Power Plant Premier
Awards
Power Products > Power Plant Premier
Power Plant Premier
Starting at just $2,195.00!
  • Also available - Limited Edition Black!
  • Regenerated AC power
  • Low distortion sine wave
  • MultiWave and CleanWave
  • Regulated AC
  • 1500 watt output power
  • Harmonic distortion analyzer
  • Remote control
  • Nano Crystalline filters
  • 10 Power Port AC receptacles
  • Solid copper delivery system
  • True dynamic voltage regulation
  • Better bass from equipment
  • Real isolation
  • Protection for everything connected
  • Lowers distortion by 10 times
  • Ultra low output impedance
  • Superior noise reduction
  • Delayed turn on for proper startup
  • Protect satellite or TV as well
  • Harmonic analyzer gives complete visibility of your power
"I was surprised at the improvement over the P600. A noticeable improvement in detail and spaciousness of the soundstage. Voices sounded much more "there". These things, I wasn't expecting.
What I was expecting, and got, was a very nice increase in dynamics. I believe the amp I have was a bit current-starved out of the P600, and as such, wasn't as punchy as I would like. Now it is. The bass also became better defined and fuller.
So, all-in-all, a very nice improvement. "
RSchergen
The Premier Power Plant is the world's only true AC regenerator that offers the full power of the wall, low distrotion even with difficult loads, MultiWave, CleanWave, remote control, true surge protection, front panel harmonic power analyzer, AC volt meter, and outstanding AC isolation in an affordable shelf or rack mount chassis product.
The Premier Power Plant offers stable, regulated and purified AC power regardless of the incoming AC line quality and improves performance of connected equipment while providing a safe and noise free power source for both audio and video equipment.
Download the Manual: Power Plant Premier Manual
  • Dimensions
  -   17" W x 16.5" D x 4" H
  • Weight
  -   35 lbs
  • Nominal Input Voltage
  -   105-135 (US) 215-245VAC (Europe/Asia)
  • Maximum Continuous Load
  -   1200VA (US) 1500VA (Europe/Asia)
  • Dynamic Power Delivery
  -   0.5 second >3600VA (US) 5000VA (Europe/Asia)
  • Voltage Regulation
  -   +/- 0.5V (US) 1Vac (Europe/Asia)
  • Output Distortion Input 220-240VAC
  -   1200VA Resistive load <0.9%
  • Output distortion 230V
  -   240VAC 1200VA Reactive* load <0.9%
  • Output Distortion Input 110-130VAC
  -   1200VA Resistive load <0.5%
  • Output distortion Input 110-130VAC
  -   1200VA reactive load <0.5%
  • Output impedance
  -   <0.015 Ohm
  • Noise reduction (all zones)
  -   100KHz-2MHz >80dB
  • Efficiency @1200VA
  -   Resistive load >80% Reactive load >85%
  • Input Frequency
  -   45-65Hz
  • Under voltage limit
  -   90VAC (US) - 175VAC (Europe/Asia)
  • Over voltage limit
  -   145VAC (US) - 275VAC (Europe/Asia)
  • Protection Modes
  -   L-N, L-G, N-G
  • Energy dissipation
  -   2160J (US) 2142J (Europe/Asia)
  • Peak Current surge
  -   144,000A (US) 84,000A (Europe/Asia)
  • Max Surge
  -   6,000 Volts
  • Clamp level
  -   330V (US) 800V (Europe/Asia)
  • Telco protection
  -   320 Joules 395 volts
  • Coax insertion loss
  -   <1dB
  • DC trigger config
  -   Tip positive
  • DC trigger Voltage
  -   5-15 volts dc
