Skip to product information
1 of 10
BHK Signature Preamplifier
Preamplifiers are at the heart of any high-performance music system. They are the critical controlling interface between our sources of music and our loudspeaker chain. Most preamplifiers do a fine job of control and isolation, but only a rare handful make magic happen. Add the BHK Signature Preamplifier into your system and suddenly you are enveloped in a wealth of musicality you’ve not yet experienced: deeper, wider, sound staging, improved separation of instruments and voices, subterranean bass, extended highs, and an openness you're unlikely to have experienced without this instrument in the system.
Regular price $6,999.00 USD
Regular price Sale price $6,999.00 USD
On Sale Sold out
Trade-in
call
TALK TO A HI-FI SPECIALIST
View full details
  • Design
    The BHK Signature Preamplifier features two 12AU7 dual triode vacuum tubes in the input stage that act as a zero feedback balanced input amplification pair. A combination of an input stepped attenuator, built around the highest quality passive components for coarse volume adjustments, coupled with controlling the actual gain of the vacuum tube for finer steps, turned out to be the most sonically transparent level control we have yet heard. Finally, the output stage is a high-bias class A MOSFET design that is unaffected by cable and power amplifier interface challenges.
  • Application
    Preamplifiers play a critical role in any separates audio system, strategically positioned between sources of music: CD players, phono preamps, DACs, tape recorders and tuners—and your power amplifier—the preamp serves essential roles of control and isolation. The BHK Signature Preamplifier features 5 identical balanced and single ended inputs, and converts all input signals into a balanced signal for the lowest possible distortion, and can be used in a two-channel audio system or as part of a home theater system. The high-bias Class A MOSFET output stage ensures unmatched performance with any cable and amplifier interface.
    Technology
    The BHK Signature Preamplifier is one of the most remarkable musical instruments in the world. It is the perfect interface between your sources and power amplifier. Designed by Bascom H. King, the BHK Signature distills Bascom’s 50 plus years of high-end audio design experience into a single masterpiece of audio amplification. “This is the best sounding preamplifier I have ever designed or heard,” and that’s saying a lot for a man of Bascom’s experience. Preamplifiers play a critical role in any separates audio system, strategically positioned between sources of music: CD players, phono preamps, DACs, tape recorders and tuners – and your power amplifier – the preamp serves essential roles of control and isolation. Control is simple in concept, but extraordinarily difficult to design in an acoustically transparent manner. Control duties such as input switching, volume, balance, and amplification can place unwanted acoustic thumbprints on the music if not designed with extraordinary care. The challenge in any design is to do as little damage to music’s purity as possible. What our Master Designer, BHK, has built will not only stand the test of time, but represents one of the finest musical instruments ever built to honor the music.
    • ZERO-LOSS VACUUM TUBE INPUT STAGE
    • 12V AND 6V TUBE SWITCH
    • COUPLED & BALANCED MOSFET OUTPUT STAGE
    • THROUGH-HOLE CONSTRUCTION
    • PRP RESISTORS IN SIGNAL PATH
    • 5x RCA SINGLE ENDED INPUTS
    • 5 XLR BALANCED INPUTS
    • SINGLE ENDED & BALANCED INPUTS
    • FULLY BALANCED INPUT TO OUTPUT
    • OVERSIZED POWER TRANSFORMER
    • BHK DESIGNED MOSFET VOLTAGE REGULATORS
    • BHK DESIGNED MOSFET HEADPHONE STAGE
    • REMOTE CONTROL
    • STANDBY BUTTON FOR VACUUM TUBE STAGE
    • -3dB > 200kHz
    • VOLUME & BALANCE THROUGH GAIN & ATTENUATION CONTROL
    • 2x OUTPUT DC CONTROL TRIGGERS
    • EASY ACCESS TO TUBES FOR CUSTOMIZATION
    • EACH INPUT CAN BE SET TO HT BYPASS
    1 of 19
    Specifications - BHK Signature Preamplifier
    Physical
    Unit Weight 22 lbs [9.97 kg]
    Unit Dimensions 17” x 14” x 4” [ 36cm x 43cm x 10cm]
    Shipping Weight 31 lbs [14 kg]
    Shipping Dimensions 20.5”x 24” x 10” [52cm x 61cm x 25cm]
    Power requirements
    Input Power Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz
    Power Consumption 60W
    Audio inputs
    Coaxial RCA single ended
    XLR Balanced
    5
    5
    Input Impedance
    Unbalanced (RCA)
    Balanced (XLR)
    33KΩ minimum
    66KΩ minimum
    Sensitivity Unbalanced 1.3V/33KΩ
    Balanced 1.3V/66KΩ
    Audio Outputs
    XLR Balanced
    2
    2
    Analog Audio Output
    Output level 4.0 Vrms
    Output Impedance <100Ω
    Frequency Response
    20-20KHz
    +/- 0.1dB
    THD&IM @ 1KHz (full scale) <0.03%
    Bandwidth -3dB 0.1Hz - 200kHz
    DC Triggers
    +12V 2
    Headphone Performance
    Output Power
    300Ω
    16Ω >
    >200mW
    4.0 Watts
    S/N Ratio >90dB (1KHz)
    THD & IM 1 volt out <0.02%
    Output Impedance <0.5Ω
    Reviews
    Questions?
