Copper#90 ; Part 2, in Copper #91---Ed.>
All of the brass points/receptor cups were designed to have cored-out cups so they could be filled with a lead/elastomer matrix. Using a urethane matrix eliminated the possibility of the lead shrinking away from the brass cups as it cooled.
The bottom of all of the cups were fitted with ¼” diameter steel ball bearings bonded into recesses machined into the bottom of the cups; therefore, assuring a three-point contact.
Here we see epoxy resin being blended with #9 lead shot in a Hobart mixer just before being poured into the undersides of the main plinth and drive motor support bases.
This is the underside of the sub-base for the VPI double motor flywheel drives, ready to be filled with the epoxy/lead matrix.
This is the underside of the main turntable plinth, ready to be filled with the epoxy/lead matrix.
The next step in getting the Minus K properly set up to support the weight of the turntable is to bond ½” thick high durometer rubber to the center top plate on the Minus K unit. It is being bonded down with a polyurethane elastomer adhesive. This adhesive will remain flexible after it is fully cured.
Initially it was my thought to install a pair of air pressure gauges, one for each of the Kuzma Air Lines and a vacuum gauge for the Sota vacuum pump. After thinking about it, I thought the gauges really serve no purpose and look out of place, as it made the unit look too industrial, so I ended up removing them.
After applying a layer of polyurethane adhesive to the top of the rubber blocks on the Minus K, I lowered into place the aluminum plate that will accept the plinth for the turntable. This plate has become part of the Minus K isolator.
Immediately after applying the adhesive, the plate was lowered and accurately positioned squarely on top of the rubber pads on the Minus K isolator. The adhesive was then allowed to cure. I might add the following; the thin sheet metal box that came with the Minus K, protecting the inner workings from dust, debris, etc., has been replaced by a number of ½” thick aluminum plates that will not only serve the same purpose but be much more aesthetically pleasing.
Ed.>
There’s something elemental and captivating about the sound of stringed instruments, and The Art of Hi-Fi Volume 04: Strings from PS Audio’s Octave Records showcases them to spellbinding effect, in...
AXPONA (Audio Expo North America) has become the biggest audio show in the United States. The 2024 show featured more than 200 exhibit rooms with over 600 exhibitors and brands....
