- Remote control
UPC Power Cell input filter
New capacitors
Teflon silver plated wire
New logo light
Bring up to spec
New Power Ports
- Cleaner performance
High temperature capacitors
Better reliability
Improved sound
Change MultiWave settings via remote
CleanWave via remote
"After I ordered the P300 Power Plant modification PS Audio sent me an e-mail asking what my Power Plants serial number was and shipping instructions. I sent my Power Plant to PS Audio and it was returned in less than two weeks. All I can say these modifications must be a labor of love. They must high regard for the P300 at PS Audio. Well to say it simply it made my system sound more like music. The remote control makes it a lot easier to use clean wave. It did take some time using the remote control to learn how to use it to control all the functions."
aaron
Upgrade your P300 to the latest specifications. This factory modification adds a remote control, a UPC-200 input stage, better wire and all new capacitors. The improvement is significant and worth every penny.
