GCP-200 Preamplifier
Awards
Stereo Products > GCP-200 Preamplifier
GCP-200 Preamplifier Specifications
Starting at just $2,195.00!
PS Audio has never been a big advocate of publishing specifications because they rarely reflect the way a product performs in your system. Customers have judged performance, based on specification comparison, without a working knowledge of how specifications relate to the way a product sounds. However, the opposite has happened as well: some customers will not choose our products because we don’t publish the specs. We decided to go ahead and publish specifications for the GCA line of amplifiers, acquiescing to demand from our customers.
We felt that as long as we’re publishing specifications we may as well include the graphic data from those measurements as well.
PS is a performance based company and as such we believe how a product performs in your system is related to these measurements but these measurements are not the entire story.
Type Solid State
Power Supply Capacitance 60,000 uF
Single-ended Inputs RCA - 6 pair
Balanced Inputs XLR - 1 pair
Input Device Type PS Audio Gain Cell
Input Impedance 47.5 kohms
Input Sensitivity 175mV - 8.5V
Single-ended Outputs RCA
1 Pair Normal
1 Pair Buffered
Balanced Outputs XLR - 1 pair
Gain (RCA) 4 to 14dB (Adjustable)
Gain (XLR) 10 to 20dB (Adjustable)
Maximum Output Voltage (RCA) 4.25V
Maximum Output Voltage (XLR) 8.5V
Frequency Response +/- 0.1dB 10Hz-50kHz
THD+N < 0.007% at 1V
Power Consumption @ idle < 15 Watts
Weight 27.0 lbs.
Dimensions (W x H x D) 17.25 x 4.00 x 14.00 in.
Join our newsletter group and get insider information once a month featuring the latest new product information from PS Audio before it hits the street!
Can you receive HTML email?   Yes   No
Email Address:
