Issue 101 • Free Online Magazine
Issue 101 REVOLUTIONS PER MINUTE
An Ode to Cassette Tape - Part One
I still remember how, as a very young boy, I had to handle a 7-inch record with both hands and I still could barely manage to put it on the turntable, having to climb up on a chair to reach it. This is how big the 7-inch format was, or how small I was at the time (a question of perspective)! The 12-inch records were far too big for me; I couldn’t even remove them from their sleeve!
I observed in astonishment as my father was holding a 12-inch LP with one hand, four fingers on the label, thumb on the edge, and wondered if I would ever become big enough to do that. Back then, I couldn’t even do that on a 7-inch single!
That sure wasn’t me! I preferred loudspeakers, and I still prefer them to be bigger than me, even nowadays.
Having been taught that records could be easily damaged and were of immense value, I found the experience of handling records rather stressful, because of my small size and clumsy motor skills as a toddler. However, the ensuing auditory experience was so deeply fulfilling that I had decided it was worth the stress and effort of placing the record on the turntable and putting it back in its correct place on the shelf again when I was done. But I still had to wait for dad to come home from work to ask him to put on a 12-inch record.
Luckily, there was another format, which I found much easier to deal with! The CD had not yet arrived and we did not have a reel-to-reel tape machine at home, which is probably for the better, as I would have most likely tangled myself up in knots trying to thread the tape, which would have felt like the equivalent of 8-inch wide tape in my tiny paws back then.
The toddler-friendly format consisted of 1/8-inch wide tape, wound on small reels, packed safely inside a plastic shell! There was no need to touch the actual tape containing the recorded information. Of course, I’m talking about cassette tape, which could be handled entirely by the shell and was small enough for me to confidently hold! As an additional bonus, the cassette deck, a vintage JVC unit, was situated on a low shelf near the floor within easy reach.
JVC cassette deck. Photo courtesy of Magnetic Fidelity.
The fact that cassette tape existed when I was a baby will perhaps give away some hints regarding my age, contrary to what some of my earlier accounts of my experience with antique audio technology may have led readers to believe. The format was introduced by Philips in 1963, but gained popularity in the 1970’s.
Not only was I able to play any of the prerecorded tapes in our collection, but, unlike our Thorens turntable, that same cassette deck could also record on blank cassettes! Both of these activities were deemed safe enough for me to pursue at will, without requiring direct supervision or assistance!
My experiences with cassette tape started when my dad decided to try to record my first words when I was about nine months old. I found the VU meters fascinating and was able to learn how to initiate the recording by simultaneously pressing the Rec and Play keys. Soon after that I learned how to adjust the recording level correctly and things rapidly escalated from there. I was building shoebox guitars with my mom (cutting a hole in a shoebox, putting rubber bands over it and sticking a piece of cardboard under them as a bridge), banging on whatever produced an interesting sound, talking, singing, and recording music from 12-inch records, to be able to enjoy the music on the records when my dad was at work.
As I grew and became able to easily handle any size records, I discovered the concept of the mixtape. Throughout my childhood, cassette tape remained the only viable means of recording sound for me. But even after graduating to reel-to-reel tape machines, disk recording lathes and all kinds of digital recording systems, cassette tape never lost its magic for me.
As a teenager playing guitar and keyboards, I started experimenting with more complex recording ideas, using several cassette decks and a mixer. At first it was a crude homemade mixer, then I got a cheap DJ mixer and as a young adult, after a lot of saving up and experience in professional recording and broadcasting facilities, I eventually managed to buy my first mixing console second-hand. I was still using this with my multiple cassette decks.
Shortly thereafter, I found a Tascam 414 Portastudio, which is a 4-track cassette deck that records using all four tracks in the same direction. No side A or side B. Flipping the tape over would play things backwards, which was great for special effects! The Tascam 414 ran at 3-3/4 ips (inches per second), twice the normal cassette speed of 1 7/8 ips. It offered dbx noise reduction and had a very simple built in mixer. I did hundreds of recordings on this setup and some of them came out surprisingly well.
Heavily modified Tascam 414 with the mixer section removed for use with higher quality mixing console. Photo from the author’s personal archive of audio adventures.
Not only were cassette decks generally much more affordable than professional recording equipment (especially in the second-hand market, as broken units in need of repair work which I was happy to do on my own), the blank cassette tapes were also very attractively priced for a schoolboy with limited resources. There was a dedicated blank cassette tape store in my area, whose owner would excitedly explain to me the differences between the multiple different types he was stocking.
I learned that Type I/Normal/Fe was very similar to the ferric oxide formulations used in reel-to-reel tape. Type II/High/CrO2 was coated with chromium dioxide particles and was used with a higher bias setting. Type III/FeCr was a combination of ferric oxide and chromium dioxide, while Type IV/Metal had a non-oxide metal particle coating and could take higher peak levels prior to saturation.
It was the affordability, ease of use and very decent level of performance that made cassette tape popular. By the early 1980s, the cassette tape had become the best-selling consumer format, surpassing vinyl record sales. The average cassette deck at the time could offer a reasonably flat frequency response from 30 Hz to 16 kHz while the more sophisticated units did much better, while also having good speed stability and being quite reliable. The Annual Equipment Directory in the October 1983 issue of Audio listed no less than 203 different models of cassette decks in the US market alone and those listings were far from complete!
Marantz cassette deck. Photo courtesy of Magnetic Fidelity.
Being immune to vibration and shock, cassette players were widely used in cars and other mobile applications. The Sony Walkman was introduced in 1979 and paved the way for a range of products aimed at those who wanted to listen to music on the go. The iPod and iTunes owe their existence to cassette tape and the Walkman.
A Sony WM-FX421 Walkman.
Cassette tapes still form a big part of my personal music collection. I used them extensively during long road trips and made countless mixtapes on them, offering hours of entertainment to many a high school sweetheart, to whom they were frequently presented as gifts.
Sansui cassette deck. Photo courtesy of Magnetic Fidelity.
Throughout my professional career in audio, despite having access to much more highly regarded equipment, there were several occasions where cassette tape proved itself, even with commercial success, as we are bound to discover in Part Two…
More from Issue 101
View All Articles in Issue 101
#228 Serita’s Black Rose Duo Shakes Your Soul With a Blend of Funk, Rock, Blues and a Whole Lot More by Frank Doris Mar 02, 2026 #228 Vinyl, A Love Story by Wayne Robins Mar 02, 2026 #228 Thrill Seeker by B. Jan Montana Mar 02, 2026 #228 The Vinyl Beat: Donald Byrd, Bill Evans, Wes Montgomery, Eddie Palmieri and Frank Sinatra by Rudy Radelic Mar 02, 2026 #228 Listening to Prestige: The History of a Vitally Important Jazz Record Label by Frank Doris Mar 02, 2026 #228 How to Play in a Rock Band, 21: Touring With James Lee Stanley by Frank Doris Mar 02, 2026 #228 The NAMM 2026 Show: The Music Industry’s Premier Event by John Volanski Mar 02, 2026 #228 The Earliest Stars of Country Music, Part Two by Jeff Weiner Mar 02, 2026 #228 From The Audiophile's Guide: A Brief History of Stereophonic Sound by Paul McGowan Mar 02, 2026 #228 A Bone to Pick With Streaming Audio by Frank Doris Mar 02, 2026 #228 Blast Off With Bluesman Duke Robillard by Ray Chelstowski Mar 02, 2026 #228 A Visit to the Marten Loudspeaker Factory in Göteborg, Sweden by Ingo Schulz and Sebastian Polcyn Mar 02, 2026 #228 Pure Distortion by Peter Xeni Mar 02, 2026 #228 A Nagra Factory Tour by Markus "Marsu" Manthey Mar 02, 2026 #228 Back to My Reel-to-Reel Roots, Part 27: Noodge and Ye Shall Receive, Part Two by Ken Kessler Mar 02, 2026 #228 PS Audio in the News by PS Audio Staff Mar 02, 2026 #228 90-Degree Stereo by Frank Doris Mar 02, 2026 #228 The Keys to Art by Rich Isaacs Mar 02, 2026 #227 Seth Lewis Gets in the Groove With Take a Look Around: a Tribute to the Meters by Frank Doris Feb 02, 2026 #227 Passport to Sound: May Anwar’s Audio Learning Experience for Young People by Frank Doris Feb 02, 2026 #227 Conjectures on Cosmic Consciousness by B. Jan Montana Feb 02, 2026 #227 The Big Takeover Turns 45 by Wayne Robins Feb 02, 2026 #227 Music and Chocolate: On the Sensory Connection by Joe Caplan Feb 02, 2026 #227 Singer/Songwriter Chris Berardo: Getting Wilder All the Time by Ray Chelstowski Feb 02, 2026 #227 The Earliest Stars of Country Music, Part One by Jeff Weiner Feb 02, 2026 #227 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part Two by Rudy Radelic Feb 02, 2026 #227 How to Play in a Rock Band, 20: On the Road With Blood, Sweat & Tears’ Guitarist Gabe Cummins by Frank Doris Feb 02, 2026 #227 From The Audiophile’s Guide: Audio Specs and Measuring by Paul McGowan Feb 02, 2026 #227 Our Brain is Always Listening by Peter Trübner Feb 02, 2026 #227 PS Audio in the News by PS Audio Staff Feb 02, 2026 #227 The Listening Chair: Sleek Style and Sound From the Luxman L3 by Howard Kneller Feb 02, 2026 #227 The Los Angeles and Orange County Audio Society Celebrates Its 32nd Anniversary, Honoring David and Sheryl Lee Wilson and Bernie Grundman by Harris Fogel Feb 02, 2026 #227 Back to My Reel-to-Reel Roots, Part 26: Half Full – Not Half Empty, Redux by Ken Kessler Feb 02, 2026 #227 That's What Puzzles Us... by Frank Doris Feb 02, 2026 #227 Record-Breaking by Peter Xeni Feb 02, 2026 #227 The Long and Winding Road by B. Jan Montana Feb 02, 2026 #226 JJ Murphy’s Sleep Paralysis is a Genre-Bending Musical Journey Through Jazz, Fusion and More by Frank Doris Jan 05, 2026 #226 Stewardship by Consent by B. Jan Montana Jan 05, 2026 #226 Food, Music, and Sensory Experience: An Interview With Professor Jonathan Zearfoss of the Culinary Institute of America by Joe Caplan Jan 05, 2026 #226 Studio Confidential: A Who’s Who of Recording Engineers Tell Their Stories by Frank Doris Jan 05, 2026 #226 Pilot Radio is Reborn, 50 Years Later: Talking With CEO Barak Epstein by Frank Doris Jan 05, 2026 #226 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part One by Rudy Radelic Jan 05, 2026 #226 Capital Audiofest 2025: Must-See Stereo, Part Two by Frank Doris Jan 05, 2026 #226 My Morning Jacket’s Carl Broemel and Tyler Ramsey Collaborate on Their Acoustic Guitar Album, Celestun by Ray Chelstowski Jan 05, 2026 #226 The People Who Make Audio Happen: CanJam SoCal 2025, Part Two by Harris Fogel Jan 05, 2026 #226 How to Play in a Rock Band, 19: Touring Can Make You Crazy, Part One by Frank Doris Jan 05, 2026 #226 Linda Ronstadt Goes Bigger by Wayne Robins Jan 05, 2026
