Issue 124 • Free Online Magazine
Issue 124 SOMETHING OLD / SOMETHING NEW
Rediscovering Johannes Ockeghem
Beethoven has enjoyed all kinds of attention in 2020 to celebrate his 250th birthday, but Johannes Ockeghem deserves a birthday party too. He’s turning 600. Never heard of him? Some recent recordings show how this Flemish composer helped create a musical bridge from the Middle Ages into the Renaissance and became one of the most influential musicians of his day.
Full disclosure: The year 1420 is only musicologists’ best guess for Ockeghem’s birth, but close enough. We need more to celebrate in 2020 anyway. Despite holes in his biography, there are some things we know for sure about him. He made a living as a choir singer in Antwerp as a young man before moving to Paris, where he worked for some major cathedrals as well as the royal court.
As a composer, he was famous for his bass voice, which inspired the unprecedented vigor and depth he gave to bass parts in his own compositions. He was trained in the rich-sounding “English style” and applied it to polyphony in both secular and sacred works. He was also at the cutting edge of a trend to combine those two types of compositions, writing so-called cyclic Masses that used pre-existing musical material – a secular song, a Gregorian chant, a motet – as the shared basis for thematically connected Mass movements. He was a close colleague of Guillaume Dufay (whom I wrote about previously in Copper Issue 100 and a major influence on Josquin DesPrez (Watch this space!).
At least one early-music ensemble is determined that Ockeghem get the birthday attention he deserves. Boston-based Blue Heron, under the direction of Scott Metcalfe, put together and toured 13 different Ockeghem programs in their huge Ockeghem@600 Project. Undeterred by COVID-19, they’ve just announced a Zoom lecture series for next spring as part of the festivities (https://www.blueheron.org/concerts/ockeghem-academy/).
Blue Heron’s latest Ockeghem recording is Johannes Ockeghem: Complete Songs, Vol. 1, released on their own label. By “songs,” they mean secular polyphonic vocal works, usually for three or four voices, with French texts.
“S’elle m’amera/Petite camusecte” (“If She Will Love Me/Little Snub-Nose”) is a beautiful example of a secular motet. By the time you get to Bach, the term motet was used only for sacred music, but it started out in the late Middle Ages as quite a different genre. By definition, it had to have at least two texts being sung at the same time, which could be secular (even quite raunchy), sacred, or both simultaneously! This motet is made up of two French love songs, with two voices singing each. Blue Heron, accompanied by bowed and plucked instruments, performs with a fluidity of phrasing sometimes missing from pre-Baroque recordings.
None of these tracks are available on YouTube, but you can hear the entire album and view the lyrics with translation here:
https://blueheron.bandcamp.com/album/johannes-ockeghem-complete-songs-vol-1
Another new recording of Ockeghem’s secular songs can be found on the Musique en Wallonie label. Johannes Ockeghem: Les Chansons is by Cut Circle, an award-winning American ensemble led by Jesse Rodin. The two-disc set contains two dozen songs.
The confident singing is notable for its use of something close to Pythagorean temperament. In brief, this means that the intonation focuses on making perfect intervals (fourth, fifth, octave) exact, which results in thirds and sixths that are slightly larger or smaller than the modern ear is used to. This is, by all accounts, accurate for music of the 16th century and earlier. If you want a little more detail on this topic, you can see a piece I wrote in The New York Times a while back: https://www.nytimes.com/1999/03/14/arts/music-ok-everyone-in-tune-whatever-that-means.html And if you want a lot more information, I recommend the book Temperament by Stuart Isacoff.
Listen to their performance of the three-voice song “Aultre Venus” (“Another Venus”) for a particularly clear example of the perfect-centered intonation. I am not one who assumes that authenticity is the end-all and be-all of early music performance, but this is quite an effective recording.
Ockeghem got extra mileage from his polyphonic secular songs by re-using them as the basis for cyclic Masses. This technique explains why Masses of his and the following generation often have apparently random French words in their titles. (Ockeghem’s Missa Fors seulement, for example, uses material from his song “Fors seulement.”)
Sometimes the cyclic technique is less obvious, as in the Mass commonly known as Missa Mi-Mi. It’s called that because of the melodic motif, appearing in every movement, of E down to A, both using the proto-solfeggio syllables “mi.” But some scholars find evidence that Ockeghem also borrowed material from his song “Presque transi,” so subtly that it takes detective work to find the quotations.
Its sources aside, Missa Mi-Mi is a stunning work, and we’ve been treated to a fine new recording by a group, little known in America, called Beauty Farm. This vocal ensemble, founded in 2014 and recording on the Frabernardo label, is based in Austria. It is made up of six men, all experienced early-music singers, many of whom also work with other groups. Beauty Farm is focused exclusively on the lush polyphonic Franco-Flemish repertoire of Ockeghem’s era.
Beauty Farm’s new Ockeghem Masses, Vol. 2 includes the Missa Mi-Mi plus three other Masses, making it an important contribution to the recordings of this corpus. Vol. 1 came out in 2017. The ensemble has a dense, even sonority, with equally strong singers from bass to countertenor who blend together beautifully. The recording, made in a monastery, rings with the ancient holiness of the surroundings, reverberating at the end of every line. Here is the Gloria from this album:
Any fan of Mozart will know the potential power of a Requiem Mass, but the genre was far from new in Mozart’s time. One that survives by Ockeghem is his Missa pro defunctis (Mass for the Dead). Three of its movements are included on a new recording by Ars Veritas on Centaur Records.
Conductor Jeremy D. Jones also produced this recording made at the Varnhem Cloister Church in Sweden. The album, Old and New Worlds, offers an interesting mix, including several world-premiere compositions by co-director Jakob Patriksson as companion works to the Ockeghem and earlier pieces. The Ars Veritas voices have a less precise, breathier sound than the other groups mentioned above, and sometimes the intonation is questionable. Still, one can imagine that this is closer to what it would have sounded like for cathedral choirs in Ockeghem’s time to sing this music, long before it was possible to get a master’s degree in early-music performance.
Here’s to 600 more years of this beautiful music!
More from Issue 124
View All Articles in Issue 124
#226 JJ Murphy’s Sleep Paralysis is a Genre-Bending Musical Journey Through Jazz, Fusion and More by Frank Doris Jan 05, 2026 #226 Stewardship by Consent by B. Jan Montana Jan 05, 2026 #226 Food, Music, and Sensory Experience: An Interview With Professor Jonathan Zearfoss of the Culinary Institute of America by Joe Caplan Jan 05, 2026 #226 Studio Confidential: A Who’s Who of Recording Engineers Tell Their Stories by Frank Doris Jan 05, 2026 #226 Pilot Radio is Reborn, 50 Years Later: Talking With CEO Barak Epstein by Frank Doris Jan 05, 2026 #226 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part One by Rudy Radelic Jan 05, 2026 #226 Capital Audiofest 2025: Must-See Stereo, Part Two by Frank Doris Jan 05, 2026 #226 My Morning Jacket’s Carl Broemel and Tyler Ramsey Collaborate on Their Acoustic Guitar Album, Celestun by Ray Chelstowski Jan 05, 2026 #226 The People Who Make Audio Happen: CanJam SoCal 2025, Part Two by Harris Fogel Jan 05, 2026 #226 How to Play in a Rock Band, 19: Touring Can Make You Crazy, Part One by Frank Doris Jan 05, 2026 #226 Linda Ronstadt Goes Bigger by Wayne Robins Jan 05, 2026 #226 From The Audiophile’s Guide: Active Room Correction and Digital Signal Processing by Paul McGowan Jan 05, 2026 #226 PS Audio in the News by Frank Doris Jan 05, 2026 #226 Back to My Reel-to-Reel Roots, Part 25: Half-Full, Not Empty by Ken Kessler Jan 05, 2026 #226 Happy New Year! by Frank Doris Jan 05, 2026 #226 Turn It Down! by Peter Xeni Jan 05, 2026 #226 Ghost Riders by James Schrimpf Jan 05, 2026 #226 A Factory Tour of Audio Manufacturer German Physiks by Markus "Marsu" Manthey Jan 04, 2026 #225 Capital Audiofest 2025: Must-See Stereo, Part One by Frank Doris Dec 01, 2025 #225 Otis Taylor and the Electrics Delivers a Powerful Set of Hypnotic Modern Blues by Frank Doris Dec 01, 2025 #225 A Christmas Miracle by B. Jan Montana Dec 01, 2025 #225 T.H.E. Show New York 2025, Part Two: Plenty to See, Hear, and Enjoy by Frank Doris Dec 01, 2025 #225 Underappreciated Artists, Part One: Martin Briley by Rich Isaacs Dec 01, 2025 #225 Rock and Roll is Here to Stay by Wayne Robins Dec 01, 2025 #225 A Lifetime of Holiday Record (and CD) Listening by Rudy Radelic Dec 01, 2025 #225 Little Feat: Not Saying Goodbye, Not Yet by Ray Chelstowski Dec 01, 2025 #225 How to Play in a Rock Band, Part 18: Dealing With Burnout by Frank Doris Dec 01, 2025 #225 The People Who Make Audio Happen: CanJam SoCal 2025 by Harris Fogel Dec 01, 2025 #225 Chicago’s Sonic Sanctuaries: Four Hi‑Fi Listening Bars Channeling the Jazz‑Kissa Spirit by Olivier Meunier-Plante Dec 01, 2025 #225 From The Audiophile’s Guide: Controlling Bass Frequencies Through Membrane Absorbers (and How to Build Your Own) by Paul McGowan Dec 01, 2025 #225 Your Editor’s Tips for Attending Audio Shows by Frank Doris Dec 01, 2025 #225 PS Audio in the News by Frank Doris Dec 01, 2025 #225 Back to My Reel-to-Reel Roots, Part 24 by Ken Kessler Dec 01, 2025 #225 Holiday Music by Frank Doris Dec 01, 2025 #225 Puppy Prognostication by Peter Xeni Dec 01, 2025 #225 How to Post Comments on Copper by Frank Doris Dec 01, 2025 #225 Living Color by Rudy Radelic Dec 01, 2025 #224 T.H.E. Show New York 2025, Part One: A New Beginning by Frank Doris Nov 03, 2025 #224 Fool’s Leap of Faith is the Extraordinary Octave Records Debut from Singer/Songwriter Tyler Burba and Visit by Frank Doris Nov 03, 2025 #224 The Beatles’ “Aeolian Cadences.” What? by Wayne Robins Nov 03, 2025 #224 Persona Non Grata by B. Jan Montana Nov 03, 2025 #224 Talking With Recording Engineer Barry Diament of Soundkeeper Recordings, Part Two by Frank Doris Nov 03, 2025 #224 B Sides, B Movies, and Beware of Zombies by Rudy Radelic Nov 03, 2025 #224 The Burn-In Chronicles: 1,000 Hours to Sonic Salvation by Olivier Meunier-Plante Nov 03, 2025 #224 A Conversation With Mat Weisfeld of VPI Industries by Joe Caplan Nov 03, 2025 #224 Blues-Rocker Kenny Wayne Shepherd Celebrates 30 Years of Ledbetter Heights by Ray Chelstowski Nov 03, 2025 #224 Playing in a Rock Band, 17: When Good Gigs Go Bad, Part Two by Frank Doris Nov 03, 2025
