M700 Amplifier - Refurbished
The Stellar M700 mono amplifiers are a massively powerful engine capable of effortlessly driving demanding loudspeaker loads to concert levels.
Enjoy an unheard of level of control and command from your loudspeakers with the Stellar M700, one of the most extraordinary under $5,000 power amplifier pair ever crafted. With its mighty 700 watt engine connected to any sized loudspeaker, the M700 monoblocks deliver extraordinarily effortless linear headroom that seems to go on forever. Dynamics like you've rarely experienced before. Slam, control, toe-tapping pacing, and music’s subterranean depths are effortlessly delivered to any loudspeaker from the most efficient to the most demanding. Revel in rich layers of fine, full detail you might have been missing before Stellar. Marvel at the deep, extraordinary, wall-to-wall soundstage. Control your loudspeakers as never before. Effortless. Lush. Stellar.
You have 14 calendar days to audition a Refurbished item from the date you received it. For more information on PS Audio Refurbished units click here.
Regular price
$1,748.00 USD
Regular price
$3,498.00 USD
Sale price
$1,748.00 USD
Unit price
per
TALK TO A HI-FI SPECIALIST
Design
Application
Technology
Features
Specifications - M700 Amplifier
Stellar M700 Mono Amplifier |
Unit Weight | 13 lbs [5.9 kg] (each) |
Unit Dimensions | 17”W x 3”H x 12”D (13"D w/connectors) 17”W x 6”H x 12”D (Stacked) |
Shipping Weight | 16.5 lbs [7.5 kg] (each) |
Shipping Dimensions | 22”W x 8”H x 17”D (each) |
Color Options | Black Silver |
Voltage Options (Factory set only) |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
Mains Power Inputs | IEC C14 |
Idle Power Consumption | 23W |
Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
Speaker Outputs | Copper base nickel plated binding posts (2 pair) |
DC Trigger Input | 3.5mm 5-15VDC |
Warranty | 3 years parts and labor |
Signal |
Gain | 30.5dB +/-0.5dB |
Sensitivity for rated output power | 1.6V |
Noise | 1kHz@700 Watts < -105dB |
Input impedance | Unbalanced 50KΩ Balanced 100KΩ |
Output Impedance | 50Hz, 2.8VRMS <0.007Ω |
Damping factor | 50Hz. 2.8VRMS 8Ω >1100 4Ω >550 |
Frequency Response | 2.8VRMS into 4Ω 10Hz – 20KHz +/- 0.5dB 10Hz – 50KHz +0.1/-3.0dB |
THD&IM |
1KHz, 1W/4Ω | <0.02% |
10-20KHz, 1W/4Ω | <0.02% |
10-50KHz, 1W/4Ω | < 0.05% (90kHz BW) |
1KHz, 87.5W/4Ω | < 0.015% |
Output Power |
120vac mains, 1kHz, 1% THD |
8Ω | 350W minimum |
4Ω | 700W minimum |
2Ω | Stable for musical transients |
