xStream Resolution Audio Cables
Awards
Cable Products > xStream Resolution Audio Cables
Starting at just $149.95!
  • Zero loss cables
  • Twin lead dual 18 gauge conductors
  • PCOCC single crystal Reference
  • Solid Silver Transcendent
  • Triple shielded
  • Low absorption dielectric
  • Highest quality connectors
  • Jaw dropping performance
  • Locking RCA connectors
  • Lowest loss cables on the market
  • Preserves all musical info
  • The best interconnects we've ever heard or built
  • Flexible
  • Musical
"Finally, after mucho break-in time, the Transcendent XLR's between my preamp and amps, settled-in. Took a couple of weeks of continuous play. I have to tell you, that once broken in, these cables deliver superb all-around performance, and actually revised my thinking on them. When broken in, they are detailed without any sense of glare or sheen on voices, in particular. Also, the bass performance is very detailed and authoritative, BUT without being overblown.
Two examples for you: The old Siltech '18's are remarkable for their clarity and, "speed", if you will. They are, however, relatively bass deficient in two of my systems. The very, very expensive Japanese Audio Tekne ($750.00/meter) cables have amazing midrange and top end, but almost too much bass. Once broken in, the Transcendent are the equal of the Audio Tekne in every way except the bass; Down low, the "Trans" are actually superior to the Audio Teckne, in my opinion. "
Mike Dodson
We're shipping now
The xStream Audio Series of interconnects are among the finest in the world at any price.
There are two models in the line: Reference and Transcendent. Reference uses solid PCOCC single crystal copper and Transcendent is built from solid silver for zero loss. Get everything possible from your system. These interconnects are awesome!
