Quintet Power Center
Awards
Power Products > Quintet Power Center
Starting at just $495.00!
  • Real surge protection
  • Nano Crystalline filters
  • Common Mode filtering
  • Differential mode filtering
  • Unimpeded AC power flow
  • 10 Power Port AC receptacles
  • Solid aluminum chassis
  • Over under voltage protection
  • Solid copper delivery system
  • Delayed, switched outlet choices
  • Two 12 volt triggers
  • Two coax protection ports
  • Two phone protection ports
  • Real sonic improvements
  • Best filter performance
  • Complete surge and spike protection
  • Low resistance AC path
  • Superior noise reduction
  • Delayed turn on for proper startup
  • Protect satellite or TV as well
"Wow. This is better than the PD 4.7 and I think the best piece I have ever owned. I am hesitant to even send it back. The difference it makes in my system is openness and it sounds more powerful."
Steve Clark
The Quintet Power Center is the world's first component level AC power center to offer true surge protection and outstanding AC filtering in an affordable package.
The Quintet offers both common mode and differential mode noise filtering of the AC line, improves performance of connected equipment and provides a safe and noise reduced power source for both audio and video equipment.
Download the Manual: Quintet Manual
  • Dimensions
  -   17.25" W x 5.25" D x 3.75" H
  • Weight
  -   8 lbs
