Power Products > P1200 Power Plant
P1200 Export Models
Starting at just $3,995.00!
All three models of the PS Audio Power Plant series are available as an export version, producing between 220 and 240 volts on their output (standard is 100 to 120 volts for our domestic model). The output voltage is adjustable by the user via the front panel control on all models of Power Plants.
While all models of Power Plant are able to accept either 120 volts AC or 230 volts AC on their input, they will only produce 120 volts AC on their output unless the export model is chosen.
Customers in the United States, Canada, Taiwan, Mexico and Japan can order the domestic model.
Input voltage, 120 or 230 is switchable
If you live in a country that has 230 volts AC as its standard voltage, you can simply open the Power Plant and switch the voltage adjust control to that voltage. This will work fine, providing that you have equipment that you wish to power from the output of the Power Plant that is able to be run at 120 volts AC. Most stereo and video equipment is easily switchable between 120 volts AC and 230 volts AC.
The Power Plant will not produce 230 volts on its output unless you purchase the export model.
If you have equipment that is not switchable
If the stereo or video equipment in your home is not switchable to 120 volts AC, and must be operated at 230 volts AC, you can purchase the export version of the Power Plant.
Export version of the Power Plant
The export version of the PS Audio Power Plant has a large, highly efficient balanced transformer added to its output. This balanced transformer, which is 80% efficient, will increase the output voltage of the Power Plant to 230 Volts with little to no loss of sonic quality.
Price for the P300 export model
- $1,745.00 UK version. Includes whisper fan, MultiWave technology, front panel adjustable voltages, Neutrik Powercon input connector and matching custom input cable, one Neutrik Powercon power output and matching plug, three UK lab grade 13 amp shuttered power outputs.
- $1,745.00 Euro/Schuko P300. Includes MultiWave, whisper fan, MultiWave technology, front panel adjustable voltages, Neutrik Powercon input connector and matching custom input cable, one Neutrik Powercon power output and matching plug, three Schuko-Euro standard power outputs.
- $1,745.00 P300 Export standard. Includes MultiWave, whisper fan, front panel adjustable voltages, four hospital grade NEMA-15 115 volt receptacles.
Price for the P600 export model
- $2,995.00 UK P600. Includes MultiWave technology, front panel adjustable voltages, Neutrik Powercon input connector and matching custom input cable, four Neutrik Powercon power output and matching plug, four UK lab grade 13 amp shuttered power outputs.
- $2,995.00 Euro/Schuko P600. Includes MultiWave technology, front panel adjustable voltages, Neutrik Powercon input connector and matching custom input cable, four Neutrik Powercon power output and matching plug, four Schuko-Euro standard power outputs.
- $2,995.00 Export standard P600. Includes MultiWave, adjustable output voltages, eight hospital grade NEMA-15 115 volt receptacles for power outputs.
Price for the P1200 export model (includes Multiwave)
- $4,950.00 UK P1200. Includes MultiWave technology, front panel adjustable voltages, Neutrik Powercon input connector and matching custom input cable, four Neutrik Powercon power output and matching plug, four UK lab grade 13 amp shuttered power outputs.
- $4,950.00 Euro/Schuko P1200. Includes MultiWave technology, front panel adjustable voltages, Neutrik Powercon input connector and matching custom input cable, four Neutrik Powercon power output and matching plug, four Schuko-Euro standard power outputs.
- $4,950.00 Export standard P1200. Includes eight hospital grade NEMA-15 115 volt receptacles for power outputs.
