Power Products > Ultimate Outlet
Ultimate Outlet
Starting at just $299.00!
- Standard and High Current versions
Standard version for all video, small to medium power amps and source equipment.
High Current version for all large power amps or use as a reference for everything.
Lowers impedance by a factor of three
Reduces noise by up to 40 dB!
Improves both audio and video performance.
Stereophile's Accessory of the year!
- Improves depth
Enhaces soundstage
Protects from surges and spikes
Cleans the top end of any audio equipment
Video is dramatically improved
Provides isolation
Lowers the system's noise floor
"I have both an ARC VT-100MKII amp and ARC Reference 2 preamp that I run off a P600. In my system, the resulting sound is stunning in comparison to plugging directly into the wall. I have 2 high current Ultimate Outlets which improve the sound of the ARC gear but are not the sonic equal to the P600 by any means. The expense and size of the P600 are well worth it IMO."
RLC
This state of the art balanced power coupler is designed to clean, protect and enhance your system.
No, not a Power Plant, but once connected, the new power that comes out of the Ultimate Outlet is quieter by up to 40 dB, and fully protected against surges, spikes and trouble.
The Ultimate is affordable, and in no way restricts the power of your wall outlet.
Use with power amplifiers of any size, projectors, TV's, analog or digital equipment. Truly a unique and breakthrough technology inside.
The improvement with video is quite noticeable.
And if you think the Ultimate's cleaning and protecting powers are something your system would benefit from, check out the Power Director, our newest system wide approach to power that contains four of the Ultimate Outlets inside.
The Power Director can handle an entire system. Download the Manual: Ultimate Outlet Manual
