| Color Options | Pearl White, Sable Black |
| Enclosure Type | Passive radiator (two, 10” side-firing passive radiators) |
| High Frequency Transducer | 2.5” planar magnetic with Teonex diaphragm |
| Mid Frequency Transducer | 10” planar magnetic with Teonex diaphragm |
| Low Frequency Transducer | 2 x 8” woofers, cast frame, carbon fiber Rohacell sandwich cone, 12lb advanced magnet structure |
| Crossover Frequency | 400 Hz, 2500 Hz – Linkwitz-Riley 4th order acoustic |
| Sensitivity (2.83V @ 1M) | 87 dB |
| Nominal Impedance | 4 ohm (3.5 ohm minimum impedance) |
| Recommended Amplifier Power | 50-300W |
| Frequency Response | 23Hz-20kHz (-6dB) half space, 20 Hz (-6dB) in-room |
| Dimensions (HxWxD) | 50.5” x 16” x 18.75″ |
| Net Weight | 133 lbs (60.3 kg) |
Factory Certified
Aspen · Floorstanding loudspeaker
Aspen® FR20
The same 20 Hz bass as the FR30, for medium to large rooms.
Open box
Now including near-mint, open-box Aspen FR20 pairs. These are in pristine condition—fully inspected, sounding incredible.
$17,249 / pair $22,999
Options
Buy or audition near you
All dealersFactory Certified
Tested in Boulder by the people who built it
14-day in-home evaluation. One-year factory warranty when registered.
Factory Certified units are already priced well below new, so they can't be combined with Trade-Up credit or other discounts.
- Outside the US? Find your local dealer
Designed for medium to large rooms
- Size (H × W × D) 50.5" × 16" × 18.75"
- Weight 133 lb each
- Deep bass Down to 20 Hz in-room
- Drivers Ribbon tweeter, 10" ribbon midrange, two 8" woofers
What reviewers say
…these mighty, musical and marvelous speakers set a new benchmark in their sector
The Aspen FR20 are simply excellent speakers that impress in every respect.
The PS Audio Aspen FR20 is for the music lover who has done their homework, knows what they need, and doesn't follow the pack
Why choose it
FR30 bass, in a one-piece cabinet
The same 10-inch ribbon midrange and in-room bass to 20 Hz as the FR30, in a one-piece cabinet that's easier to set up.
Where it fits
Loudspeakers are part of the family. With their presence, they grace our homes and living areas by bringing the joy of music into our lives. Unlike the electronics that drive them, to perform their best most loudspeakers depend on proper placement and optimized room parameters.
Read more
Loudspeakers are part of the family. With their presence, they grace our homes and living areas by bringing the joy of music into our lives. Unlike the electronics that drive them, to perform their best most loudspeakers depend on proper placement and optimized room parameters. The Aspen FR20, however, is designed to more easily fit into any living environment and perform at their best with a minimum of setup hassles and a maximum of options. While the FR20, like all high-performance speakers, appreciates some breathing room between them and the front wall, placement in the room for best performance is a snap. Using the included step-by-step guide and CD, setup, from unboxing to playing music, happens easily in a few short hours.
Design
How it's built
Designing and building a new loudspeaker is both the easiest and hardest engineering challenge in all of high-fidelity. On the one hand, anyone can go online and buy a few drivers and bang together a box to make decent sound.
Read the full design story
Designing and building a new loudspeaker is both the easiest and hardest engineering challenge in all of high-fidelity. On the one hand, anyone can go online and buy a few drivers and bang together a box to make decent sound. On the other hand, the most difficult task in all of high-performance audio is crafting a seamless phase-correct output from two or more driver technologies. Over nearly a century of loudspeaker designs, few models have ever achieved legendary status. The FR20 joins the ranks of a rare handful of true full-range speakers that can honestly cover the frequency range of 28Hz to beyond 20kHz with grace, dynamics, slam, and low distortion. What's captured on the disc is exactly what you'll hear with a greater resolution than most have ever experienced. Grace, beauty, PRaT, power, and a musicality that is rare amongst 6 figure offerings from other manufacturers await owners of the Aspen FR20. That this speaker is financially within reach of many makes it a miracle.
- 20 Hz
- in-room bass (−6 dB)
- 87 dB
- sensitivity
- 4
- 8-inch woofers and 10-inch bass radiators
- 3-way
- full range
01
Overview
By far the most important piece in the HiFi chain is the loudspeaker. If the speaker cannot reproduce what's it is fed from the electronic chain, the missing musical information is forever lost.
Read more
By far the most important piece in the HiFi chain is the loudspeaker. If the speaker cannot reproduce what's it is fed from the electronic chain, the missing musical information is forever lost. To achieve all that music demands, over the years loudspeaker designers have tried to leverage every trick in the book: electrostats for details, conventional drivers for dynamics, planars for transparency, ribbons, domes, horns, open baffles, bipoles, dipoles. The list is endless and the choices and their inevitable sonic compromises daunting. With close to 50 years under our collective belts, we at PS Audio determined to design the perfect loudspeaker. Our strategy would be to combine the best of all possible driver and crossover technologies in a single coherent design. We would call it the FR30 and we would follow it up with a smaller model, the FR20. Both would have unquestioned dynamics. They would be full range and capable of being driven by just about any amplifier. Their high-frequency drivers would have lower mass than the air they were driving and the speed and clarity of the best electrostats. Their midrange driver would be so transparent and uncolored as to be unnoticeable. And our speakers would never be shy when it came to the low end. With the FR20's 4 woofers per pair of speakers supported by 4 high-compliance passive radiators, in-room bass response would be nothing short of legendary.
02
The Drivers
The heart and soul of any loudspeaker are its drivers, the transducers that in response to the amplifier's demands pressurize the air and generate the music. Each driver must be optimized for the task at hand.
Read more
The heart and soul of any loudspeaker are its drivers, the transducers that in response to the amplifier's demands pressurize the air and generate the music. Each driver must be optimized for the task at hand. In the FR20, it quickly became apparent we could not source from even the most advanced driver manufacturers in the world the ultra low-distortion high-dynamic output drivers we would need to build the FR20. We started with our tweeter and midrange for here are the two most difficult drivers to perfect. Moving air at high frequencies without colorations or distortion is a daunting task. On the FR20 we chose to go with a technology that has the speed of an electrostat with the dynamics of a cone. Planar Magnetics. These ultra-low distortion drivers are equally driven with front and rear magnetic structures that offer inherent linearity through symmetrical “push-pull” neodymium motor structures and directly driven ultra-low mass diaphragms with none of the cone or dome breakup, inductance modulation, or hysteresis distortion that plagues traditional drivers. For the low end, we crafted long-throw high-excursion woofers with massive 12-pound motor structures that match the effortlessness and transparency of the planar magnetic drivers. To lower distortion, we employed a unique split magnetic gap and a double faraday ring for low, linear inductance and wide bandwidth, coupled with a single progressive Nomex spider with stitched-in lead wires. The woofer cones are a low-mass PMI foam core with non-woven carbon fiber skins on each side. Lastly, to achieve maximum linearity and extended deep bass extension without the compression and distortion of ports, we designed our own high-compliance passive radiators.
03
The Enclosure
Loudspeakers have an honored place in our homes. They often are the focal point of our living rooms and in that capacity must proudly make a statement of fitting elegance.
Read more
Loudspeakers have an honored place in our homes. They often are the focal point of our living rooms and in that capacity must proudly make a statement of fitting elegance. The Aspen FR20 enclosure design starts with the internal structure necessary for great sound and then lovingly sculpted into a work of art befitting our homes. With industrial design by famed Studio 63, the FR20 stands as a proud sculpture comfortable in almost every decor. Internally, the FR20 is an extensively braced enclosure designed to minimize external vibrations that have the potential of coloring the sound. Externally, the enclosures are lovingly finished with 20 coats of hand-rubbed high-grade “piano gloss” lacquer. While the main body and baffling structure are built with MDF, the sculpted front baffle is formed from a dense, rigid and well-damped high-tech thermoset fiberglass resin composite material with integrated high-frequency acoustic waveguides. The speakers look to be almost floating as its curved bottom rests upon its sturdy aluminum base featuring large milled brass spikes with removable tips and integrated plastic feet for hard surfaces (and to aid in speaker placement). A masterpiece of design and love, crafted by those of us that care deeply about music and its reproduction in the home.
Deep dive
Inside the Aspen FR20 Loudspeaker
How it works, what’s inside and how it measures, for anyone who wants every detail.
Watch
Features
At a glance
- Full range 3-way system
- 87 dB sensitivity
- One 2.5" planar ribbon tweeter
- 10" planar ribbon midrange
- Two 8" low distortion high excursion woofers
- Two 10" low distortion high excursion bass radiators
- Advanced carbon fiber pmi foam composite woofer cones
- Thermoset fiberglass resin front baffles
- Flat impedance curve for easy amplifier load
- Smooth and full off axis response
- In-room bass response to 20 Hz @ −6 dB
- One piece cabinet for easy setup
- Adjustable milled brass feet
- Easy to position for best performance
Specifications
Full specifications
Compare
How it compares
| FR30 | FR20This one | FR10 | FR5 | F12 | |
| Price | $34,999 / pair | $22,999 / pair | $9,999 / pair | From $3,499 / pair | From $2,749 / each |
| Size (H × W × D) | 60.5" × 16" × 25.75" | 50.5" × 16" × 18.75" | 41.5" × 11.75" × 16.25" | 14.5" × 8" × 13" (stand 28.25" tall) | 16.75" × 14.75" × 17.5" |
| Weight | 230 lb each | 133 lb each | 75 lb each | 26.6 lb each | 77 lb each |
| Room | Large rooms | Medium to large rooms | Typical living rooms | Small to medium rooms | Any room. Stackable |
| Deep bass | Down to 20 Hz in-room | Down to 20 Hz in-room | Down to 25 Hz in-room | Down to 30 Hz in-room | Flat to below 20 Hz in-room |
| Drivers | Two ribbon tweeters, 10" ribbon midrange, four 8" woofers | Ribbon tweeter, 10" ribbon midrange, two 8" woofers | Ribbon tweeter, 8" ribbon midrange, two 6.5" woofers | Ribbon tweeter, 6.5" woofer | Sealed 12" driver |
| Amp power | 100–600 W | 50–300 W | 50–200 W | 50–150 W | Built in: 1,000 W |
Build your system
What it pairs with
Amplifiers in its power range (50–300 W)
PMG Signature M400 Monoblocks$17,998 / pairLarge floorstanders, medium to large roomsView detailsAmplifiers in its power range (50–300 W)
PMG Signature S400 Stereo$9,999Floorstanders, typical roomsView detailsReviews
More reviews
I am hearing something close to wheat i heard in the concert hall.
Turning up the volume and with really good recordings the sound is so very much like my memories of what I heard at Lincoln Center.The new equipment ups the ability of the system to a new level. And the PSAudio Aspen speakers, 30s in one...
PS Audio didn’t just dip their toes into loudspeaker design; they aimed for the stars and achieved something remarkable.
these mighty, musical and marvelous speakers set a new benchmark in their sector and, arguably, fix the standard even more ambitious designs now have to beat
A little more reduced, a little less massive, but at least as high a level – that is the definition of successful down-sizing.
Or simply the description of the PS Audio Aspen FR20
High-quality, elegantly designed and easy to set up, they are suitable for listening rooms and living rooms alike. Despite their size, they do not require enormous power, they pack an energetic punch even with smaller amplifiers and always appear controlled. Ultimately, however, it is clearly...
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialistOutside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Aspen FR20 Loudspeaker - Factory Certified
Note:
Price is per pair. Factory Refurbished units
Factory Certified
The perfect size loudspeaker for any room
What Factory Certified means
These are PS Audio units that have come home to our factory in Boulder — trade-ins, demos, and returns — not off-the-shelf new production. Each one is fully tested on the same benches we use for new gear: performance, safety, and reliability before it ships again.
- 14-day in-home evaluation — live with it in your own system before you decide.
- One-year factory warranty from your purchase date when you register the serial (new products carry three years).
- Honest cosmetics — function and measured performance meet factory standards; some units may show light blemishes.
Overview
The Drivers
The Enclosure
What owners and reviewers say
I am hearing something close to wheat i heard in the concert hall. Turning up the volume and with really good recordings the sound is so very much like my memories of what I heard at Lincoln Center.The new equipment ups the ability of the system to a new level. And the PSAudio Aspen speakers, 30s...
A little more reduced, a little less massive, but at least as high a level – that is the definition of successful down-sizing. Or simply the description of the PS Audio Aspen FR20
The Aspen FR20 are simply excellent speakers that impress in every respect. High-quality, elegantly designed and easy to set up, they are suitable for listening rooms and living rooms alike. Despite their size, they do not require enormous power, they pack an energetic punch even with smaller amp...
This is not the 30-day new-product trial — it is the Factory Certified evaluation period. How it works, or read the full warranty and returns policy.
Not for sale
We build these in Boulder, Colorado, and we are glad to show our work. Paul answers questions on video most weekdays, and the factory is open to visitors.
At home
Where it disappears into the music.
Design
Applications
Overview
The Drivers
The Enclosure
Product Videos
Features
16 key featuresFULL RANGE 3-WAY SYSTEM
87 dB SENSITIVITY
ONE 2.5" PLANAR RIBBON TWEETER
10" PLANAR RIBBON MIDRANGE
TWO 8" LOW DISTORTION HIGH EXCURSION WOOFERS
TWO 10" LOW DISTORTION HIGH EXCURSION BASS RADIATORS
ADVANCED CARBON FIBER PMI FOAM COMPOSITE WOOFER CONES
THERMOSET FIBERGLASS RESIN FRONT BAFFLES
FLAT IMPEDANCE CURVE FOR EASY AMPLIFIER LOAD
SMOOTH AND FULL OFF AXIS RESPONSE
IN-ROOM BASS RESPONSE TO 20hz @ -6db
ONE PIECE CABINET FOR EASY SETUP
ADJUSTABLE MILLED BRASS FEET
EASY TO POSITION FOR BEST PERFORMANCE
HEAVY INTERNAL BRACING FOR LOW CABINET VIBRATION
CUSTOM FILM CAPACITORS & PREMIUM AIR-CORE INDUCTORS
Reviews
6 reviewsI am hearing something close to wheat i heard in the concert hall. Turning up the volume and with really good recordings the sound is so very much like my memories of what I heard at Lincoln Center.The new equipment ups the ability of the system to a new level. And the PSAudio Aspen speakers, 30s in one system and 20s in the other are so good that they can easily display the improved signal coming from the new equipment.
Read full review →
Read full review →
Read full review →
Read full review →
The Aspen FR20 are simply excellent speakers that impress in every respect. High-quality, elegantly designed and easy to set up, they are suitable for listening rooms and living rooms alike. Despite their size, they do not require enormous power, they pack an energetic punch even with smaller amplifiers and always appear controlled. Ultimately, however, it is clearly their sound that makes them completely convincing. This level of precision, depth of detail, dynamics and simultaneous long-term
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Specifications
