xStream™ Radian Power Cable
Awards
Cable Products > xStream™ Radian Power Cable
Starting at just $229.95!
  • 12 gauge copper conductors
  • Right angle IEC
  • Multistrand OFC copper
  • Connectors machined from solid billet
  • Nickel plated connectors
  • 2 shields
  • Hot and cold welded connections
  • Removable ground pin
  • Ferrite impregnated jacket
  • Fits under Mark Levinson products
  • Unrestricted power delivery
  • No stamped brass parts
  • No corrosion
  • Huge surface area for connections
  • Fits underneath products
  • Perfect for using in tight spaces
  • Cleans while it powers
  • Excellent power delivery
  • Lower noise floor
  • Ability to eliminate ground loops
"the improvemnt in sound is astounding for the relatively low cost of the cables. In fact I don't think I have ever heard that degree of improvement relative to the cost of the upgrade. "
Lee Allen
Now there's no need to compromise!
The Radian was designed to fit under products like the Mark Levinson's or behind products where space is at a premium.
The exclusive custom made right angle low profile IEC connector is perfect to fit anywhere.
