Issue 67 • Free Online Magazine
Issue 67 VINTAGE WHINE
50 Ways to Read a Record Part 3
It’s difficult to explain the basics of a highly-technical process like record playback without getting bogged down in eye-rolling minutiae. I’ll try to stick to the big-picture trends and details, and avoid nerding out. But when you get right down to it—a major part of audiophilia is nerding out—no?
But I digress.
In the big picture, record playback is just the process of tracking the groove. If you’ve ever encountered a jukebox or a transcription turntable from the ’40s or ’50s, designed to play back 78s, you’ll have seen the massive tonearms and bulky cartridges that often required ounces in tracking force—not grams.  Remember, an ounce is 28.3495 grams— let’s say roughly 28 1/2 grams. The manual for the RCA 70-D transcription ‘table, state of the art at its introduction in 1948, specifies tracking weight at 28 grams, plus or minus 1/2 gram—which is damned near close to an ounce. For comparison, depending on when they were minted—the metallic composition varied in density— a US penny runs from 2.5 grams to 3.11 grams. A nickel runs about 5 grams—and as a kid, I saw phonographs with nickels taped to the tonearm’s headshell, a brute-force method of improving tracking.
I’d still love to have one, but it may well rumble like a freight train with stereo records. Only 150 pounds in that cabinet.
While those weights sound  horrific in the context of a stereo microgroove vinyl record, keep in mind that 78s had much larger grooves, and thus the downforce is distributed over a much larger surface area than with a modern 45/45 microgroove record. Even today, with a modern tonearm and cartridge designed for 78 playback, optimal downforce is usually considered to be in the 4-5 gram range.
If you’re looking for simple, straightforward, factual history—you need to stay away from the history of 78s. For starters, from the turn of the century through the ’20s, record speeds were not standardized, and different labels had their own “house” speeds—which could vary anywhere from 70 to 100 rpm. To make matters even more confusing, groove sizes weren’t standardized, either. Pre-1940, most mainstream labels had grooves playable by a conical or spherical stylus of  around 3 mil in diameter(a mil being one one-thousandth of an inch—so 3 mil= 0.003″), but again, earlier and more obscure labels varied from that. Post-1940, most 78 grooves were playable with a 2.7 mil stylus.
Back in the day,  many phono cartridge companies offered a variety of playback styli for archival work. Today, Esoteric Sound, maker of present-day Rek-O-Kut products, still offers kits with a wide range of styli size in both cartridges and replacement styli to assist in playback of early records.
Everything we’ve just discussed? Forget it all, when it comes to the 33 1/3 rpm LP (long-playing record) introduced by Columbia in 1948. The discs themselves were thinner than 78s, made from vinyl rather than shellac and clay, and the grooves were far finer. The LP thus had both longer playing time and (in general) lower surface noise than 78s. The LP was developed by a team at CBS Labs in Stamford, Connecticut, near New York City. The team leader was Dr. Peter Goldmark, a polymath who had previously led development of early rotating-disk color television systems, and subsequently helped develop videotape technology and scanning imaging systems for lunar landers. Goldmark’s 1973 autobiography, Maverick Inventor: My Turbulent Years at CBS can still be found on Amazon and other outlets. It’s an interesting read, though it does tend to be self-serving. But then: what autobiography isn’t?
As if the change to the microgroove wasn’t enough upheaval—stereo made matters even more complex. While stereo recordings had been made in the early 1930’s by Alan Blumlein at EMI in England and by Keller and Fletcher at Bell Labs in the US—the famous Stokowski recordings—development of stereo discs didn’t pick up momentum until the LP was on the market. The obvious question was: how do you record two separate channels of information to a disc, and then play it back? Several developers opted for two separate grooves; most famous of these was Emory Cook, whose Cook Laboratories released a number of binaural recordings, including demo discs featuring trains—soon to become a stereo cliche’. Cook’s two-groove method required two separate cartridges, and clip-on cartridge assemblies were produced to adapt existing turntables.The other contender was ultimately the victor: the 45/45 single groove method, which cut both channels into a single groove. The method had been explored by Bell Labs in the ’30s, and was revived by Western Electric offshoot Westrex, in the ’50s. As we’ve written about previously, the first single single-groove stereo discs were released in the US by the tiny Audio Fidelity label, using Westrex demo material. The warring formats and commercial competition can be read in contemporary accounts archived here, and it’s pretty  gripping stuff.
Somehow, a sidebar has grown into a full column. We’ll get back on track with a look at the nuts and bolts of record playback in the next issue of Copper.
More from Issue 67
View All Articles in Issue 67
#225 Capital Audiofest 2025: Must-See Stereo, Part One by Frank Doris Dec 01, 2025 #225 Otis Taylor and the Electrics Delivers a Powerful Set of Hypnotic Modern Blues by Frank Doris Dec 01, 2025 #225 A Christmas Miracle by B. Jan Montana Dec 01, 2025 #225 T.H.E. Show New York 2025, Part Two: Plenty to See, Hear, and Enjoy by Frank Doris Dec 01, 2025 #225 Underappreciated Artists, Part One: Martin Briley by Rich Isaacs Dec 01, 2025 #225 Rock and Roll is Here to Stay by Wayne Robins Dec 01, 2025 #225 A Lifetime of Holiday Record (and CD) Listening by Rudy Radelic Dec 01, 2025 #225 Little Feat: Not Saying Goodbye, Not Yet by Ray Chelstowski Dec 01, 2025 #225 How to Play in a Rock Band, Part 18: Dealing With Burnout by Frank Doris Dec 01, 2025 #225 The People Who Make Audio Happen: CanJam SoCal 2025 by Harris Fogel Dec 01, 2025 #225 Chicago’s Sonic Sanctuaries: Four Hi‑Fi Listening Bars Channeling the Jazz‑Kissa Spirit by Olivier Meunier-Plante Dec 01, 2025 #225 From The Audiophile’s Guide: Controlling Bass Frequencies Through Membrane Absorbers (and How to Build Your Own) by Paul McGowan Dec 01, 2025 #225 Your Editor’s Tips for Attending Audio Shows by Frank Doris Dec 01, 2025 #225 PS Audio in the News by Frank Doris Dec 01, 2025 #225 Back to My Reel-to-Reel Roots, Part 24 by Ken Kessler Dec 01, 2025 #225 Holiday Music by Frank Doris Dec 01, 2025 #225 Puppy Prognostication by Peter Xeni Dec 01, 2025 #225 How to Post Comments on Copper by Frank Doris Dec 01, 2025 #225 Living Color by Rudy Radelic Dec 01, 2025 #224 T.H.E. Show New York 2025, Part One: A New Beginning by Frank Doris Nov 03, 2025 #224 Fool’s Leap of Faith is the Extraordinary Octave Records Debut from Singer/Songwriter Tyler Burba and Visit by Frank Doris Nov 03, 2025 #224 The Beatles’ “Aeolian Cadences.” What? by Wayne Robins Nov 03, 2025 #224 Persona Non Grata by B. Jan Montana Nov 03, 2025 #224 Talking With Recording Engineer Barry Diament of Soundkeeper Recordings, Part Two by Frank Doris Nov 03, 2025 #224 B Sides, B Movies, and Beware of Zombies by Rudy Radelic Nov 03, 2025 #224 The Burn-In Chronicles: 1,000 Hours to Sonic Salvation by Olivier Meunier-Plante Nov 03, 2025 #224 A Conversation With Mat Weisfeld of VPI Industries by Joe Caplan Nov 03, 2025 #224 Blues-Rocker Kenny Wayne Shepherd Celebrates 30 Years of Ledbetter Heights by Ray Chelstowski Nov 03, 2025 #224 Playing in a Rock Band, 17: When Good Gigs Go Bad, Part Two by Frank Doris Nov 03, 2025 #224 From The Audiophile’s Guide: Dealing with Odd-Shaped Rooms by Paul McGowan Nov 03, 2025 #224 TEAC’s TN-3B-SE Turntable Plays Bob Dylan by Howard Kneller Nov 03, 2025 #224 PS Audio in the News by Frank Doris Nov 03, 2025 #224 Lost in Translation by Peter Xeni Nov 03, 2025 #224 Reel-to-Reel Roots, Part 23: Better Than Rice Krispies by Ken Kessler Nov 03, 2025 #224 I Bring Joy! by Frank Doris Nov 03, 2025 #224 Screen Test by Rich Isaacs Nov 03, 2025 #224 How to Post Comments on Copper by Frank Doris Nov 03, 2025 #132 Dr. Patrick Gleeson: The Interview, Part Two by Rich Isaacs Oct 07, 2025 #223 World Fusion Meets Flamenco in Gratitude from Steve Mullins and Rim of the Well by Frank Doris Oct 06, 2025 #223 Judging Albums by Their Covers by Rich Isaacs Oct 06, 2025 #223 Recent Arrivals and 12-inch Royalty by Rudy Radelic Oct 06, 2025 #223 Summer of Creem, Part Two by Wayne Robins Oct 06, 2025 #223 Recording Engineer Barry Diament of Soundkeeper Recordings: Striving for Natural Sound by Frank Doris Oct 06, 2025 #223 Tea on the Terrace by B. Jan Montana Oct 06, 2025 #223 How Good Can Car Audio Get? by Joe Caplan Oct 06, 2025 #223 The Advantages of a Dedicated Listening Room by Paul McGowan Oct 06, 2025 #223 1! 2! 3! 4! Surrounded by the Ramones in Dolby Atmos! by Frank Doris Oct 06, 2025
But I digress.
