aspen FR10 Loudspeaker
Hi-Fi News says the aspen FR10 sets the $10k standard. Check out the rest of the review here.
The aspen loudspeaker series represents the culmination of 50 years of industry experience; learning in intimate detail what works and what does not; what it takes for a loudspeaker to disappear and leave only the magic of the music; designing a no-compromise phase-correct crossover; constructing a cabinet that does not color the sound; crafting a speaker that is easily driven with any decent power amplifier, and when not even the most advanced driver manufacturer’s products are good enough to meet our exacting standards, designing woofers, radiators, tweeters, and midranges from scratch. In all respects, the FR10 will transcend your expectations of what a small floor-standing loudspeaker can do.
No longer do you have to compromise.
Breathtaking to listen to, beautiful to behold, fits in any size room, with bass that will astound you, the aspen FR10 is a dream come true.
A no compromise affordable loudspeaker
Setup in minutes
Design
Application
Technology
Features
Specifications - aspen FR10 Loudspeaker
Color Options | Satin White, Satin Black |
Enclosure Type | Passive radiator (three 6x9” oval rear-firing) |
High Frequency Transducer | 2.5” planar magnetic with Teonex diaphragm |
Mid Frequency Transducer | 8” planar magnetic with Teonex diaphragm |
Low Frequency Transducer | 2 x 6.5” woofers, cast frame, non-woven carbon fiber PMI foam sandwich cone, advanced magnet structure |
Crossover Frequency | 550 Hz, 1750 Hz - Linkwitz-Riley 4th order acoustic |
Sensitivity (2.83V @ 1M) | 86.5 dB |
Nominal Impedance | 4 ohm (3.3 ohm minimum impedance) |
Recommended Amplifier Power | 50-200W |
Frequency Response | 32 Hz-20 kHz (-6dB) half space, 25 Hz (-6 dB) in-room |
Dimensions (HxWxD) |
41.5” x 11.75” x 16.25” with base (8” width not including base) |
Net Weight | 75 lbs (34.1 kg) |
Reviews
So much from such a compact speaker!
Carl H.
Hard to believe
Rob
They sound huge
Tony
I like they are not shiny
I really love the way the new FR10s look in my room. I have a smaller family room where I put them and they look great. I'm not so much into that glossy look so these are perfect. And they sound excellent.
I am very impressed with their openness and the deep bass. Hard to believe they would make that much bass from such a small enclosure. Even my wife likes them. :)
Barry M.
Better than my Focals
I was really concerned the FR10 wouldn't live up to the Focals but they are now on their way to PS as a trade in. They were great but too sharp in the upper midrange and I wanted something that just played music. The aspens are cool. They really rock.
D.M.
