xStream™ Plus Power Cable
Awards
Cable Products > xStream™ Plus Power Cable
Starting at just $229.95!
  • 8 gauge copper conductors
  • Solid core and Multistrand
  • Connectors machined from solid billet
  • Nickel plated connectors
  • Hermetically sealed connectors
  • 4 shields
  • Hot and cold welded connections
  • Removable ground pin
  • Ferrite impregnated jacket
  • Unrestricted power delivery
  • No stamped brass parts
  • No corrosion
  • Huge surface area for connections
  • Cleans while it powers
  • Excellent power delivery
  • Lower noise floor
  • Ability to eliminate ground loops
"The Plus [in my system] has added another level of refinement. The highs are extended without brightness or exaggeration. Midrange is pure and soundstage seems wider, with a bit more depth. Remember, that overall these changes are subtle. To the casual listener with a mid-fi system, maybe meaningless or inaudible. But, for someone trying to get the most out of their system, power cords in general and the Plus specifically are a worthwhile purchase "
Jeff
8 gauge, machined connectors from a solid metal billet, an outer jacket that actually cleans the AC is it powers your equipment, the Plus is our second best power cable and an excellent performer.
Don't settle for less than what your equipment has to offer. Power with an xStream power cable.
