xStream™ Super Punch Power Cable
Awards
Cable Products > xStream™ Super Punch Power Cable
Starting at just $69.95!
  • Unique right angle male plug
  • Works for either audio or video
  • Hugs the wall or conditioner
  • Connectors machined from solid billet
  • Nickel plated and polished
  • Hermetically sealed connectors
  • Removable ground pin
  • 12 Gauge multistrand OFC copper
  • Double shielded
  • Ferrite impregnated jacket
  • Hot and cold welded connections
  • Perfect for both audio and video equipment
  • Shielded power
  • Lowers noise floor
  • Improves picture quality
  • Improves video black level
  • Improves audio quality
  • Helps eliminate ground loops
  • Improves performance of anything connected
The Super Punch Power Cable has a unique right angle male power cable, designed to hug the wall or power conditioner.
When used behind a plasma or LCD wall mounted screen, it provides a neat and clean installation.
As a video or an audio cable it will work wonders with any video product because of its exceptional shielding and power delivery capabilities.
