We’ve spent a fair amount of time and pixels on the brand Fairchild (part 1 in issue #75, part 2 in issue #76, part 3 in issue #77, and a sidebar/part 4 in issue #82), but there is a lot more yet to be said. Or maybe I’m just obsessive.
Fairchild’s professional products are still highly-regarded and sought-after, 60+ years after their manufacture. Their designs were forward-thinking, and the build quality was what you’d expect from a company that also built airplanes and precision optics. Outside of a few recording studios, they’re seldom seen these days—so when I found a comprehensive piece on a Fairchild pro product, I immediately wanted to add it to this series.
J.I. Agnew is a recording engineer in the U.K., and wizard in all things analog—as you’ll see if you take a look at his website. J.I. undertook the rebuild and voltage conversion of a Fairchild lathe, and has even used it for direct-to-disc recording. What follows is his incredibly detailed account of that process. I think you’ll find it fascinating—but you will need to allow some time to read it! —And oh: the whole “disc” vs. “disk” issue will not be resolved by this article. Just sayin’.
I’m happy to announce that J.I. will soon be writing a column for Copper, beginning with an explanation of the whole mysterious process of how records are made. And now, here’s J.I.’s Fairchild story—Ed.
This project started from a bare bones Fairchild Model 199 disk recording lathe, which was found in Florida back in 2015. It was manufactured by the Fairchild Aerial Camera Corporation in the mid-1930’s in New York, before the relevant patents were issued. It was originally sold to a radio broadcasting facility in Grand Rapids, Michigan, where it saw very heavy use, at least until the 1950’s. At some point it was sold to someone in the East Coast again and from there, made it down south.
It arrived in a fairly sad state and it was clear that it was going to need a lot of work, as most old disk recording equipment does nowadays when sold at a bargain price.
It did not come with a cutter head or any electronics and was missing several parts, such as the original cutter head mounting bracket with the advance ball assembly.
The motor and “drive unit”
Following a thorough cleaning job and ample lubrication, the next challenge was to make it spin at the right speed. It is driven by a hysteresis synchronous AC motor, whose speed depends on the mains frequency of the supply. The motor and gearbox assembly (Fairchild called it the “drive unit”) were designed to run at the correct speed when powered by 60 Hz mains, but because we are located in Europe (50 Hz mains), it ran slow.
The original manual (available on request) noted that a “50 Hz version” of the “drive unit” was available with different gearing, so it would still spin at the correct speed, even though the motor would run slower. But, it proved impossible to find such a unit. Next thought was to machine new gears of the required ratio. The lathe was operated for half an hour at 50 Hz, and it was found that it ran a bit hot, which was to be expected due to the lower frequency. This would unnecessarily reduce its lifespan, so it was decided to leave the gearbox as is and figure out a stable 60 Hz supply. There are many ways to achieve this at low cost, but none of them are suitable for this application. Since the speed of the platter depends on the line frequency, any instability of the line frequency will result in speed instability. Moreover, any deviation from a pure 60 Hz sine wave (harmonics, noise, etc.) will be causing the motor to run hot and produce excessive vibration.
We developed a dead stable and clean 60 Hz supply unit, specifically for running disk recording lathe motors, the Type 191. Problem solved. We designed and assembled a more appropriate and stable wooden furniture for the lathe, and started the search for a cutter head.
Cutter Head Safari
The search yielded an RCA MI-4896 monophonic magnetic cutter head of similar vintage.
It also arrived in a very bad, non-functional state. J. I. Agnew promptly took it apart and rebuilt it, making it functional again.
At this stage, we wanted to do a quick and dirty test run of the whole setup, to see where there problems are and to make a plan of action.
Platter experiments
Height adjusters were installed in the platter to compensate for the lack of flatness. Big improvements, but still far from being as precise as it should be.
Several experiments were then conducted with sandwich-type platter arrangements and a lot was learned in the process about how not to make platters.
In the meantime, we started putting together a chip suction system to be able to cut some grooves.
As you can see, the blank disk is being held down by means of a "puck", which screws onto the spindle. This arrangement is far from ideal, but at least a starting point. We started out cutting plastic blanks to get the system set up without wasting lacquer disks in the process. The chip they produce is a transparent-whitish fluff, betraying the sandwich construction of the blanks, which appears to be solid black at first glance.
The chip suction system needs to be precisely adjusted or it will clog up.
Stylus heating
With this sorted, it was time to try out stylus heating. This should never be attempted before ensuring that the chip suction system is operating reliably. If it fails half-way through the cut, not only is the cut ruined, but the stylus will most likely also end up being ruined. If this should happen with lacquer, it will catch fire so fast, it won’t even be funny.
Weird pattern: Vertical oscillations
Next issue was the vertical oscillations (moire pattern on the disk). This is a very usual problem which is easily solved by means of an adjustable dashpot (which we can supply if required). First we tried an airpot, which sort of worked with the light-weight monophonic head but was not easy to adjust right.
Pitch control system
Then the focus shifted to a more versatile pitch control system, electronically variable, to be able to upgrade to an automatically variable pitch system in the future when the rest of the issues are dealt with.
Upgrade to stereophonic cutter head
The time was finally ripe to upgrade to a stereophonic feedback cutter head, the Caruso Nr. 135! A new head mount was needed, so we designed and built it (we can supply custom cutter head mounts to fit almost any head to any lathe, just ask). The airpot was not adequate for the much heavier Caruso head, so we had to upgrade to an oil dashpot as well.
Gearbox overhaul
Now the tiny details are really starting to show. Bearing noises, clattering sounds, rumble, and so on. Time to get dirty and do a full-on gearbox overhaul. While we are at it, why not also get the lead screw sorted out?
Pitch Control
In original form, the Fairchild Model 199 and the almost identical Model 539 were essentially fixed pitch machines, in that the pitch could not be altered during the cut. The operator had a choice of four pitches, ranging from 96 to 161 LPI, which could be selected by means of changewheels, as in early screw cutting lathes. Changewheels are little gears that can be changed out only when the lathe is not in operation. Once the lathe starts spinning, the pitch is defined by the gear installed. A lever is provided to select between inside-out and outside-in direction of cut and there was a fixed relationship between platter speed and pitch, resulting in highly accurate, constant groove spacing. However, it is possible to fit more music per side if the grooves can be made to come closer to each other during silent passages, and the spacing between them opened up for loud passages. This can be achieved manually with electronic pitch control, or automatically with a suitable pitch automation system. The Fairchild was first converted to manually variable electronic pitch control, and a Pitch13 automation system was eventually installed.
Dashpot
The previously made, enclosed dashpot, proved difficult to adjust, so a new head mount adapter was made, with a built-in oil cylinder, along with a plunger. At first, the plunger was made simple and non-adjustable, but was soon replaced with Type 6022, our standard high performance adjustable plunger. This setup allows the vertical damping to be fine-tuned, an essential feature for cutting stereophonic records, where quality matters.
Platter upgrade
So, with the gearbox running as good as new, the platter was no longer satisfactory. Apart from the warping which made it impossible to true it up to the required level of accuracy, it also suffered from an additional major disadvantage: It was made of cast iron, which interacts with the stray magnetic field of a stereophonic cutter head (monophonic heads have weaker fields so it is usually not much of a problem) and ruins the depth of cut adjustment. Additionally, as mentioned earlier, the puck clamping of the blank disk is really not a good idea if you are trying to do professional work. The obvious choice was to fit a Neumann-style vacuum clamp-down platter, made of a suitable aluminum alloy to very precise dimensional standards (which means flat as can be). We first had to make a sub-platter with height adjusters and a new hollow spindle, to act as an air channel for evacuating the platter. The teeth around the subplatter provide the impulse to a speed/positioning sensor, to interface with automatically variable pitch and electronic speed regulation systems.
