xStream Premier SC Power Cable
Awards
Cable Products > xStream Premier SC Power Cable
Starting at just $995.00!
  • Solid silver conductors
  • PCOCC single crystal copper
  • 7 gauge overall
  • Machined prongs
  • Removable ground pin
  • Ferrite impregnated jacket
  • Unrestricted power delivery
  • Finest power cable in the world
  • One single crystal barrier
  • Huge surface area for connections
  • Cleans while it powers
  • No comprimse power delivery
  • Lower noise floor
  • Ability to eliminate ground loops
"I upgraded the stock power cord for the UPC-200 to a Plus SC. I thought the difference would be minor. It certainly isn't. It is huuuuuge. After 36 hours it opened up with a greater soundstage, bass that is tight and definitely more natural, and instruments, whether it is a rock band or a large orchestra, have taken on a vibrancy that is more precise in texture and timbre. The separation of intruments is incredible. I am blown away. Geniuses you are!"
Charlie K
Combining the best of the two finest conductors in the world, silver and PCOCC pure copper, the Premier is the best power cable in the world. 7 overall gauge, which is huge, the Premier has 14 gauge of solid silver (equal to a stock power cord) and then we add in PCOCC pure single crystal copper to build the overall gauge to 7.
