Skip to product information
1 of 1
AudioQuest Robin Hood ZERO Speaker Cable
When Paul's Reference AudioQuest Dragon ZERO Speaker Cables are not in the financial cards, it's time to step up to the PerfectWave Robin Hood ZEROs from AudioQuest. These bad boys bring music to life as few cables can.
The engineers at AQ set out to solve a fundamental problem in loudspeaker/amplifier interactions, impedance mismatch, said to cause compression and a loss of life in the music. By eliminating the speaker cable’s characteristic impedance, current compression and distortion of the signal (current) transient is significantly reduced. The result is dynamic contrast, transient response, and bass slam that are rendered seemingly without effort.
Regular price $1,995.00 USD
Regular price Sale price $1,995.00 USD
On Sale Sold out
call
TALK TO A HI-FI SPECIALIST
View full details
  • Design
    The same team responsible for the groundbreaking new series of AudioQuest AC power cables—AudioQuest's founder, William Low, and Senior Director of Engineering, Garth Powell—has created what AudioQuest considers one of the finest-sounding speaker cables ever made. Robin Hood ZEROs use the same technology as the top-of-the-line Dragons with fewer conductors. In these groundbreaking cables, the designers focused on addressing one of the most vexing issues plaguing speaker cable design: the mismatch between the amplifier’s source impedance and the speaker’s load impedance. The results need to be heard to be believed. These are one great set of cables for connecting PS amps to your speakers.
  • Application
    The Robin Hood ZERO speaker cables may be used in one of two ways: either as ideal Full-Range cables, or, in combination with a dedicated BASS cable, in a BiWire cable assembly of unparalleled performance. Robin Hood cables incorporate AQ's patented common-mode noise-rejection technology, yielding an audibly dramatic additional reason to BiWire when possible. The openness and dynamic contrast is the sound of your amplifier doing its job unmolested by either current compression or radio-frequency noise.
    Technology
    Solid conductors prevent electrical strand-to-strand interaction: a major source of distortion. Surface quality is critical because a conductor can be considered as a rail-guide for both the fields within a conductor, and for the magnetic fields that extend outside the conductor. The astonishingly smooth and pure surface of all AudioQuest’s Perfect-Surface metals nearly eliminates harshness and greatly increases clarity compared to lesser materials. Extremely high-purity Perfect-Surface Copper+ further minimizes distortion caused by grain boundaries that exist within any metal conductor.
    • CONTROLLED FOR LOW-NOISE DIRECTIONALITY
    • SOLID PERFECT SURFACE COPPER+ CONDUCTORS
    • ZERO TECH, NO CHARACTERISTIC IMPEDENCE
    • CARBON BASED LINEARIZED NOISE DISSIPATION (NDS)
    • 72V DIALECTIC BIAS SYSTEM
    • RADIO FREQUENCY TRAP
    • COLD WELDED TERMINATIONS
    1 of 7
    Questions?
