Issue 17 • Free Online Magazine
Issue 17 BACK TO BASICS
Simple Subwoofer Setup
Very few loudspeakers are full range. Yes, nearly all extend higher than we humans can hear, but rarely as low.
Audio setup guru Jim Smith, in his continuing series on Subwoofery, is covering a lot the specific details on why you need a subwoofer and what’s involved in its setup. For the rest of us it’s helpful to start at the beginning, keeping it simple.
Why speakers measure one way and sound another
Though full range loudspeakers may advertise their low frequency response as going down as low as 30Hz or even 20Hz, it is rare they achieve this in your room.
When speaker manufacturers measure the response of their products a microphone is placed a few feet from the speaker (1 meter, to be exact). This close, speakers can produce very low frequencies, but those low notes don’t necessarily reach your listening position—where it counts. So, nearfield measurements of the kind speaker manufacturers rely upon serve marketing and brochures more than listeners. This is one reason most speakers fail to deliver low bass in a typical room.
There are two main reasons for this: too small a woofer to effectively couple the air in your room, and placement. It is to the latter issue we will focus our subwoofer basics column.
Bass reproduces differently in your room
Bass is not consistent within your room. Depending on where your speakers are, compared to where you are, the bass may be very different.  Here’s an experiment you can easily make. Find a track with good bass on it. I like Brian Bromberg’s Wood. It’s an excellent recording and should have deep bass with great presence. As Bromberg is playing, walk around your room and note just how different the strength of bass notes are. Make sure you walk into the corners of the room too. Notice anything? Sure, bass collects up in the corners. You might also notice that in the middle of your room, there’s likely very little bass. Yet, stand near your rear wall, the front wall, the corners, and the bass will be stronger.
Everything we hear is actually sound pressure changes: air pressure that comes in waves. High frequencies have short waves (often measured in increments of an inch) while low frequencies have long waves (often measured in many feet).  A 20Hz bass note is approximately 50 feet long! Air pressure waves of this length bunch up at the boundaries of your room, like walls and corners.
Do you need a subwoofer?
Unless your loudspeaker has a built in subwoofer, chances are excellent your system would benefit from the addition of an aftermarket sub.
Where do you place it?
Our first inclination would be to place the new subwoofer in the same place our existing full range speaker is. That’s typically exactly where you don’t want it to be. And here’s why.
The best place for imaging and mid to high frequency reproduction from a loudspeaker is almost never the best place to make bass. To make matters worse, it’s almost never where you’re sitting, either.
Now that we understand the subwoofer is likely not going to be placed where our speakers are now, the obvious question is, where to place it?
Simple way to place it
Since we know the best bass reproduction in your room is likely not where the speakers are, nor where your listening position is, we have to find the right spot to place our new subwoofer so we get perfect bass in the listening position.
Here’s the trick. Place the subwoofer where your listening chair is, crank up the music, and then walk behind the main loudspeakers until you find where the bass sounds perfect. Bingo!
Now, move the sub into that exact spot, behind the loudspeaker, and when you play music again, bass at your listening position will sound identical.
It’s that easy.
More from Issue 17
View All Articles in Issue 17
#227 Seth Lewis Gets in the Groove With Take a Look Around: a Tribute to the Meters by Frank Doris Feb 02, 2026 #227 Passport to Sound: May Anwar’s Audio Learning Experience for Young People by Frank Doris Feb 02, 2026 #227 Conjectures on Cosmic Consciousness by B. Jan Montana Feb 02, 2026 #227 The Big Takeover Turns 45 by Wayne Robins Feb 02, 2026 #227 Music and Chocolate: On the Sensory Connection by Joe Caplan Feb 02, 2026 #227 Singer/Songwriter Chris Berardo: Getting Wilder All the Time by Ray Chelstowski Feb 02, 2026 #227 The Earliest Stars of Country Music, Part One by Jeff Weiner Feb 02, 2026 #227 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part Two by Rudy Radelic Feb 02, 2026 #227 How to Play in a Rock Band, 20: On the Road With Blood, Sweat & Tears’ Guitarist Gabe Cummins by Frank Doris Feb 02, 2026 #227 From The Audiophile’s Guide: Audio Specs and Measuring by Paul McGowan Feb 02, 2026 #227 Our Brain is Always Listening by Peter Trübner Feb 02, 2026 #227 PS Audio in the News by PS Audio Staff Feb 02, 2026 #227 The Listening Chair: Sleek Style and Sound From the Luxman L3 by Howard Kneller Feb 02, 2026 #227 The Los Angeles and Orange County Audio Society Celebrates Its 32nd Anniversary, Honoring David and Sheryl Lee Wilson and Bernie Grundman by Harris Fogel Feb 02, 2026 #227 Back to My Reel-to-Reel Roots, Part 26: Half Full – Not Half Empty, Redux by Ken Kessler Feb 02, 2026 #227 That's What Puzzles Us... by Frank Doris Feb 02, 2026 #227 Record-Breaking by Peter Xeni Feb 02, 2026 #227 The Long and Winding Road by B. Jan Montana Feb 02, 2026 #226 JJ Murphy’s Sleep Paralysis is a Genre-Bending Musical Journey Through Jazz, Fusion and More by Frank Doris Jan 05, 2026 #226 Stewardship by Consent by B. Jan Montana Jan 05, 2026 #226 Food, Music, and Sensory Experience: An Interview With Professor Jonathan Zearfoss of the Culinary Institute of America by Joe Caplan Jan 05, 2026 #226 Studio Confidential: A Who’s Who of Recording Engineers Tell Their Stories by Frank Doris Jan 05, 2026 #226 Pilot Radio is Reborn, 50 Years Later: Talking With CEO Barak Epstein by Frank Doris Jan 05, 2026 #226 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part One by Rudy Radelic Jan 05, 2026 #226 Capital Audiofest 2025: Must-See Stereo, Part Two by Frank Doris Jan 05, 2026 #226 My Morning Jacket’s Carl Broemel and Tyler Ramsey Collaborate on Their Acoustic Guitar Album, Celestun by Ray Chelstowski Jan 05, 2026 #226 The People Who Make Audio Happen: CanJam SoCal 2025, Part Two by Harris Fogel Jan 05, 2026 #226 How to Play in a Rock Band, 19: Touring Can Make You Crazy, Part One by Frank Doris Jan 05, 2026 #226 Linda Ronstadt Goes Bigger by Wayne Robins Jan 05, 2026 #226 From The Audiophile’s Guide: Active Room Correction and Digital Signal Processing by Paul McGowan Jan 05, 2026 #226 PS Audio in the News by Frank Doris Jan 05, 2026 #226 Back to My Reel-to-Reel Roots, Part 25: Half-Full, Not Empty by Ken Kessler Jan 05, 2026 #226 Happy New Year! by Frank Doris Jan 05, 2026 #226 Turn It Down! by Peter Xeni Jan 05, 2026 #226 Ghost Riders by James Schrimpf Jan 05, 2026 #226 A Factory Tour of Audio Manufacturer German Physiks by Markus "Marsu" Manthey Jan 04, 2026 #225 Capital Audiofest 2025: Must-See Stereo, Part One by Frank Doris Dec 01, 2025 #225 Otis Taylor and the Electrics Delivers a Powerful Set of Hypnotic Modern Blues by Frank Doris Dec 01, 2025 #225 A Christmas Miracle by B. Jan Montana Dec 01, 2025 #225 T.H.E. Show New York 2025, Part Two: Plenty to See, Hear, and Enjoy by Frank Doris Dec 01, 2025 #225 Underappreciated Artists, Part One: Martin Briley by Rich Isaacs Dec 01, 2025 #225 Rock and Roll is Here to Stay by Wayne Robins Dec 01, 2025 #225 A Lifetime of Holiday Record (and CD) Listening by Rudy Radelic Dec 01, 2025 #225 Little Feat: Not Saying Goodbye, Not Yet by Ray Chelstowski Dec 01, 2025 #225 How to Play in a Rock Band, Part 18: Dealing With Burnout by Frank Doris Dec 01, 2025 #225 The People Who Make Audio Happen: CanJam SoCal 2025 by Harris Fogel Dec 01, 2025 #225 Chicago’s Sonic Sanctuaries: Four Hi‑Fi Listening Bars Channeling the Jazz‑Kissa Spirit by Olivier Meunier-Plante Dec 01, 2025
It’s that easy.
