xStream™ Digital
Awards
Cable Products > xStream™ Digital
xStream™ Digital
Starting at just $179.00!
  • 3 shields
  • Conductive PVC layer
  • OFC copper and silver conductors
  • Multi-stranded for surface area
  • PE Foam insulation
  • Low absorption dielectric
  • Low capacitance
  • RCA coax
  • BNC Coax
  • XLR AESEBU
  • TOSLINK Glass
  • Enhanced imaging and focus
  • Reduced digital jitter
  • Eliminates bright "digital" sound
  • Permits ultra-fast rise times
  • Dolby Digital & DTS optimized
  • Improves all digital connection
"I just received my Prelude PC and the xStream Digital IC and WOW, what a difference! The body of the instruments / voices are so much more robust, much fuller. My first impressions are that each cable made a 10 to 15% increase in clarity / resolution. The prelude PC replaced a stock cord on my Toshiba SD-4700 DVD player (connected to a Denon AVR-2802) and the xStream Digital replaced a bettercables Silver Serpent which tended to emphasize certain frequency ranges. I am very pleased and will be getting the xStream Audio RCA''s for the DVD-Audio connections! And I must say that I THOUGHT I was ordering the least expensive PC (prelude) - all I could do is blink my eyes with my mouth hanging open when I saw how thick & heavy it was!
The pictures on your website don''t put it into perspective - you should show them with a person''s hand so they know what to expect - so they don''t go into shock like I did upon first sight! I was floored!"
Tom from Erie PA
Now you can afford state of the art performance when it comes to your CD, DVD music or video playback system.
xStream Digital cables are as good as they get. Regardless of the cost of your equipment, the xStream Digital will provide stunning performance on your two-channel or your multi-channel system.
  • Capacitance per foot
  -   10 pF
