Skip to product information
Silver
href="/products/bhk-signature-preamplifier-refurbished?variant=48716452364578" class="link" >BHK Signature Preamplifier - Factory Certified
Preamplifiers are at the heart of any high-performance music system.
They are the critical controlling interface between our sources of music and our loudspeaker chain. Most preamplifiers do a fine job of control and isolation, but only a rare handful make magic happen.
Add the BHK Signature Preamplifier into your system and suddenly you are enveloped in a wealth of musicality you’ve not yet experienced: deeper, wider, sound staging, improved separation of instruments and voices, subterranean bass, extended highs, and an openness you're unlikely to have experienced without this instrument in the system.
Note:
Discontinued from new production in 2024
Sale price  $3,000.00 Regular price  $6,999.00
Factory Certified 14-Day In-Home Evaluation Click for details
Call
TALK TO A HI-FI SPECIALIST
Design
The BHK Signature Preamplifier features two 12AU7 dual triode vacuum tubes in the input stage that act as a zero feedback balanced input amplification pair. A combination of an input stepped attenuator, built around the highest quality passive components for coarse volume adjustments, coupled with controlling the actual gain of the vacuum tube for finer steps, turned out to be the most sonically transparent level control we have yet heard. Finally, the output stage is a high-bias class A MOSFET design that is unaffected by cable and power amplifier interface challenges.
Applications
Preamplifiers play a critical role in any separates audio system, strategically positioned between sources of music: CD players, phono preamps, DACs, tape recorders and tuners—and your power amplifier—the preamp serves essential roles of control and isolation. The BHK Signature Preamplifier features 5 identical balanced and single ended inputs, and converts all input signals into a balanced signal for the lowest possible distortion, and can be used in a two-channel audio system or as part of a home theater system. The high-bias Class A MOSFET output stage ensures unmatched performance with any cable and amplifier interface.
Overview
The BHK Signature Preamplifier is one of the most remarkable musical instruments in the world. It is the perfect interface between your sources and power amplifier. Designed by Bascom H. King, the BHK Signature distills Bascom’s 50 plus years of high-end audio design experience into a single masterpiece of audio amplification. “This is the best sounding preamplifier I have ever designed or heard,” and that’s saying a lot for a man of Bascom’s experience. Preamplifiers play a critical role in any separates audio system, strategically positioned between sources of music: CD players, phono preamps, DACs, tape recorders and tuners – and your power amplifier – the preamp serves essential roles of control and isolation. Control is simple in concept, but extraordinarily difficult to design in an acoustically transparent manner. Control duties such as input switching, volume, balance, and amplification can place unwanted acoustic thumbprints on the music if not designed with extraordinary care. The challenge in any design is to do as little damage to music’s purity as possible. What our Master Designer, BHK, has built will not only stand the test of time, but represents one of the finest musical instruments ever built to honor the music.
Inside Story
At the heart of any preamplifier are the gain stage that provides the amplification, and the volume control that manages how loud or soft the music plays. Inside the BHK Signature Preamp a pair of hand-selected and matched 12AU7 dual triode vacuum tubes provides the unit’s gain. Volume is controlled by a GainCell controling the actual gain of the vacuum tube. This offers the cleanest, lowest impact gain control in precise, half-dB steps. A massive, high-current transformer feeds the BHK Signature Preamp's power supply, which ensures that the unit can reproduce music with a wide dynamic range, without compression or distortion. Painstaking through-hole construction is used, along with the finest, hand-selected components: PRP resistors, high grade Audiophile capacitors---even the solder was auditioned for the best sound. Nothing was spared in the execution of Bascom King's design. Fully-balanced circuitry with a bandwidth that extends almost to DC on the low end and well above audibility on the high end are responsible for the effortless presentation of music BHK preamplifier owners enjoy. First time listeners remark at how much better-defined the space around instruments and vocals appears; the improvements in sound quality are nothing short of ground breaking. Openness, transparency, increased space around instruments---voices come alive in ways most never thought possible.
The Build
Bascom King has said, “vacuum tubes are simply more convincing and musically accurate than any other input configuration I have ever tried,” and the BHK Signature preamplifier proves his statement. All inputs, whether single-ended or balanced, are converted to a pure balanced signal by the dual triode vacuum tube for lowest distortion, highest linearity performance. Input switching is accomplished through hand-selected double-pole double-throw, gold plated relays that we’ve chosen for their sonic neutrality. The signals, once selected, are passed directly to the revolutionary new multi-stage attenuator controlling both volume and balance. High-performance analog audio products like the BHK Preamp benefit from the use of through-hole discrete parts in the signal path. Hand-selected through-hole PRP resistors, high grade Audiophile capacitors and the finest discrete parts are used throughout the BHK Signature preamplifier. Nothing was spared in its design. Even the solder we use has been auditioned for best sound. Extended signal bandwidth---from below 0.1 Hz to above 100 kHz--- is partly responsible for the effortless presentation of music produced by the BHK preamplifier. A massive power supply with an oversized toroidal transformer, the Class A MOSFET output circuit ensure that the BHK Preamplifier will effortlessly drive any cable or amplifier.
Features
19 key features
ZERO-LOSS VACUUM TUBE INPUT STAGE
12V AND 6V TUBE SWITCH
COUPLED & BALANCED MOSFET OUTPUT STAGE
THROUGH-HOLE CONSTRUCTION
PRP RESISTORS IN SIGNAL PATH
5x RCA SINGLE ENDED INPUTS
5 XLR BALANCED INPUTS
SINGLE ENDED & BALANCED INPUTS
FULLY BALANCED INPUT TO OUTPUT
OVERSIZED POWER TRANSFORMER
BHK DESIGNED MOSFET VOLTAGE REGULATORS
BHK DESIGNED MOSFET HEADPHONE STAGE
REMOTE CONTROL
STANDBY BUTTON FOR VACUUM TUBE STAGE
-3dB > 200kHz
VOLUME & BALANCE THROUGH GAIN & ATTENUATION CONTROL
2x OUTPUT DC CONTROL TRIGGERS
EASY ACCESS TO TUBES FOR CUSTOMIZATION
EACH INPUT CAN BE SET TO HT BYPASS
Reviews
5 reviews
Juan C. Ayllon, Prairie Audio Man Cave
The Signature is the most transparent and neutral of the active preamps, giving added life and expression, but otherwise stepping out of the way of the music. Bottom line, the PS Audio BHK Signature Preamplifier is the ultimate witness to the music: It tells the truth, the whole truth, and nothing but the truth
Read full review →
Dave Clark, Positive Feedback
Synergy and magic. Right now here in our listening room...Way deeper bass, way more open, way less whatever being in the way of our music… way more music. Dynamics… try My Disco's "1991" or anything from Lustmord. Happy times
Read full review →
Karl Sigman, Audiophilia
What the PS Audio BHK Signature Preamplifier brings to the table is a significant achievement. For me, it seals the deal, and I believe it will satisfy audiophiles on both sides of the aisle (digital versus analog, tubes versus solid state), and those in between. Taking into consideration its price, simplicity of use, extraordinary quality of sound, design and features such as an included internal headphone amp, I must honestly say, 'There is no preamp like this preamp'. Very highly recommended
Read full review →
Jim Austin, Stereophile
PS Audio's BHK Signature preamp is one of the finest audio components I've had in my home. It didn't raise the dead, but it could conjure in my listening room the spirits of dead musicians, or fine facsimiles thereof. It didn't solve my problems, but it could sure distract me from them—and, with the right recordings, even trigger catharsis or philosophical insight
Read full review →
Erich Wetzel, Soundstage!
In the BHK Signature preamplifier, Bascom H. King has designed, and PS Audio has built, an outstanding performer. It possesses the top-quality fit and finish that one would expect to get for 999. Its sound was beautiful and alive, re-creating three-dimensional soundstages that were the largest I've heard in my room. Its excellent clarity of sound let me easily decipher even the most complex music, its bass was superbly firm, deep, and controlled, and its treble extension was clear and
Read full review →
Want to leave your own review?
Specifications
Technical details
Physical
Unit Weight 22 lbs [9.97 kg]
Unit Dimensions 17” x 14” x 4” [ 36cm x 43cm x 10cm]
Shipping Weight 31 lbs [14 kg]
Shipping Dimensions 20.5”x 24” x 10” [52cm x 61cm x 25cm]
Power requirements
Input Power Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz
Power Consumption 60W
Audio inputs
Coaxial RCA single ended
XLR Balanced
5
5
Input Impedance
Unbalanced (RCA)
Balanced (XLR)
33KΩ minimum
66KΩ minimum
Sensitivity Unbalanced 1.3V/33KΩ
Balanced 1.3V/66KΩ
Audio Outputs
XLR Balanced
2
2
Analog Audio Output
Output level 4.0 Vrms
Output Impedance <100Ω
Frequency Response
20-20KHz
+/- 0.1dB
THD&IM @ 1KHz (full scale) <0.03%
Bandwidth -3dB 0.1Hz - 200kHz
DC Triggers
+12V 2
Headphone Performance
Output Power
300Ω
16Ω >
>200mW
4.0 Watts
S/N Ratio >90dB (1KHz)
THD & IM 1 volt out <0.02%
Output Impedance <0.5Ω
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Recommended products
