Issue 135 • Free Online Magazine
Issue 135 Featured
London “Decca” Cartridges: Unique Design, Timeless Quality
Decca cartridges are unique transducers with quite a bit of interesting history behind them, starring with the Decca company itself. From their 1929 beginnings as a British record company and gramophone (phonograph) manufacturer, the company later contributed to the 1940s war effort by developing radar and marine navigation systems. Decca produced records in both Europe and North America and quickly became the second-largest record label in the world, known for technical innovation and advanced recording techniques.
My vintage 1960 copy of the soundtrack album from Spartacus (the original, with Kirk Douglas) is a fine example of their work. The record is impeccable in every way, starting with the jacket and inner booklet. The vinyl record itself is quiet with outstanding dynamics that ebb and flow effortlessly, a lush, silken tonal quality, great soundstage depth, and fine detail with no etchiness in the sound whatsoever. (Decca Records is now part of the Universal Music Group.)
Mythological: the Spartacus soundtrack and the London “Decca” Super Gold cartridge.
This is just a small bit of the colorful history of the Decca company, and if you find the subject interesting I suggest you read some of the many online articles about Decca. Even the origin of the Decca name may surprise you. It is the word “Mecca” with the initial “D” from their trademarked 1914 “Dulcetphone” replacing the M. It was also chosen because “Decca” was found to be easy to pronounce in most languages.
Inner workings of a London “Decca” cartridge.
The Decca cartridge design is as interesting and unique as the company itself. It uses a “positive scanning system” generator design that is comprised of a piece of metal foil with the stylus mounted directly to it. This eliminates a conventional cantilever (and a sonic effect the company called “cantilever haze”) resulting in the shortest possible path from record to electrical signal.  Along with the singular design and the sonic qualities of this cartridge, with its reputation for unrivaled musicality, also came a reputation for having many compromises, such as being unforgiving of dirty record and tracking abilities that fell well behind conventional moving magnet and moving coil designs.
Fast forward several decades and Decca is no longer in the business of manufacturing phono cartridges, the company having been sold in 1989. The cartridge design was licensed to Decca engineer John Wright, a license that is still in effect today. Now sold under the London brand name, “Decca” is often unofficially inserted into product description as the new manufacturer does not have the rights to use the Decca name. Referencing Decca makes the cartridge instantly recognizable to customers familiar with this unique transducer.
The latest London cartridges have been improved with a wider choice of styli and an improved mounting plate. All the cartridges, including the styli, are handmade in London to exacting standards, with the company being particularly proud of their stylus quality and the precise ways they are made and polished. The current London cartridge line-up is distributed by Pro Audio Ltd. of Tower Lakes, Illinois and is comprised of the following models:
Professional (DJ), $1,100
Maroon – Spherical, $950
Maroon DP*, $1,100
Gold – Elliptical, $1,200
Gold DP, $1,400
Super Gold – Line Contact Super, $1,500
Gold DP, $1,600
Jubilee – Line Contact, $3,000
Reference Low-Mass Fine Line, $5,000
*DP = Decapod
Any of the cartridges are available in mono or 78 RPM versions by special order. Re-tipping and servicing is available for all models as well.
As part of this feature I was loaned a London Super Gold cartridge to review and provide an update on a modern version of this classical, historically relevant piece of audio gear. I was most interested in seeing if the mythical status of the Decca cartridge was deserved, in both its positive and negative aspects. I used it with my Technics SL-1200GR feeding a Graham Slee Accession phono preamp. The Super Gold has a strong 5 mV output so no special phono preamp is required, and it tracks at 1.8 grams. The cartridge starts sounding its best after 30 hours of break-in so if you try the cartridge be sure to give it enough time to open up.
The London “Decca” Super Gold cartridge.
The legendary musicality is definitely not a myth. Whether it is the elimination of “cantilever haze,” the unique transducer itself or a combination of the two, there is something special to the sound that is different from other cartridges, analogous to the way that planar speakers are different from speakers with dynamic drivers. It made some of my $800 moving magnet and moving coil cartridges sound almost digital at times, and not good digital at that. Though the difference in price would certainly justify it in sounding so much better, as I mentioned before, there is a difference to the sound that is difficult to quantify.
There is an immediacy and clarity to the music that has to be experienced to be appreciated, along with tonal color and roundness I have never heard from any other musical component or transducer of any kind. Listening to the soundtrack from Breakfast at Tiffany’s featuring the music of Henry Mancini, the percussion had an immediacy and clarity I have never heard on that recording. The strumming at the beginning of “Moon River” had a richness and silken tonality that made took the listening experience to a new level.
The notion that the cartridge is intolerant of less-than-perfect vinyl also has some basis in reality. The qualities that make it so good at extracting music out of the groove make it somewhat unforgiving if your records are not well cared for. It is not unlistenable in these cases, but it seems to make imperfections come to the forefront a bit more than other fine cartridges I have used. If anything, the Decca Super Gold will encourage you to keep up your vinyl as pristine as possible. There is not much clearance between the stylus and the cartridge body so I recommend checking it frequently for dust build-up. The very fine stylus of the Super Gold managed to collect dust from records that were quiet and seemed clean, and if you have any accumulation it will degrade the sound more quickly than with other cartridges. Keep that stylus brush handy!
Tracking was not an issue whatsoever and the 1.8-gram tracking force handled everything I threw at it. I did find the set-up to be somewhat fussy, and if you have an arm with easily-adjustable VTA it will help you get the most out of the cartridge.
If you are looking for something to take your analog system to the next level and are willing to try something different, London Decca cartridges definitely belong on your shopping list. You will not only experience the distinctive and beautiful sound, you will also enjoy the pride that comes with owning something classic, unique and a part of audio history.
Manufacturer’s website:
http://londondeccaaudio.com/
US Distributor:
Pro Audio, Ltd.
111 N. South Dr.
Tower Lakes, IL 60010-1324
847-526-1660
Photos courtesy of Don Lindich.
More from Issue 135
View All Articles in Issue 135
#228 Serita’s Black Rose Duo Shakes Your Soul With a Blend of Funk, Rock, Blues and a Whole Lot More by Frank Doris Mar 02, 2026 #228 Vinyl, A Love Story by Wayne Robins Mar 02, 2026 #228 Thrill Seeker by B. Jan Montana Mar 02, 2026 #228 The Vinyl Beat: Donald Byrd, Bill Evans, Wes Montgomery, Eddie Palmieri and Frank Sinatra by Rudy Radelic Mar 02, 2026 #228 Listening to Prestige: The History of a Vitally Important Jazz Record Label by Frank Doris Mar 02, 2026 #228 How to Play in a Rock Band, 21: Touring With James Lee Stanley by Frank Doris Mar 02, 2026 #228 The NAMM 2026 Show: The Music Industry’s Premier Event by John Volanski Mar 02, 2026 #228 The Earliest Stars of Country Music, Part Two by Jeff Weiner Mar 02, 2026 #228 From The Audiophile's Guide: A Brief History of Stereophonic Sound by Paul McGowan Mar 02, 2026 #228 A Bone to Pick With Streaming Audio by Frank Doris Mar 02, 2026 #228 Blast Off With Bluesman Duke Robillard by Ray Chelstowski Mar 02, 2026 #228 A Visit to the Marten Loudspeaker Factory in Göteborg, Sweden by Ingo Schulz and Sebastian Polcyn Mar 02, 2026 #228 Pure Distortion by Peter Xeni Mar 02, 2026 #228 A Nagra Factory Tour by Markus "Marsu" Manthey Mar 02, 2026 #228 Back to My Reel-to-Reel Roots, Part 27: Noodge and Ye Shall Receive, Part Two by Ken Kessler Mar 02, 2026 #228 PS Audio in the News by PS Audio Staff Mar 02, 2026 #228 90-Degree Stereo by Frank Doris Mar 02, 2026 #228 The Keys to Art by Rich Isaacs Mar 02, 2026 #227 Seth Lewis Gets in the Groove With Take a Look Around: a Tribute to the Meters by Frank Doris Feb 02, 2026 #227 Passport to Sound: May Anwar’s Audio Learning Experience for Young People by Frank Doris Feb 02, 2026 #227 Conjectures on Cosmic Consciousness by B. Jan Montana Feb 02, 2026 #227 The Big Takeover Turns 45 by Wayne Robins Feb 02, 2026 #227 Music and Chocolate: On the Sensory Connection by Joe Caplan Feb 02, 2026 #227 Singer/Songwriter Chris Berardo: Getting Wilder All the Time by Ray Chelstowski Feb 02, 2026 #227 The Earliest Stars of Country Music, Part One by Jeff Weiner Feb 02, 2026 #227 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part Two by Rudy Radelic Feb 02, 2026 #227 How to Play in a Rock Band, 20: On the Road With Blood, Sweat & Tears’ Guitarist Gabe Cummins by Frank Doris Feb 02, 2026 #227 From The Audiophile’s Guide: Audio Specs and Measuring by Paul McGowan Feb 02, 2026 #227 Our Brain is Always Listening by Peter Trübner Feb 02, 2026 #227 PS Audio in the News by PS Audio Staff Feb 02, 2026 #227 The Listening Chair: Sleek Style and Sound From the Luxman L3 by Howard Kneller Feb 02, 2026 #227 The Los Angeles and Orange County Audio Society Celebrates Its 32nd Anniversary, Honoring David and Sheryl Lee Wilson and Bernie Grundman by Harris Fogel Feb 02, 2026 #227 Back to My Reel-to-Reel Roots, Part 26: Half Full – Not Half Empty, Redux by Ken Kessler Feb 02, 2026 #227 That's What Puzzles Us... by Frank Doris Feb 02, 2026 #227 Record-Breaking by Peter Xeni Feb 02, 2026 #227 The Long and Winding Road by B. Jan Montana Feb 02, 2026 #226 JJ Murphy’s Sleep Paralysis is a Genre-Bending Musical Journey Through Jazz, Fusion and More by Frank Doris Jan 05, 2026 #226 Stewardship by Consent by B. Jan Montana Jan 05, 2026 #226 Food, Music, and Sensory Experience: An Interview With Professor Jonathan Zearfoss of the Culinary Institute of America by Joe Caplan Jan 05, 2026 #226 Studio Confidential: A Who’s Who of Recording Engineers Tell Their Stories by Frank Doris Jan 05, 2026 #226 Pilot Radio is Reborn, 50 Years Later: Talking With CEO Barak Epstein by Frank Doris Jan 05, 2026 #226 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part One by Rudy Radelic Jan 05, 2026 #226 Capital Audiofest 2025: Must-See Stereo, Part Two by Frank Doris Jan 05, 2026 #226 My Morning Jacket’s Carl Broemel and Tyler Ramsey Collaborate on Their Acoustic Guitar Album, Celestun by Ray Chelstowski Jan 05, 2026 #226 The People Who Make Audio Happen: CanJam SoCal 2025, Part Two by Harris Fogel Jan 05, 2026 #226 How to Play in a Rock Band, 19: Touring Can Make You Crazy, Part One by Frank Doris Jan 05, 2026 #226 Linda Ronstadt Goes Bigger by Wayne Robins Jan 05, 2026
Maroon DP*, $1,100
Gold DP, $1,400
Gold DP, $1,600
*DP = Decapod
US Distributor:
Pro Audio, Ltd.
111 N. South Dr.
847-526-1660
