Skip to product information
1 of 11
DirectStream DAC MK1 - Refurbished
In response to the incredible demand for our highly sought-after Directstream DAC MK2, we are delighted to announce that we have a collection of preloved Directstream DAC MK1 units. At PS Audio, we consider it a true privilege to offer these units the opportunity to find a new loving home. We take great pride in our processes. Each unit undergoes a comprehensive inspection by our expert technicians, ensuring its great condition. Factory refurbished units may have cosmetic blemishes. Furthermore, we conduct thorough functionality tests to guarantee its optimal performance. To provide you with complete peace of mind, we offer a one-year guarantee.
You have 14 calendar days to audition a Refurbished item from the date you received it. For more information on PS Audio Refurbished units click here.
Regular price $1,599.00 USD
Regular price $5,999.00 USD Sale price $1,599.00 USD
On Sale Sold out
call
TALK TO A HI-FI SPECIALIST
View full details
  • Design
    DirectStream converts every input signal, both PCM and DSD, to single-bit, high sample rate 20X DSD signal. Use of a FPGA rather than an off the shelf DAC chip provides immense processing power, resulting in complete lack of digital glare, and allows the owner to download OS updates as they are released.
  • Application
    DirectStream is the heart of a reference quality digital audio based system. It handles all PCM sources up to 352.8 kHz, and DSD 64 and 128 (USB and I2S) and DSD256 (I2S only, with the Sunlight OS). Its zero-loss digital volume control allows it to be used as a preamplifier, directly feeding a power amp. Include the Network Bridge to stream Qobuz, Tidal, and Spotify. Roon ready.
    Technology
    Class A+ Stereophile rated DirectStream DAC converts any digital input format from CDs, servers, and streamers, into a pure DSD format and outputs near-perfect analog directly to your power amplifier or preamplifier. Whatever the format, sample rate, or the medium, DirectStream provides a pure output that fulfills the promise of high-resolution analog performance from digital sources. DirectStream is the work of digital audio genius, Ted Smith. Unlike conventional DACs that rely upon off the shelf DAC chips, DirectStream is hand written onto a FPGA (Field Programmable Gate Array). This allows far more precise and accurate processing of the digital signal, resulting in significantly better sound quality and upgradeability in the field. Every six months or so, Ted Smith's continual research into digital audio reproduction nets another breakthrough in performance. DirectStream DAC owners are given it free in the form of a downloadable upgrade. In this way, DirectStream owners can be assured that their unit will continue to improve over time, and never become obsolete. Hear what’s been missing in your music for all these years. If you know the sound of music and instruments, and want to hear what’s been missing on your discs, then this DAC is right for you.
    • 100% DSD BASED D-A CONVERTER
    • UPGRADABLE VIA SOFTWARE RELEASES
    • VOLUME, BALANCE CONTROL BUILT IN
    • UPSAMPLES PCM AND DSD TO 20x DSD RATE
    • DXD SUPPORT
    • PASSIVE TRANSFORMER COUPLED OUTPUT
    • IMPROVES IMAGING + SOUNDSTAGE
    • DIRECT SIGNAL PASS WITH 1x MASTER CLOCK
    • HANDWRITTEN FILTERS, PROCESSORS, SAMPLERS
    • IMMUNE TO OUTSIDE SOURCE JITTER PROBLEMS
    • INCREASED DIGITAL HEADROOM
    • NO OFF-THE-SHELF IC-DAC CHIPS USED
    • UNCOVERS DETAILS USUALLY MASKED BY PCM PROCESSORS
    • 7x DIGITAL INPUTS
    • MQA + TIDAL READY WITH OPTIONAL BRIDGE II
    • FULLY BALANCED FROM INPUT TO OUTPUT
    • COLOR TOUCH SCREEN
    1 of 17
    Specifications - DirectStream DAC
    Physical
    Unit Weight 22 lbs [9.97 kg]
    Unit Dimensions 14” x 17” x 4” [ 36cm x 43cm x 10cm]
    Shipping Weight 31 lbs [14 kg]
    Shipping Dimensions 20.5”x 24” x 10” [52cm x 61cm x 25cm]
    Power requirements
    Input Power Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz
    Power Consumption 30W
    Digital audio inputs
    I2S(2), Coax, XLR Balanced, TOSLINK, USB, Network Bridge slot
    Sample Rates
    I2S, and USB — 44.1kHz to 352.8kHz 16bit, 24bit, DSD 64, DSD 128 (I2S  DSD 256 with Sunlight update)
    TOSLINK – 44.1kHz to 96kHz 16bit, 24bit
    XLR (AES/EBU)S/PDIF (coax)– 44.1kHz to 192kHz 16bit, 24bit, DSD 64
    Analog Audio Output
    Connector RCA/XLR Unbalanced /Balanced (X2)
    Output level, low 0.282 VRMS Balanced
    0.141 VRMS Single Ended
    Output level high, maximum 2.818 VRMS Balanced
    1.414 VRMS Single Ended
    Output Impedance 100Ω/200Ω
    Frequency Response 20-20KHz +/- 0.25dB
    THD+N @ 1KHz (full scale) <0.03%
    Output Stage Passive audio transformer, fed by high current, high speed analog amps producing double rate DSD.
    Data Handling
    Format PCM or DSD
    Sample rate (PCM) 44.1kHz, 48.0kHz, 88.2kHz, 96.0kHz, 176.4kHz, 192kHz, 352.8kHz
    Word length (PCM) 16b, 18b, 20b, 24b
    Data rate (DSD) Standard (2.8MHz) or Double (5.6MHz) DoP as well as raw DSD on I2S and USB inputs
    Input jitter reduction effectively 100%, residual immeasurable. No input PLLs, FLLs.
    Input Processing 170MHz
    Signal Processing 50MHz
    Synchronous Upsampling, all inputs 28.224MHz
    Digital Processing S/N ratio >146 dB
    Digital Volume Control Zero loss of precision
    Analog Conversion method Delta Sigma (DSD) Single-bit double rate
    I2S Digital Input
    Connector HDMI
    Format PCM or DSD. DoP on all inputs as well as raw DSD on I2S inputs
    USB Digital Input
    Connector USB “B” Type
    Format PCM or DoP v1.1 (DSD over PCM)
    Transfer mode Asynchronous
    • Rajiv Arora, Audiophile Style
      The PS Audio DirectStream DAC is a 5 year old design that, with the latest “Snowmass” release, still competes with the best DACs in its price class. How many DACs can make that claim? Many DACs are user-upgradeable, but very few have received the steady stream of free firmware updates that delivered sound quality improvements - not just bug fixes - that enable the DS DAC to retain its competitive edge. Plus, designer Ted Smith tells me he still has some (albeit shrinking) capacity left in the
      See More
    • Dan Rubin, Dagogo
      In all configurations I tried, playback from the Memory Player was clearly better than playback from the Mac Mini+Roon. This is an instance where I feel the differences were not a matter of preference. I am sure there are some out there who would prefer the sound of the server, but they would be wrong…. I consistently heard a lower noise floor from the Memory Player and, from that, more air, better definition, and less smearing, which I became aware of only when confronted with its absence
      See More
    • John Richardson, Part Time Audiophile
      I feel fairly safe in concluding that not only are these components highly enjoyable to hear and use, but that they are also safely on the cutting edge of digital audio reproduction. And I don't see that premise changing anytime soon, what with PS Audio's commitment to free software updates to anyone purchasing the gear. I don't think the digital audio enthusiast could go wrong with this pair
      See More
    • Jeff Dorgay, Tone Audio
      I can't think of a better digital disc player than the PS Audio DirectStream Memory Player and DAC. (Neither of these six figure players will play your DVD-a discs) If I had more than two thumbs to raise I would offer them, it's that good. The only remaining choice is whether you want silver or black
      See More
    • Greg Petan, Positive Feedback
      Attaining the performance provided by the PerfectWave transport and DirectStream DAC even five years ago would have cost multiples of the PS Audio Duo. This potent, engagingly musical front end will allow you to rediscover the plethora of CDs in your collection with a fresh, more organic and dynamic take. And with the millions of CDs flooding the used market the PerfectWave Transport and DirectStream DAC will be a great musical partner standing by your side for years to come
      See More
    • Scott Hull, Part Time Audiophile
      The DirectStream DAC is the hottest thing to come of PS Audio since forever. This unconventional design, even as it does all manner of violence to the heart of the purist with all of his “do nothing to the signal” whining, just kills it. Its performance is on par with some of the very best “traditional” designs on the market, and with its potential for endless upgradability, the DirectStream is revolutionary
      See More
    • Art Dudley, Stereophile
      Time will tell if and when these levels of performance, flexibility, and luxury will become available for less than 000. But today, for those who've waited for a computer-friendly DAC that offers, with every type of music file, the best musicality of which DSD is capable, the PerfectWave DirectStream may be in a class by itself
      See More
    • Vade Forrester, The Absolute Sound
      DirectStream's easily the best DAC I've ever heard in my system, making digitally-recorded music sound better than I've ever heard it
      See More
    • Chris Martens, Hi Fi PLus
      The real magic of this DAC may centre on its handling of PCM material—material the DAC gives greater smoothness, fluidity, dimensionality, and elegance than it might otherwise have had. I don't mean to suggest by this that traditional PCM playback methods cannot or do not sound perfectly good in their own right, because they certainly can and do. But if PCM playback has an identifiable 'failure mode' it might be that PCM files can at times sound a bit flat and 2-dimensional, while exhibiting
      See More
    • Deon Schoeman, AV Magazine
      The jump from downmixed to true, native DSD was quite astonishing. It lifted a previously unnoticeable opaqueness, allowing unfettered access to the full harvest of tonality and detail
      See More
    • Dave Clark, Positive Feedback
      Synergy and magic. Right now here in our listening room...Way deeper bass, way more open, way less whatever being in the way of our music… way more music. Dynamics… try My Disco's "1991" or anything from Lustmord. Happy times
      See More
    • Karl Sigman, Audiophilia
      The DS is a game changer; I think it has caused the 'war' between DSD and PCM to be on hold or mute for most of us, and above all hold your horses before buying expensive high-resolution PCM files or DSD. That alone is a major accomplishment
      See More
    • Brian Kahn, Home Theater Review
      The DirectStream DAC is one of the finest-sounding DACs I have heard. Many will be excited just to see that it can accept DSD signals, but I would say that they are being shortsighted. The DSD processing of all signals is what makes this unit special
      See More
    • John Darko, Digital Audio Review
      PS Audio's DirectStream DAC is a goto unit for vinyl fans who've previously found digital playback to sound too rigid or uptight. The DirectStream is simultaneously more mellow and understated; there's less of the celestial awe of the Aqua La Scala MKII and less of the ultra-colourful exuberance of the AURALiC Vega. In driving this point home I've put my money where my mouth is: I've purchased the DirectStream review unit in spite of already having a multitude of terrific sounding DACs here to
      See More
    • AV Magazine (South Africa)
      The PS Audio DirectStream is a musically authentic, thoroughly engaging and ultimately compelling DAC that elevates the listening experience to an entirely new level. Its treatment of any digital material, regardless of format, is quite astounding — even MP3s and Internet radio sounded vibrant and exciting
      See More
    • Stereo Magazine (Germany)
      Matthias Böde of Germany's Stereo Magazine gives DirectStream 100 out of 100 points. The article is in German, but it can easily be translated and viewed if German's not your native language. "100 out of 100"
      See More
    • Marja and Henk, 6 Moons
      But what happened now was beyond our expectations. Maybe we had been lulled into a bit of been-there-done-that reviewer fatigue but the DirectStream's handling of this CD became a rude wakeup call and put us back on edge to eat crow. Damn, the performances of the various groups and soloists were so real and at such dynamic range, it was hard to believe that the source material was a simple 16/44.1 Redbook CD
      See More
    • Michael Lavorgna, AudioStream
      Even at low listening levels, music retained its character with no sense of the sound washing out. For those people looking for a direct-to-amp DAC/Digital Preamp, consider the DirectStream a solid contender
      See More
    • Frank Alles, Stereo Times
      After listening to the PS Audio PerfectWave DirectStream DAC for the past few months it is my opinion that DirectStream represents a new benchmark in audio reproduction. Notice that I didn't say “digital audio reproduction.” In other words, in my view the PS Audio DirectStream is the most musically and technically capable device of any type that I've ever had the pleasure to evaluate. My heartfelt congratulations go out to Paul McGowan, Ted Smith, and PS Audio's excellent design team for making
      See More
    • David W. Robinson, Positive Feedback
      This is a brilliant design, with exceptional execution, and paradigm-setting sound. I can tell you, this bloody DAC, DSD to the fore, is a real killer. Flat-out, stone-cold, and damn-straight. It has been a while since 2008, but now I have to say that the DirectStream DAC is the first real rival to Playback Designs that I've heard. It goes right to the top of my heap of DSD DACs, right next door to the PD Series-3. The envelope for the audio arts has moved out yet again. To tell you the truth, I
      See More
    • Richard Murrison, Bit Perfect
      The DirectStream's sound is non-fatiguing in an almost tube-like way. It is smooth and relaxing. Surely, you tell yourself, it must be sacrificing detail to deliver this. But no. With recording after recording, the DirectStream presents layers and layers of detail in such a way as to produce a sound which is very easy to listen to, and with a low fatigue factor, even with CD sources. As someone with very little tolerance for the fatiguing nature associated with CD, I find this to be a most
      See More
    • Brent Uptain, Headphone Guru
      It is truly an exceptional product, and a DAC that allows even the most familiar music to surprise and enthrall. Yes, the folks at PS Audio understand that with digital audio, there can be no final word. Meet the Directstream - a DAC that is ready to keep up with the conversation
      See More
    Questions?
