Issue 101 • Free Online Magazine
Issue 101 THE COPPER INTERVIEW
John Meyer Interview, Part Three
To recap from Part One (Issue 99) and Part Two (Issue 100): John Meyer is a pioneer in the field of sound reinforcement. Meyer Sound equipment is used by a who’s who of artists, in touring productions like Cirque de Soleil and in concert halls and theaters around the world. Meyer began his professional career in 1967, worked with the Grateful Dead on their famous Wall of Sound and continues to innovate today. John Meyer graciously took the time to share some of his insights with John Seetoo for Copper.
John Seetoo: Let’s talk about the use of alternative materials for loudspeaker drivers. Larry Hartke (of musical instrument amplifier company Hartke) created the first commercial aluminum cone drivers for bass amplifier speaker cabinets; other manufacturers have used Kevlar, polymer and other materials. Meyer Sound still uses paper cones, if I understand correctly. Is that still your preference for sound quality and overall performance or are there other materials that Meyer Sound is planning to put into production?
John Meyer: Well, we’ve done a lot of research on cone materials. We have materials engineers and several chemists on staff. And we’ve tried working with graphite materials and all kinds of things. What we use is treated paper, that is, not just raw paper, like paper towels. Our paper is a highly treated material in terms of stability, treated with minerals and other agents to give us the characteristics we want. Paper has a nice quality in that it’s self-damping.
Metal cones tend to break up into [unwanted distortion] modes. On the other hand, a lot of people like aluminum domes on the front of speakers because they would break up and create the harmonics typical of a guitar amp speaker.
You have to be very careful with metals because they’re very brittle and they can make a lot of noise — additional noise [not present in the original signal]. Which may be what someone’s looking for if it’s a guitar speaker. Also, the paper we developed is very robust. Paper is really designed to bend, the fibers are designed to flex and will last a long time when properly treated for weather protection, and treated so bugs won’t eat it.
We’re always looking at materials, but so far, paper has turned out to be very beneficial. It doesn’t seem very “techie” to most people because it’s so common, but cellulose is the basis of some very high-tech materials, not just for loudspeaker drivers but in more and more other applications as we discover new ways of working with it.
JS: What do you think was the most frustrating and challenging sound reinforcement problem that Meyer Sound has ever faced, and how did you finally resolve it?
JM: I think that the hardest problem we had was to try and get the sound [of our loudspeakers] to project hundreds of meters out and not be broken up and affected by wind noise. I think we spent five years working on our LEO flagship line array system, experimenting with it, building newer types of horns to try and make sure that the sound was smooth out there in the far field. That was an unknown challenge for us.
We weren’t certain we could even find a solution. Some things are open-ended. You can put a lot of work into it a problem and not find an answer. So that was really exciting because in the end it gave us the results we wanted, and it in our opinion and that of others, the LEO still holds up today as the best far-throw speaker out there.
JS: On that same theme: you have worked with countless artists like Metallica, Ed Sheeran, Steve Miller and many others, as well as theatrical productions like Cirque De Soleil and Broadway hit shows. Are there any particular artists or shows that you recall as anticipating to be problematic, only to be surprised at the end result? Conversely, any that you thought would be a cinch only to become stumped due to logistics, rigging, politics or other circumstances that forced you to make less than optimal compromises or that you would do differently now?
JM: All shows are very demanding. This is an artist’s life’s work we’re dealing with. If they go on the stage and they don’t do well for whatever reason, it’s not a great scene. There’s a lot at stake.
One of the expressions we use is that you don’t think about anything else when you’re doing these shows. From when you’re starting to load in until you load out, there’s very little thinking about politics or anything extraneous. These are complicated shows and demand total attention. There are hundreds and hundreds and hundreds of elements, from the video to the bathrooms, everything required to make the experience work. So these are high stress shows, especially for the artists. And what about the fans out there? Are they in a good mood? Or are they in a bad mood because parking was bad, or something else? There are an endless amount of little details that make these shows what they are from a production perspective. All artists get a little bit stressed with so much at stake.
JS: Congratulations on Meyer Sound Labs’ 40th anniversary. Retrospectively, what do you think your top three achievements have been and that you are most proud of, and what do you see as the company’s direction for the next two decades?
JM: Well I think in the beginning building the HD-1 loudspeaker was a real monument because it demonstrated that we could build a speaker that had linear phase [response] – which was really exciting because that had not been achieved up to that point. The HD-1 was very well behaved and the numbers showed it. Then, our LEO was a really great product, for the reasons I gave earlier.
Today, I think our ULTRA X40 compact point source loudspeaker is really interesting because people think it has a “hi-fi” sound. We put into it everything we’ve learned about how to make high quality sound work for both accurate low-level vocal reproduction and powerful projection, all stuffed in this little box. People love it. We sold far more already than we expected. People recognize that [although it’s compact], they can do shows with it. You can throw the ULTRA X40s and all your stuff in your back of your van and do gigs with them as your mains.
The Meyer Sound ULTRA-X40.
And probably the Bluehorn System is the third. [The Bluehorn System is a full-range powered speaker system with built-in DSP, designed for flat frequency response, phase linearity and sonic transparency. – Ed.] It’s been exciting because that product was basically done to see if we could get phase correction all the way down to 30 Hz, and doing it with high-quality digital processing. I mean, we’re getting over 120 dB of dynamic range, which is really quite an achievement. Bluehorn has definitely become a sonic reference.
The Meyer Bluehorn system in action.
We didn’t accomplish this without hearing from a lot of skeptics. I think some in the industry have a tendency to, when they can’t do something like make [a speaker with] full bandwidth phase correction, simply say, “We’re phase deaf!” We’ve heard kickback from people saying this, so it’s almost like sour grapes. “Well, maybe it doesn’t matter or maybe we’re deaf to it,” they’ll say. It’s always a challenge to achieve something when everyone is telling you, “Why are you doing that? No one’s going to hear it.”
But that’s true in every field. I think they probably made fun of cell phones at first with people out there saying, “this is a joke, no one’s going to buy that thing.” But you have to do the work to find out if something’s viable, and there is risk in the sense that you don’t know if what you’re creating is what anyone wants.
I think we’re going through a period today where people want to try to create more interesting sonic spaces or environments. So we’re going through a lot of what they now call immersive sound. But this is something we’ve been looking at for a long time. We could say that the Cirque du Soleil shows have been immersive – one of the shows even has speakers in the back of the seats.
From my point of view, the most exciting thing that we’ve put together lately is the system at National Sawdust [performance venue in Brooklyn]. Now we’re giving artists a chance, with our Spacemap acoustic processing system, to be able to change the configuration of the sounds in the mix, change the spatial character of the room, change where the sound is, and it all can be scripted. So we’re giving sound back to the artists so that they control it easily. But in order to make immersive sound like this practical, it’s got to be something really easy to use, so it’s also easy to script and control the sonic changes.
The Stage at National Sawdust: Meyer Sound Concert, September 26, 2019.
You know, we’re still in the infancy of this transition. A lot of promises are being made about what can happen [with immersive audio]. I think we’ll work through this until we create a more interesting sound palette from the artist’s point of view. They are the ones that will have to create something new and compelling. Otherwise, it could be just a gimmick.
I remember some hi-fi people, back in the Fifties, who did a big demonstration over at a planetarium with 15 speakers all around the room. It was a kind of experiment where you could move a sound around the room, but where you could only run one sound, like a train. That’s interesting for about 10 seconds and then the audience wants it to do something more.
With immersive sound, we have to remember we’re dealing with humans who have the capacity to can think of anything. So we want to develop things carefully so that we don’t over promise and disappoint people, considering that their imagination might be way ahead of our ability to create things through technology. That’s what science fiction movies show us, that you can think way ahead to imagine all kinds of possibilities. Materializing them is another thing.
More from Issue 101
View All Articles in Issue 101
#226 JJ Murphy’s Sleep Paralysis is a Genre-Bending Musical Journey Through Jazz, Fusion and More by Frank Doris Jan 05, 2026 #226 Stewardship by Consent by B. Jan Montana Jan 05, 2026 #226 Food, Music, and Sensory Experience: An Interview With Professor Jonathan Zearfoss of the Culinary Institute of America by Joe Caplan Jan 05, 2026 #226 Studio Confidential: A Who’s Who of Recording Engineers Tell Their Stories by Frank Doris Jan 05, 2026 #226 Pilot Radio is Reborn, 50 Years Later: Talking With CEO Barak Epstein by Frank Doris Jan 05, 2026 #226 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part One by Rudy Radelic Jan 05, 2026 #226 Capital Audiofest 2025: Must-See Stereo, Part Two by Frank Doris Jan 05, 2026 #226 My Morning Jacket’s Carl Broemel and Tyler Ramsey Collaborate on Their Acoustic Guitar Album, Celestun by Ray Chelstowski Jan 05, 2026 #226 The People Who Make Audio Happen: CanJam SoCal 2025, Part Two by Harris Fogel Jan 05, 2026 #226 How to Play in a Rock Band, 19: Touring Can Make You Crazy, Part One by Frank Doris Jan 05, 2026 #226 Linda Ronstadt Goes Bigger by Wayne Robins Jan 05, 2026 #226 From The Audiophile’s Guide: Active Room Correction and Digital Signal Processing by Paul McGowan Jan 05, 2026 #226 PS Audio in the News by Frank Doris Jan 05, 2026 #226 Back to My Reel-to-Reel Roots, Part 25: Half-Full, Not Empty by Ken Kessler Jan 05, 2026 #226 Happy New Year! by Frank Doris Jan 05, 2026 #226 Turn It Down! by Peter Xeni Jan 05, 2026 #226 Ghost Riders by James Schrimpf Jan 05, 2026 #226 A Factory Tour of Audio Manufacturer German Physiks by Markus "Marsu" Manthey Jan 04, 2026 #225 Capital Audiofest 2025: Must-See Stereo, Part One by Frank Doris Dec 01, 2025 #225 Otis Taylor and the Electrics Delivers a Powerful Set of Hypnotic Modern Blues by Frank Doris Dec 01, 2025 #225 A Christmas Miracle by B. Jan Montana Dec 01, 2025 #225 T.H.E. Show New York 2025, Part Two: Plenty to See, Hear, and Enjoy by Frank Doris Dec 01, 2025 #225 Underappreciated Artists, Part One: Martin Briley by Rich Isaacs Dec 01, 2025 #225 Rock and Roll is Here to Stay by Wayne Robins Dec 01, 2025 #225 A Lifetime of Holiday Record (and CD) Listening by Rudy Radelic Dec 01, 2025 #225 Little Feat: Not Saying Goodbye, Not Yet by Ray Chelstowski Dec 01, 2025 #225 How to Play in a Rock Band, Part 18: Dealing With Burnout by Frank Doris Dec 01, 2025 #225 The People Who Make Audio Happen: CanJam SoCal 2025 by Harris Fogel Dec 01, 2025 #225 Chicago’s Sonic Sanctuaries: Four Hi‑Fi Listening Bars Channeling the Jazz‑Kissa Spirit by Olivier Meunier-Plante Dec 01, 2025 #225 From The Audiophile’s Guide: Controlling Bass Frequencies Through Membrane Absorbers (and How to Build Your Own) by Paul McGowan Dec 01, 2025 #225 Your Editor’s Tips for Attending Audio Shows by Frank Doris Dec 01, 2025 #225 PS Audio in the News by Frank Doris Dec 01, 2025 #225 Back to My Reel-to-Reel Roots, Part 24 by Ken Kessler Dec 01, 2025 #225 Holiday Music by Frank Doris Dec 01, 2025 #225 Puppy Prognostication by Peter Xeni Dec 01, 2025 #225 How to Post Comments on Copper by Frank Doris Dec 01, 2025 #225 Living Color by Rudy Radelic Dec 01, 2025 #224 T.H.E. Show New York 2025, Part One: A New Beginning by Frank Doris Nov 03, 2025 #224 Fool’s Leap of Faith is the Extraordinary Octave Records Debut from Singer/Songwriter Tyler Burba and Visit by Frank Doris Nov 03, 2025 #224 The Beatles’ “Aeolian Cadences.” What? by Wayne Robins Nov 03, 2025 #224 Persona Non Grata by B. Jan Montana Nov 03, 2025 #224 Talking With Recording Engineer Barry Diament of Soundkeeper Recordings, Part Two by Frank Doris Nov 03, 2025 #224 B Sides, B Movies, and Beware of Zombies by Rudy Radelic Nov 03, 2025 #224 The Burn-In Chronicles: 1,000 Hours to Sonic Salvation by Olivier Meunier-Plante Nov 03, 2025 #224 A Conversation With Mat Weisfeld of VPI Industries by Joe Caplan Nov 03, 2025 #224 Blues-Rocker Kenny Wayne Shepherd Celebrates 30 Years of Ledbetter Heights by Ray Chelstowski Nov 03, 2025 #224 Playing in a Rock Band, 17: When Good Gigs Go Bad, Part Two by Frank Doris Nov 03, 2025
