- Four models to choose from
Bi-Wire available
Comes with spade and banana
Solid core and Multi-strand build
Soldered connections
Open, spacious, transparent sound
- Open dimensional presentation
Full and robust sound
Extremely fast transient response
Improved 3d imaging
Open top end
Unbelievably rich and robust
The PS Audio xStream Speaker Cable is the finest power interconnecting system made. Recognizing that the speaker/amplifier combination is the single most difficult interface in the entire audio chain, it is absolutely critical that you get it right.
The xStream Speaker Cables "get it right" with lots of copper, both solid core and Multi-strand construction and the ability to change to whatever type of connector your system requires "on the fly".
