Lab Speaker Cables
Awards
Cable Products > Lab Speaker Cables
Lab Speaker Cables
Starting at just $695.00!
  • 6 Gauge Copper
  • State of the art WBT Spade Connections
  • Triple shielded
  • Increases midbass
  • Rich, full bodied performance
  • Life like midrange
  • A real jaw dropper!
  • Awesome and unequalled mid bass bloom
  • Subterranean bass performance
  • Un-restricted energy flow
  • Full, big, open soundstage
"I always find great pleasure and reward when putting a piece of gear/cable into my system and it totally exceeds expectations. I am not easily impressed. Let me break this down.
The Lab Speaker Cable is a home-run cable! I have had numerous kinds of cable in my systems over the years. Each has their own characteristics. I was shocked, literally, by the amount of information I was receiving through these cables on material I knew, both from music and movie sources. While I use the Lab Power Cables and Ultimate Outlets for my systems, the only change was the Lab Speaker Cable. In my system, I have never heard dynamics jump as quickly, with more power and authority, than with these cables. Fast! The timbre of acoustic music is right, rich, full -- but not bloated. Yes, I am comparing them to cables that cost many times more! Anyone who does not seriously consider these cables in their system, no matter how expensive their system, is missing a musical and emotional opportunity. I can not get the smile off my face. Thanks. "
Lowell Graham
One of the hallmarks of a great stereo system is a full, rich midbass and a midrange with lots of "bloom" and life.
Frankly, not many systems have an appropriate amount of the all critical midbass, and so instruments tend to sound less natural, less full.
We have discovered that in many cases, it's the loudspeaker cable that is causing the restricted midbass, and the equipment and loudspeakers are just fine.
Introducing the Lab Cable speaker version. Complete with the world's finest spade connectors from WBT, the Lab speaker cable will provide more midbass and midrange bloom than virtually any other cable we know of.
If you have not heard your loudspeakers connected to your power amplifier with a Lab Cable, then you really don't know all that there is to hear. This is jaw dropping material.
If a full bodied rich musical presentation is important to you, then the Lab speaker cable is absolutely worth your time. We highly recommend you audition one soon.
