The second base run
Prev
The second base run
Sometimes the nicknames we use to speak of technical concepts can be confusing.
For example, an AC wiring home run is not the same as a baseball home run.
In baseball, a home run finds our batter running in a circle from home plate, around the bases, and back again to home plate. A full circle.
In a home audio or video setting, an AC home run wiring technique simply means a dedicated circuit from an AC outlet back to the circuit breaker panel. One cable between circuit breaker and AC outlet.
Technically speaking, it is in fact a home run since the equipment powered at the outlet is actually in the middle of that run: basically, at 2nd base. Which points out another common misconception, that our equipment is at the end of the wire instead of in the middle.
Perhaps it would be better to call a dedicated home run circuit a Second Base run. While it might be confusing at first, a little thought later it'll all make more sense.
Back to blog
Paul McGowan
Founder & CEO
Never miss a post
Subscribe
Related Posts
1 of 2
