xStream™ Power Punch Power Cable
Awards
Cable Products > xStream™ Power Punch Power Cable
Starting at just $49.95!
  • Connectors machined from solid billet
  • Braid shielded
  • C7 and IEC styles
  • Nickel plated and polished
  • Hermetically sealed connectors
  • Removable ground pin
  • 12 Gauge multistrand
  • Hot and cold welded connections
  • Perfect for source equipment
  • Shielded power
  • Lowers noise floor
  • Helps eliminate ground loops
  • Improves performance of anything connected
"I have had high-quality power cords in my system for many years, from companies like Balanced Power Technologies, Soundstring, and Monarchy, to name a few. They all made a difference, but the thing about the Power Punch is the degree to which it raised the performance of my CD/DVD player. That had not been the case with any other power cord. This is what my player had needed all along. If you have a component that is having its performance strangled by a stock C-7 cord, you owe it to yourself to try the PS Audio X Stream Power Punch."
Francisco Duran
Our most affordable, entry level AC power cord is perfect for any source equipment, digital products and small to medium power amplifiers.
PS AC power cables are unequalled from a construction quality and performance standpoint. There are none better in the world.
The Power Punch is affordable and allows anyone to replace their stock power cables and make an immediate improvement.
The C7 style of connector works for any consumer product like an Xbox, CD player or DVD with the smaller end. The standard IEC model works with any detachable cable product.
