Type | Two piece – Sealed upper cabinet mid-tweeter module, Passive radiator lower cabinet (4 10” side-firing passive radiators) |
High Frequency Transducer | 2 x 2.5” planar magnetic with Teonex diaphragm |
Mid Frequency Transducer | 10” planar magnetic with Teonex diaphragm |
Low Frequency Transducer | 4 x 8” woofers, cast frame, aluminum cone, 12lb advanced magnet structure |
Crossover Frequency | 400 Hz, 2500 Hz – LR4 |
Sensitivity (2.83V @ 1M) | 88 dB |
Nominal Impedance | 4 ohm (3.6 ohm minimum impedance) |
Recommended Amplifier Power | 100-600W |
Frequency Response | 23Hz-20kHz (-6dB) half space, 20 Hz (-6dB) in-room |
Dimensions (HxWxD) | 60.5” x 16” x 25.75” with base (10” width not including base) |
Net Weight | 230 lbs (104.5 kg) |
Reviews
Really amazing speakers
I have to say, that was the most beautiful sounding room at the whole event. The PS Audio FR30 were filling
that big room perfectly, full, precise, never bright, great imaging. Really amazing speakers for 30k. At the
same event there were even more expensive speakers, some were ok, some pretty bad. Some were so bright and
sibilant that I couldn't stay in the room more than 10 seconds!
- Simo
They sound just as elegant as they look!
Absolutely amazing, they sound just as elegant as they look!
- Vince Boyce
WTF?
I just heard the FR 30 at the excellent Mala Audio here in Norway, and my jaw dropped. It was one of those
“WTF is that?” moments, pardon my french. The way those speakers grabbed your attention was something else.
Probably the most impressive speakers I have heard, also compared to much more expensive offerings. They
didn't seem to be super dependent on room treatment either to sound good since the room they played in
weren't treated much yet - but it was a fairly large room. Though they looked a bit too big for my listening
room, especially being in Europe where our listening rooms/houses are a bit smaller compared to the US
typically, so I am hopefully looking forward to try out the FR20s. I usually don't buy into hyperbole but
well done Chris, Paul and rest of the PS Audio team. I hope you continue to bring out products down the line
so many people can enjoy your offerings.
- Bjournar
I haven't heard much that can.....
The stories of the development, and all of the hyperbole that Paul seems to mention about them are
absolutely deserved. These are truly world class speakers, capable of awesome dynamics, completely full
range, detailed, and really disappear in the room. They were revealed delicate details in the middle of a
mix while being powerful at the same time. I haven't heard much that can do what these do, even for 6
figures. Very well done PS audio, congratulations on a great new product!
- Deki
They look even better in real life
I listened to the FR30 for half an hour, playing different tracks, and I can tell you right away that this
is an amazingly good sounding and balanced speaker. All instruments and voices sound very natural, there is
nothing pointing out, and the sound is seamless from bottom to top. When I sat down in front of the speakers
I immediately start listening to the music instead of listening to the gear or any defect in the sound. This
tells me that the design of the speakers is very balanced and natural sounding. Not too much/less bass,
midrange and top was airy and open with no edge. Speakers disappeared and the sound stage was wide and big,
between and outside of the speakers. The system together with the FR30 sounded amazing, it was just like I
had a band playing live in front of me.
- Eral
Very impressive! They were extremely clean sounding with exceptional imaging/soundstaging. Instruments
sounded truly like the real thing. There was a true to life relaxed quality to the sound rather than the
tendency of hyper detailed speakers like Magico to sound a little sterile. They certainly sounded a lot
better than my 20 year old Vandersteen 5s (it would be fun and more appropriate to compare the FR30 to 5A
Carbon or Kento). We even cranked it very loud on one or two tracks, not something I normally do, and there
was no compression or distortion. A good demonstration of the clarity and lack of distortion.
- Pmotz
Absolutely stunning
CONGRATULATIONS!!!
They look absolutely stunning and 'OMG' bass is something you PRAY to come out of a reviewer's mouth!
Congrats.. I imagine this product had a long, meticulous gestation period!
- Mike
Music just explodes out of them
They are also remarkably unfazed by placement and room nodes. They just don't seem to interact or excite a
room at all, almost as if they exist in their own void. I've played around with a lot speakers around this
price point and only the very best designs are able to achieve this.
The other thing that amazes me is the way they untangle complex strands of music, enabling the listener to
focus in on individual lines, whilst still maintaining the overall coherency of a musical piece.
They are not in any way “boxy”. Music just explodes out of them way beyond the confines of the box and they
are very “tuneful”.
- M.K.
![](http://www.psaudio.com/cdn/shop/files/Absolute_Sound_26c9dd36-4155-4aae-bffe-77894ae4e3c9.jpg?v=1689279944&width=1500)
I tend to be a bit hypercritical in evaluating anything I consider for purchase. The FR30, did more than live up to my hopes, however, and one way to sum up is to state that I'm buying my review pair as another set of reference speakers. The FR30 is truly outstanding, highly recommended, and well worth the set-up effort necessary to make it perform at its best!
The Absolute Sound
Anthony H. Cordesman
![](http://www.psaudio.com/cdn/shop/files/soundstage.jpg?v=1675192473&width=1500)
I consistently heard super-powerful bass, a really rich and robust midrange, smooth highs, and the kind of effortlessness and scale that you get from big speakers with large and/or lots of drivers....I heard no disparity between what the woofers and planar-magnetic drivers were playing......anyone looking for a pair of speakers that are this large and styled in such an unusual way should explore them. I could tell that there was at least the potential that amazing sound could emerge from them.
Soundstage!
Doug Schneider
![](http://www.psaudio.com/cdn/shop/files/stereophile_eccf4e93-6502-4a4b-a9ef-b8b56a94d1fb.jpg?v=1689279968&width=1500)
The Aspens projected an electrically charged soundfield that was big and dimensional, with notes that were bold and fully formed, supple and dynamic. Even the quieter moments seemed to emit an energetic presence, a kind of radiant musical assertiveness. The speakers sounded well balanced across the frequency range. They also balanced power and agility, machismo and finesse, soaring highs and low-end heft.
Stereophile
Robert Schryer
Even if we didn't get to try them in our usual conditions, our visit clearly showed: the PS Audio Aspen FR30 are impressive in practically every aspect. With their elegant design, they have what it takes to conquer a prominent place in the living room, despite their size. Their incredibly natural, dynamic sound then seems to flow effortlessly from the gigantic floor-standing loudspeakers. The nimble magentostats combine their advantages excellently with the powerfully gripping bass section. But it is especially this fullness and energy that she shows every second that you don't find every day.
HiFidelity
Stefan Gawlick
Having read about the development of these speakers literally for years, in various online postings, I was both keen to hear them and also filled with a little trepidation that they'd not live up to expectation. I needn't have worried: it only took a few tracks to realise that the Aspen FR30 is every bit a sensational design and - to cut to the chase - nothing short of one of the high-end bargains of the moment, making some much pricier speakers seem just a little bit silly.
