Accessory · AC outlet
PowerPort Classic
A high-end AV grade outlet that makes a real contribution to your system's performance.
$49
Options
Buy or audition near you
All dealers30-day in-home trial
The PS Audio Home Experience
Try it risk-free for 30 days in your own system. Love it or return it.
- Outside the US? Find your local dealer
Designed for the wall outlet behind your system
- 15 or 20 amp ready
- Isolated ground
- Single or 5-pack
Why choose it
A better outlet behind your system
A custom-built, isolated-ground 15 to 20 amp receptacle, plated in 15 coats of polished nickel. It exceeds hospital grade for grip strength and contact resistance.
Where it fits
Power Port AC receptacles should replace any standard wall outlets connected to your stereo or home theater system. To install a Power Port takes about 10 minutes. Turn off the power to the outlet.
Read more
Power Port AC receptacles should replace any standard wall outlets connected to your stereo or home theater system. To install a Power Port takes about 10 minutes. Turn off the power to the outlet. Remove the cover plate. Remove the two screws affixing the existing receptacle and pull the receptacle out from the box. Using a Phillips screwdriver, simply disconnect the wires from the existing plug and place them on the Power Port. Reverse the removal procedure and you are done. Not only will the Power Port ensure that your system will always be provided with as much power as your listening habits require, but it will also give you peace of mind that your AC wall plug is no longer the weak-link in your power chain.
Design
How it's built
The Power Port contacts are cast from the highest purity non-ferrous material available: pure OFC copper and beryllium to maintain excellent grip. The OFC copper contacts are then plated with a high phosphor electroless nickel coating, free from flux-density and power supply issues. nce the electroless nickel plating has been added to the OFC copper connectors, each Power Port goes through a final step before insertion into the body of the receptacle.
Read the full design story
The Power Port contacts are cast from the highest purity non-ferrous material available: pure OFC copper and beryllium to maintain excellent grip. The OFC copper contacts are then plated with a high phosphor electroless nickel coating, free from flux-density and power supply issues. nce the electroless nickel plating has been added to the OFC copper connectors, each Power Port goes through a final step before insertion into the body of the receptacle. Each contact is hand polished to improve the surface smoothness and hence an increase in surface area and better conductivity. The main body of the Power Port is a UL approved polycarbonate material while the front cover of the Power Port is a glass fiber filled high temperature nylon, both excellent dielectrics.
- 15
- coats of polished nickel
- 15 or 20 A
- ready
01
Overview
You spent a great deal of time, money and personal effort building a great sounding music or home theater setup and in all likelihood, you’re feeding it less than great power. Everything we see and hear in our AV systems starts out as raw AC power.
Read more
You spent a great deal of time, money and personal effort building a great sounding music or home theater setup and in all likelihood, you’re feeding it less than great power. Everything we see and hear in our AV systems starts out as raw AC power. The unrestricted quality of that power has a great deal to do with the performance quality of our systems. Garbage in, garbage out. If you're serious about sound and video quality, replacing your home's cheap brass power receptacles is the first step. The Power Port is among the finest AC receptacles made. Hospital grade, and using high purity copper with 15 coats of polished nicer as conductors, the Power Port is a must have in a high-performance system.
02
What's In Your Walls?
Most every home in the US and Canada has a 15 amp duplex NEMA socket in the wall. Some have 20 amp versions, most have 15 amp varieties, but all are basically the same.
Read more
Most every home in the US and Canada has a 15 amp duplex NEMA socket in the wall. Some have 20 amp versions, most have 15 amp varieties, but all are basically the same. These receptacles are constructed out of low-grade brass with very little care as evidenced in their purchase price of under $1.00. They are very poorly built, have poor grip, lower surface area and tend to build up oxidation "barnacles" on the untreated brass, which hampers connectivity. Poor connectivity and loss of surface area from the contacts interacting with airborne pollution spells audible degradation for audio systems and increased visible noise for video systems.
03
Why AC Receptacles Matter
AC power is the source for everything we see and hear through our media systems. Whether a 2-channel audio setup or a multi-channel home theater, AC power supplies everything needed to bring music and pictures into our homes.
Read more
AC power is the source for everything we see and hear through our media systems. Whether a 2-channel audio setup or a multi-channel home theater, AC power supplies everything needed to bring music and pictures into our homes. The quality of that raw power impacts our system's performance. Just as cables make a difference, so too do the contacts and connectors gluing everything together into a system. The receptacles in our homes are made from cheap brass that will oxidize and over time suffer conductivity issues. These can be helped by constant cleaning, plugging in and out to remove oxidation and airborne pollutants. Or, simple replace with the Power Ports and never worry again.
Features
At a glance
- 15 coats polished nickel
- Improves images
- Easy to install
- Cleans the soundstage
- Open, airy, top end
- Improves mid range bloom
- Will not degrade over time
- Improved connectivity
- Lowers apparent noise floor
- Av grade
Full specifications are not published for this product yet.
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialistOutside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealerHear it in your own room
PowerPort Classic
From $49
- 30-day in-home trialThe PS Audio Home Experience. Love it or return it.
- Talk to a real person800-PSAUDIO, Monday to Friday.
PowerPort Classic
In stock
Design
Application
Overview
Features
11 key features15 COATS POLISHED NICKEL
15 OR 20 AMP READY
IMPROVES IMAGES
EASY TO INSTALL
CLEANS THE SOUNDSTAGE
OPEN, AIRY, TOP END
IMPROVES MID RANGE BLOOM
WILL NOT DEGRADE OVER TIME
IMPROVED CONNECTIVITY
LOWERS APPARENT NOISE FLOOR
AV GRADE
Reviews
0 reviewsNo reviews yet for this product.
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
