Skip to product information
1 of 16
M700 Amplifier
M700 Amplifier
The Stellar M700 mono amplifiers are a massively powerful engine capable of effortlessly driving demanding loudspeaker loads to concert levels.
Enjoy an unheard of level of control and command from your loudspeakers with the Stellar M700, one of the most extraordinary under $5,000 power amplifier pair ever crafted. With its mighty 700 watt engine connected to any sized loudspeaker, the M700 monoblocks deliver extraordinarily effortless linear headroom that seems to go on forever. Dynamics like you've rarely experienced before. Slam, control, toe-tapping pacing, and music’s subterranean depths are effortlessly delivered to any loudspeaker from the most efficient to the most demanding. Revel in rich layers of fine, full detail you might have been missing before Stellar. Marvel at the deep, extraordinary, wall-to-wall soundstage. Control your loudspeakers as never before. Effortless. Lush. Stellar.
Regular price $3,498.00 USD
Regular price Sale price $3,498.00 USD
On Sale Sold out
Trade-in
call
TALK TO A HI-FI SPECIALIST
View full details
  • Design
    The hybrid approach used in the Stellar M700 Power Amplifier takes advantage of the best traits technology has to offer. The perfected analog voltage is then converted into the high current output needed to effortlessly drive your loudspeakers.
  • Application
    The M700 is Stellar's best. Rated at 350 watts into 8Ω and 700 watts into 4Ω, a pair of these placed on any loudspeaker brings forth the lush, rich, and soul-satisfying power of two completely independent power blocks with headroom to spare. The listening experience with the M700 starts feet tapping and smiles breaking out. One listen to a hugely loud and complex musical passage effortlessly rendered by the M700 pair and you'll know you made the right choice.
    Technology
    Rated at 350 Watts into 8Ω and 700 Watts into 4Ω, the M700 combines the best of two worlds: ultra linear, high-current, Class D technology for the output stage; a discrete, Class A MOSFET based Analog Cell for the all-important input stage. The Stellar M700 captures the rich, full-bodied essence of recorded music and presents it to your loudspeakers with authority and grace, never a hint of glare or unnaturalness. The M700 is faithful to the music like few amplifiers are. Listeners are constantly surprised at the width and depth of the M700's soundstage; its preservation of the smallest details in reverb, room acoustics, and musical overtones; its commanding presence without intrusion; its delicate handling of subtle shadings; its authority as it grabs hold of the loudspeaker and breezes through even the most complex musical passages.
    • MONO POWER AMPLIFIER PAIR
    • ZERO-LOSS ANALOG CELL INPUT
    • POWERFUL MOSFET OUTPUT STAGE
    • RCA SINGLE-ENDED INPUT
    • XLR "TRUE" BALANCED INPUT
    • 350 WATTS PER 8Ω CHANNEL
    • 700 WATTS PER 4Ω CHANNEL
    • 2Ω STABLE
    • < 0.1% THD 20Hz 20kHz AT RATED POWER
    • DAMPING FACTOR = 1100
    • FRONT PANEL STANDBY
    • VERY LITTLE HEAT PRODUCTION
    • DUAL, SOLID, COPPER PLATED OUTPUT POSTS
    • 27 LBS
    • INPUT 12v TRIGGER
    1 of 15
    Specifications - M700 Amplifier
    Stellar M700 Mono Amplifier
    Unit Weight 13 lbs [5.9 kg] (each)
    Unit Dimensions 17”W x 3”H x 12”D (13"D w/connectors)
    17”W x 6”H x 12”D (Stacked)
    Shipping Weight 16.5 lbs [7.5 kg] (each)
    Shipping Dimensions 22”W x 8”H x 17”D (each)
    Color Options Black
    Silver
    Voltage Options
    (Factory set only)
    Japan 100V
    North America 120V
    Europe/Asia/Australia/New Zealand 230V
    Mains Power Inputs IEC C14
    Idle Power Consumption 23W
    Accessories Included US (NEMA 5-15P) (all versions)
    Schuko (CEE7/7) (230V version)
    UK (BS 1363) (230V version)
    Audio Inputs RCA (Unbalanced)
    XLR (Balanced)
    Speaker Outputs Copper base nickel plated binding posts (2 pair)
    DC Trigger Input 3.5mm 5-15VDC
    Warranty 3 years parts and labor
    Signal
    Gain 30.5dB +/-0.5dB
    Sensitivity for rated output power 1.6V
    Noise 1kHz@700 Watts < -105dB
    Input impedance Unbalanced 50KΩ
    Balanced 100KΩ
    Output Impedance 50Hz, 2.8VRMS <0.007Ω
    Damping factor 50Hz. 2.8VRMS
    8Ω >1100
    4Ω >550
    Frequency Response 2.8VRMS into 4Ω
    10Hz – 20KHz +/- 0.5dB
    10Hz – 50KHz +0.1/-3.0dB
    THD&IM
    1KHz, 1W/4Ω <0.02%
    10-20KHz, 1W/4Ω <0.02%
    10-50KHz, 1W/4Ω < 0.05% (90kHz BW)
    1KHz, 87.5W/4Ω < 0.015%
    Output Power
    120vac mains, 1kHz, 1% THD
    8Ω 350W minimum
    4Ω 700W minimum
    2Ω Stable for musical transients
    Reviews
    They are a revelation!
    I have had the 700's for several months now and all I can say is..."WOW!" Even after the burn in period at PS Audio, that was not the end of the burn in process. It's taken a few more months and I don't even know now if they will continue to do this. However, I can't tell you enough of what these amps have done for me in terms of detail and no compression of sound in loud passages of music/film. For me, they are a revelation! It's only been in the last month or so that actors, orchestras, soloists have exited the speakers and are in my home theater room! The Maggies are so much more in richness and dynamics that I really can't believe it! I had a gut feeling prior to purchasing them that I was in for something very special and that's putting it mildly! I've received Paul's emails over the years and actually this was a blind purchase but the price was certainly right for each of the six amps and the trade in of my Carver 7 channel amp was financially sufficient enough that the value given me would cover one and a half of the 700's!
    Bravo!
    I just replaced my Parasound Halo A21 amp with your M700's. All of my electronics are now PS Audio: BHK pre, P5 power conditioner, memory player, Direct Stream DAC, and now the m700”s. Each new piece marked an improvement in my system. But the addition of the amp took my system into some place magical. When I read equipment reviews, I am often skeptical of the claims therein. I have to say that the level of musical engagement was so palpable as to defy belief. There was great clarity and even 3-dimensionality with the PArasound, but the M700's brought something else into the field. It is almost impossible for me to hear my music and not want to move with it. That is the way I feel at a club or a concert hall. Now it is in my living room. Every one of my friends who have heard my system as I have slowly built it has been impressed, but the final handshake between all your components is something beyond my explanation. Obviously, I am a fan, but there are times when you need to give praise for the efforts and dedication that you people bring to your products. Bravo!
    Questions?
