Factory Certified
Stellar · AC regenerator
Stellar™ PowerPlant 3
New voices, new harmonics and a renewed sense of musicality.
$1,200 $2,999
Options
Buy or audition near you
All dealers
Factory Certified
Tested in Boulder by the people who built it
14-day in-home evaluation. One-year factory warranty when registered. Each unit is fully factory tested in Boulder; some may show light cosmetic blemishes.
Factory Certified units are already priced well below new, so they can't be combined with Trade-Up credit or other discounts.
Designed for sources and small systems
  • Output 300 W · 900 W peak
  • Outlets (US) 6
  • Wall input Standard 15 amp
  • Screen None. Remote control
What reviewers say
What really matters is that it can transform – yes, transform – the sound from source components, DACs and headphone amplifiers. Wow.
HHi-Fi NewsKeith Howard, 2020
The value-priced Stellar PowerPlant 3 is without a peer
FFuture AudiophileBob Barrett, 2023
The PS Audio Stellar Power Plant 3 delivers an immediate and easily noticeable improvement in overall sound quality.
HHome Theater ReviewDylan Seeger, 2019
Why choose it
Regenerated power, sized for your sources
300 watts of continuous regenerated power, 900 watts peak, for sources and small systems. Six outlets, and overbuilt surge and spike protection.
Where it fits
The P3 is the perfect companion for improving system performance and ensuring a safe environment for you Hi-Fi system. Providing 300 watts of continuous power output and peaks of 1000 watts, the P3 is just right for source gear or an entire systems running small to medium class AB amps or larger high-efficiency Class D amps like the Stellar M700 monoblocks. The P3 will bring forth all that's possible from your HiFi system, ensuring you get the same great performance every time you listen.
Design
How it's built
The Stellar P3 PowerPlant features an ultra-low impedance analog AC power amplifier, pure DSD FPGA based analog sine wave regenerator, and low distortion high-dynamic-peak-capable outputs found only in PS Audio PowerPlants. Designed with elegant simplicity in mind, the P3 is a plug and play device that will provide you with perfect power and worry free protection from surges, spikes, and ugly power without any fuss.
Read the full design story
The Stellar P3 PowerPlant features an ultra-low impedance analog AC power amplifier, pure DSD FPGA based analog sine wave regenerator, and low distortion high-dynamic-peak-capable outputs found only in PS Audio PowerPlants. Designed with elegant simplicity in mind, the P3 is a plug and play device that will provide you with perfect power and worry free protection from surges, spikes, and ugly power without any fuss. Regulate, remove distortion, and get better performance.
300 W
continuous
900 W
peak
6
US outlets
3x
lower impedance than the P5
01
Overview
The Stellar P3 PowerPlant takes your incoming AC power and converts it to DC, similar to what comes out of a battery, and then, with patented PS Audio technology, regenerates and produces new sine-wave-perfect, regulated, high-current AC power. In the process of regeneration, any problems commonly found on your power line, such as low voltage, distorted waveforms, sagging power, flat-topping, and noise are eliminated.
Read more
The Stellar P3 PowerPlant takes your incoming AC power and converts it to DC, similar to what comes out of a battery, and then, with patented PS Audio technology, regenerates and produces new sine-wave-perfect, regulated, high-current AC power. In the process of regeneration, any problems commonly found on your power line, such as low voltage, distorted waveforms, sagging power, flat-topping, and noise are eliminated. The input voltage to the PowerPlant is fully protected by state-of-the-art clamping devices and the output is fully regulated so even large voltage swings that would normally damage connected equipment are made safe by either clamping or regulating. With your system powered directly from the ouput of the Stellar P3, dynamics and openness are breathtaking. New voices, new harmonics, and a renewed sense of musicality are yours the moment the P3 starts up.This is one of the most important pieces of audio equipment you can own, building a firm and reliable foundation for your system that will serve you for years to come. Not suited for class A or A/B amplification in 220V models.
02
Output
The P3 takes in your home's noisy, distorted, and unregulated AC and outputs pure and perfect power that dramatically enhances sound quality. It does this by rebuilding the AC, lowering output impedance, and regulating the voltage.
Read more
The P3 takes in your home's noisy, distorted, and unregulated AC and outputs pure and perfect power that dramatically enhances sound quality. It does this by rebuilding the AC, lowering output impedance, and regulating the voltage. Low output impedance is critical to maintaining a dynamic presentation. Powering equipment through a passive power conditioner only worsens the problem and should be avoided. The Power Plant, on the other hand, has such low output impedance (0.008Ω vs. typical 0.4Ω) that even the hungriest of amplifiers won’t be starved for clean AC power. When your amp is asked to produce loud orchestral levels, you want to make sure it has all the power it needs and only a Power Plant provides a constant output regardless of the dynamic demands of equipment or your neighbors. Power Plants also generate new waveforms that enhance the capabilities of your equipment. MultiWave extends the peak charging time of the sine wave so connected equipment has more energy storage and less power supply ripple. The results are dramatic: a bigger more musically accurate soundstage than with a simple sine wave.
03
Protection
An electrical surge, or spiked transient, is an intense, short-duration voltage increase that travels through electrical wiring in our homes. It can severely damage connected equipment.
Read more
An electrical surge, or spiked transient, is an intense, short-duration voltage increase that travels through electrical wiring in our homes. It can severely damage connected equipment. Shielding devices from these potential electrical problems is mandatory if we're to protect our investment and ensure the safety of our homes. These electrical transients are not the only potentially damaging problems faced by our sensitive audio systems. There are also sustained over-voltage conditions that many surge suppression devices will not be able to protect equipment from. Owners who have invested in a Power Plant can rest assured their connected equipment will be safe from any power line event such as over voltage, under voltage, surges, spikes and potentially threatening problems. The input voltage to the Power Plant is fully protected by state-of-the-art clamping devices and the output of the Power Plant is fully regulated so even large voltage swings that would normally damage connected equipment are made safe by either clamping or regulating. In most cases, connected equipment enjoys the protection and performance benefits of fully regulated power, even under extreme circumstances.
Features
At a glance
  • Built in boulder
  • 300 watts continuous output
  • 500 watts short-term output
  • 900 watts peak output
  • 1000 watts filtered output
  • 3x lower impedence than p5 power plant
  • 6x outlets US
  • 15amp AC input US
  • Range 95 – 145 vac US
  • 4 eu/au/gr/uk outlets
  • 10amp AC input eu/au/gr/uk
  • 230 volt regulated eu/au/gr/uk
  • Range 200 –285vac eu/au/gr/uk
  • 100% regenerated AC
Specifications
Full specifications
Environment SpecificationU.S./Japan / Europe/Asia
LocationIndoor use only / Indoor use only
Duty CycleSuitable for continuous operation / Suitable for continuous operation
Moisture SensitivityNot sealed against moisture / Not sealed against moisture
Operating Humidity<80%rh / <80%rh
Storage Temperature-40C to +40C / -40C to +40C
Operating Temperature0C to 40C / 0C to 40C
Electrical Supply Nominal RatingUS - 120V 15A 60Hz JP - 100V 15A 50/60Hz / 230V 10A 50/60Hz
Instrument SpecificationU.S./Japan / Europe/Asia
Unit Dimensions17” W x 12” D x 3.25” H (43cm x 30.48cm x 8.255cm) / 17” W x 12” D x 3.25” H (43cm x 30.48cm x 8.255 cm)
Unit Weight31.4 lbs ( 14.24 kg) / 31.4 lbs ( 14.24 kg)
Shipping Dimensions22” x 17” x 8” (55.88cm x 43.18cm x 20.32cm) / 17” W x 12” D x 3.25” H (43cm x 30.48cm x 8.255 cm)
Shipping Weight39.4 lbs (17.87 kg) / 39.4 lbs (17.87 kg)
Nominal Input VoltageUS - 108 – 145 VAC JP - 85 – 125 VAC / 200 –270 VAC
Maximum Continuous LoadUS - 300VA JP - 300VA / 300VA
Maximum Peak Load (30 seconds)1000VA / 1000VA
Voltage Regulation<0.1% / <0.2%
Typical Output THD<0.3% / <0.3%
Output Impedance<0.008 ohm / <0.008 ohm
Efficiency @ 300VA>85% / >85%
Input Frequency45 – 65 Hz / 45 – 65 Hz
Energy Dissipation680J / 850J
Peak Current Surge60,000A / 60,000A
Max Surge Voltage6,000V / 6,000V
Clamp Level340V / 800V
DC TriggerNone / None
Standby Power Consumption25 Watts / 25 Watts
Compare
How it compares
P3This oneP12P15P20
Price$2,999$5,999$7,999$9,999
PowersSources and small systemsWhole system, medium to large ampsWhole system, more amp headroomWhole system, the largest amps
Output300 W · 900 W peak1,200 VA1,500 VA2,000 VA · 3,600 W peak
Outlets (US)681016
Wall inputStandard 15 ampStandard 15 ampStandard 15 amp15 or 20 amp
ScreenNone. Remote control4.3-inch color touchscreenColor touchscreen7-inch color touchscreen
Reviews
More reviews
DDylan Seeger, Home Theater Review2019
Read the full review
PS Audio has a winner.
If you’re looking for clean power, there is no way to go wrong here.
WWill Wright, Positive Feedback2021
Wow.
KKeith Howard, Hi-Fi News2020
The sonic benefits to the Stellar Power Plant 3 are clear and palpable.
GGary Alan Barker, Headphone Guru2019
I can say it is the single best audio purchase that I’ve ever made…
FForum memberOwner · PS Audio forum · 2020
Read the full post
I hear space around instruments where before there was none.
Music has both energy and ease.
Read the full post
Read all 8 reviews
The soundstage, already great, is wider, taller and deeper and with greater separation between instruments.
FForum memberOwner · PS Audio forum · 2025
Read the full post
BBob Barrett, Future Audiophile2023
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialist
Outside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealer
Skip to product information
Silver
href="/products/stellar-powerplant-3-refurbished?variant=48706125693218" class="link" >Stellar PowerPlant 3 - Factory Certified
<strong>Our most affordable AC regenerator, the P3 protects, purifies, and powers sources, as well as small to medium sized systems.</strong>
The Stellar Power Plant 3 stands on the shoulders of giants. Built as an evolution from our renowned P12, P15, and P20 the P3 is our most affordable regenerator – perfect for powering sources and small to medium systems.
Power Plants generate sine-wave-perfect, regulated, high current AC power from your home’s AC. Problems on your power line such as low voltage, distorted waveforms, sagging power, and noise are eliminated and the power quality enhanced.
The Stellar P3 PowerPlant provides greatly improved performance and safety from just plugging into the wall socket, along with far better dynamics, more authoritative bass, and a much bigger, more open soundstage than any passive power conditioner on the market.
Note:
Sale price  $1,200.00 Regular price  $2,999.00
Factory Certified 14-Day In-Home Evaluation Click for details
What Factory Certified means
These are PS Audio units that have come home to our factory in Boulder — trade-ins, demos, and returns — not off-the-shelf new production. Each one is fully tested on the same benches we use for new gear: performance, safety, and reliability before it ships again.
  • 14-day in-home evaluation — live with it in your own system before you decide.
  • One-year factory warranty from your purchase date when you register the serial (new products carry three years).
  • Honest cosmetics — function and measured performance meet factory standards; some units may show light blemishes.
Full Factory Certified warranty and evaluation terms
Overview
Output
Protection
What owners and reviewers say
Dylan Seeger, Home Theater Review · Read full review
PS Audio has a winner. If you’re looking for clean power, there is no way to go wrong here.
Will Wright, Positive Feedback · Read full review
Keith Howard, Hi-Fi News · Read full review
Gary Alan Barker, Headphone Guru · Read full review
Scott (scott.rex), PS Audio Forum (owner) · Read full review
I hear space around instruments where before there was none. Music has both energy and ease.
cxp, PS Audio Forum (owner) · Read full review
Nick (Palouse), PS Audio Forum (owner) · Read full review
Bob Barrett, Future Audiophile · Read full review
This is not the 30-day new-product trial — it is the Factory Certified evaluation period. How it works, or read the full warranty and returns policy.
Not for sale
We build these in Boulder, Colorado, and we are glad to show our work. Paul answers questions on video most weekdays, and the factory is open to visitors.
At home
Where it disappears into the music.
14-day in-home evaluation $1,200.00
Add to cart
Call
TALK TO A HI-FI SPECIALIST
Design
Applications
Overview
Output
Protection
Features
20 key features
BUILT IN BOULDER
300 WATTS CONTINUOUS OUTPUT
500 WATTS SHORT-TERM OUTPUT
900 WATTS PEAK OUTPUT
1000 WATTS FILTERED OUTPUT
3x LOWER IMPEDENCE THAN P5 POWER PLANT
6x OUTLETS US
15AMP AC INPUT US
RANGE 95 – 145 VAC US
4 EU/AU/GR/UK OUTLETS
10AMP AC INPUT EU/AU/GR/UK
230 VOLT REGULATED EU/AU/GR/UK
RANGE 200 –285VAC EU/AU/GR/UK
100% REGENERATED AC
MULTIWAVE
CLEANWAVE
PURE SINE WAVE
REMOTE CONTROL
48 LBS.
17W x 4H x 14D
Reviews
8 reviews
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →
Read full review →
Want to leave your own review?
Specifications
Technical details
U.S./Japan
Europe/Asia
Location Indoor use only Indoor use only
Duty Cycle Suitable for continuous operation Suitable for continuous operation
Moisture Sensitivity Not sealed against moisture Not sealed against moisture
Operating Humidity <80%rh <80%rh
Storage Temperature -40C to +40C -40C to +40C
Operating Temperature 0C to 40C 0C to 40C
Electrical Supply Nominal Rating US - 120V 15A 60Hz
230V 10A 50/60Hz
U.S./Japan
Europe/Asia
Unit Dimensions 17” W x 12” D x 3.25” H (43cm x 30.48cm x 8.255cm) 17” W x 12” D x 3.25” H (43cm x 30.48cm x 8.255 cm)
Unit Weight 31.4 lbs ( 14.24 kg) 31.4 lbs ( 14.24 kg)
Shipping Dimensions 22” x 17” x 8” (55.88cm x 43.18cm x 20.32cm) 17” W x 12” D x 3.25” H (43cm x 30.48cm x 8.255 cm)
Shipping Weight 39.4 lbs (17.87 kg) 39.4 lbs (17.87 kg)
Nominal Input Voltage US - 108 – 145 VAC
JP - 85 – 125 VAC
200 –270 VAC
Maximum Continuous Load US - 300VA
JP - 300VA
300VA
Maximum Peak Load (30 seconds) 1000VA 1000VA
Voltage Regulation <0.1% <0.2%
Typical Output THD <0.3% <0.3%
Output Impedance <0.008 ohm <0.008 ohm
Efficiency @ 300VA >85% >85%
Input Frequency 45 – 65 Hz 45 – 65 Hz
Energy Dissipation 680J 850J
Peak Current Surge 60,000A 60,000A
Max Surge Voltage 6,000V 6,000V
Clamp Level 340V 800V
DC Trigger None None
25 Watts
25 Watts
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Specifications
U.S./Japan
Europe/Asia
230V 10A 50/60Hz
U.S./Japan
Europe/Asia
JP - 85 – 125 VAC
200 –270 VAC
JP - 300VA
300VA
25 Watts
25 Watts
Recommended products
