BHK Signature 250 Amplifier
The BHK 250 stereo power amplifier is an industry reference standard for performance—a 250 watt per channel investment grade musical instrument that brings life to music.
The BHK Signature 250 Stereo Power Amplifier culminates one man’s lifelong quest for perfection in power amplification. Bascom H. King’s magnum opus combines a vacuum tube input with a powerful MOSFET output capable of 250/500 watts per channel. When cost-no-object performance is the goal there are a rare handful of power amplifiers capable of transporting listeners into a musical space few are able to enjoy. The BHK Signature 250 is one such amplifier. Lush, gorgeous, powerful, revealing, hand built, perfect. If you are uncomfortable with compromise and seek the finest performance, reliability, and build quality in a single-chassis format, the BHK Signature 250 is a perfect fit.
Regular price
$4,249.00 USD
Regular price
$8,499.00 USD
Sale price
$4,249.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Design
Application
Technology
Features
Specifications - BHK Signature 250 Amplifier
BHK Signature 250 Stereo and BHK Signature 300 Mono |
Unit Weight | 83 lbs [37.6 kg] |
Unit Dimensions | 17.1” x 8.7” x 14” Chassis only. 15" deep including connectors. |
Shipping Weight | 92 lbs [41.7 kg] |
Shipping Dimensions | 21”x 13” x 19” |
Color Options | Black Silver |
Voltage Options Factory set only |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
Mains Power Inputs | IEC C14 |
Fuse Compliment all Countries | 4 - 10 amp fast blow H-Rated 5x20mm Rail Fuses |
Fuse Compliment Mains |
100vac Countries 1 - 2 amp slow blow H-rated 5x20mm 1 - 12 amp slow blow H-rated 5x20mm 120vac Countries 1 - 2 amp slow blow H-rated 5x20mm 1 - 10 amp slow blow H-rated 5x20mm 230vac Countries 1 - 1.6 amp slow blow H-rated 5x20mm 1 - 5 amp slow blow H-rated 5x20mm |
Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
Speaker Outputs Signature 250 | Gold plated copper binding posts (2 pair per channel) |
Speaker Outputs Signature 300 | Gold plated copper binding posts (2 pair) |
Other | DC Trigger Input 3.5mm 5-15VDC |
Warranty | 3 years parts and labor on unit 1 year on vacuum tube |
Power Consumption |
@Ready | 75 Watts |
@Idle | 175 Watts |
@Rated power 8Ω | 850 Watts |
@Rated power 4Ω | 1600 Watts |
Signal |
Gain | 30.5dB +/-0.5dB |
Sensitivity for rated output power of 250 watts into 8Ω | 1.3V |
Noise | 100-20KHz <-85dBV |
Input impedance Signature 250 stereo | Unbalanced 100KΩ Balanced 200KΩ |
Input impedance Signature 300 mono | Unbalanced 50KΩ Balanced 100KΩ |
Output Impedance | 50Hz, 2.8VRMS <0.1Ω |
Frequency Response | @2.8VRMS 10Hz – 20KHz +/- 0.1dB 10Hz – 200KHz +0.1/-3.0dB |
THD&IM |
1KHz, 1W/8Ω | <0.01% |
20-20KHz, 1W/8Ω | <0.1% |
1KHz, 200W/8Ω | < 0.1% (120VAC Mains input) |
1KHz, 400W/4Ω | < 0.1% (120VAC Mains input) |
Signature 250 Stereo Amplifier |
Output Power |
Both channels driven 120vac mains, 1kHz, 1% THD |
8Ω | 250W minimum |
4Ω | 500W minimum |
2Ω | Stable for musical transients |
Signature 300 Mono Amplifier |
Output Power |
8Ω | 300W minimum |
4Ω | 600W minimum |
2Ω | 1000W |
