Thirty times bigger
by Paul McGowan
In yesterday's post, I showed the block diagram of a power amplifier. The drawing detailed the three main structures within an analog power amplifier: input voltage gain stage, output current gain stage, and the power supply.
Today we'll take a brief look at what the jobs of the two gain stage elements are, then delve into details of the blocks tomorrow.
First, a bit of backstory to set the stage. To drive loudspeakers we need voltage and lots of it. Presenting a voltage across the speaker's binding post excites the speaker's drivers to move and we hear music. The drivers move with voltage because it generates a magnetic field in the speaker's voice coil. The voice coil is affixed to the speaker's cone and is pushed and pulled away from and towards the permanent magnet of the speaker. But it is voltage that moves speaker drivers. As a quick reference, we need 40 volts across a 4Ω woofer of medium efficiency to push it hard and get bass.
So, where does this voltage come from? Certainly not the turntable, CD player, or DAC we might be using for our media. These devices and their associated electronics produce no more than 2 volts. How about a preamplifier? Not much better for voltage. While some preamps can manage upwards of 10 volts at their outputs, more typical is only a few.
We get those higher volts from our power amplifier's first stage. A typical input voltage gain stage of a preamplifier is nothing more than a glorified preamplifier without a volume control. Place 1 volt into this input stage and you get (typically) 30 out. We'll discuss more about this section tomorrow.
Once we have thirty times the voltage we started with from our source or preamp, we have a problem. That higher voltage stays high only into air (high impedance). Try placing that high voltage into a low impedance, like that of a speaker, and it collapses back to near nothingness. This is where the second stage of our power amplifier, the output current gain stage, takes over. Place a voltage into one end of this circuit and the same thing comes out its output, only stronger and unaffected by low impedance.
More tomorrow.
- Opens in a new window.
