xStream Plus SC power cable
Awards
Cable Products > xStream Plus SC power cable
Starting at just $269.00!
  • Solid core
  • Single Crystal
  • PCOCC
  • Multiple Shields
  • 10 gauge PCOCC conductors
  • Connectors machined from solid billet
  • Nickel plated connectors
  • Hermetically sealed connectors
  • Hot and cold welded connections
  • Removable ground pin
  • Ferrite impregnated jacket
  • Unrestricted power delivery
  • Awesome performance
  • One single crystal barrier
  • Huge surface area for connections
  • Cleans while it powers
  • No comprimse power delivery
  • Lower noise floor
  • Ability to eliminate ground loops
"I own a Mark Levinson Reference based system, and I am using a couple of your Power Plants
Your new XStream Premier power cables were a more significant "step up" from your XStream Statement power cables that they replaced than the Statements were from stock cables! As you know, many Levinson products have upgraded "S" versions which employ a special circuit board material. These "S" versions sound significantly better than the standard versions. Adding your new cable to my Reference Levinson equipment was like "S'ing" the "S" version!
The addition of of the XStream Premier SC cables has elevated the performance of my audio system to an entirely new, improved, and much higher level.
Call them indespensable, but that is what they are -- indespensable! (One is not buying a cable, they are buying what the cable does for the music and these guys "do it" like no other!!!) This may very well be the very best power product that PS Audio has yet produced! "
Rob Cooper
10 gauge, machined connectors from a solid metal billet, an outer jacket that actually cleans the AC is it powers your equipment, and the best single crystal copper conducting material on the planet, PCOCC
Real power solutions from the power leader, PS Power.
