Skip to product information
1 of 1
AudioQuest Rocket 44 Speaker Cable
Regardless of which Stellar power amplifier is connected to your loudspeaker, the speaker cables used play a vital role in overall sound quality. We curated the perfect match between Stellar and your speakers: Rocket 44 speaker cables. These Perfect-Surface Copper+ cables are an ideal connection between Stellar and your speakers.
The Rocket 44 speaker cables from AQ have been chosen by the PS team to perfectly match the sonic qualities of Stellar. This cable uses a carefully finessed combination of Perfect-Surface Copper (PSC) and extremely high purity Perfect-Surface Copper+ (PSC+) conductors. The astonishingly smooth and pure Perfect-Surface eliminates harshness and greatly increases clarity compared to OFHC, OCC, 8N and other coppers. Extremely high-purity PSC+ further minimizes distortion caused by grain boundaries, which exist within any metal conductor. The result is a musical miracle: Stellar and Rocket 44. Get ready to take off with improved dynamic contrast, transient response, and bass slam that are rendered seemingly without effort.
Regular price $880.00 USD
Regular price Sale price $880.00 USD
On Sale Sold out
call
TALK TO A HI-FI SPECIALIST
View full details
  • Design
    Designing speaker cables properly requires careful consideration of conductor quality, cable geometry and quality of insulation material (dielectric). Speakers exhibit varying impedances as well as high-current demands. If the speaker cable is not up to the job, loss of fidelity as well as a tonal balance shifts are the unwanted results. With Rocket 44 speaker cable and Stellar a perfect match has been created. Rocket 44 incorporates Perfect-Surface Copper+ into its blend of conductors. PSC+ has fewer grain boundaries, which reduces harshness in the sound. This carefully finessed combination of PSC+ and PSC enables Rocket 44 to deliver clear and faithful sound. Rocket 44 technology also incorporates Double Star Quad geometery eliminating the problems suffered by standard parallel-conductor speaker cables. Stellar power and Rocket 44 connectivity: that's a low-distortion combination we can celebrate.
  • Application
    The Rocket 44 speaker cables are a perfect match for Stellar power amplifiers and your speakers. Use a single Rocket 44 in a full range application, or two Rocket 44s in a bi-wire application. Stellar amps provide two sets of binding posts for this very purpose. Properly connecting your speakers and amplifier together using Rocket 44 allows the amplifier to perform at its absolute best. Rocket 44 and Stellar: a perfect low-distortion match.
    Technology
    Rocket 44's negative conductors are covered with partially conductive Carbon-Loaded Polyethylene. This remarkable material reduces radio-frequency garbage being fed back into the amplifier. The sonic benefit is exactly the same reduction in "hash" and improved dimensionality that comes whenever RF interference is reduced in an audio circuit. In addition, a carbon layer damps interaction between positive and negative conductors, and an external Carbon-Based Noise-Dissipation System reduces external interference.
    • SOLID PERFECT-SURFACE COPPER+ CONDUCTORS
    • DOUBLE STAR QUAD GEOMETRY
    • CARBON BASED NOISE & CROSSTALK DISSIPATION SYSTEM
    • FOAMED POLYETHYLENE INSULATION
    • SPADE OR BANANA, GOLD OR SILVER CONNECTORS
    1 of 5
    Questions?
